HELP!!!PLEASE Toshiba A300 and Capacitor Tutorial
  • bonniedoon
    • Jan 2015
    • 22
    Hi peoples, I have an A300 that needs to have the NEC Tokin 0E907 replaced. Now I am a novice at this sought of thing, so can some please post a complete fix: this would be from the removal of the Tokin, cleaning the 4 strips and how to solder the 4 new capacitors, including the soldering method, Photos of each stage. Also, what one has to to do to determine the corrects Tantalums. I have seen these Tatalums on ebay where they state them as being a replacement for the Nec Tokin 0E907. http://www.ebay.com.au/itm/4x-SMD-Ta...-/330953629462 Thanks peoples
  • diif
    • Feb 2014
    • 6978
    • England
    Re: HELP!!!PLEASE Toshiba A300 and Capacitor Tutorial
    Read this thread, lots of help in there https://www.badcaps.net/forum/showth...ighlight=tokin
    Yes those tantalums are suitable.
    • trebo
      • 514
      • Wales, UK
      try reading this thread that you first posted into,"https://www.badcaps.net/forum/showthread.php?p=526455#post526455"
      Its a long one I know, but the reason being for that is that people on the forum went out of there way to give the information that you are asking for, you only have to browse through it to find loads of detailed info that you require, trust me its all there.
      • bonniedoon
        • Jan 2015
        • 22
        Thanks peoples, I will peruse those articles and let you know the outcome
        • bonniedoon
          • Jan 2015
          • 22
          Advice Please, I can get these Caps here in Perth Australia, would these do the job???
          http://au.mouser.com/ProductDetail/K...1myMofWw%3D%3D
          • diif
            • Feb 2014
            • 6978
            • England
            At 3.1mm i believe they are too tall.
            • bonniedoon
              • Jan 2015
              • 22
              Si I should stick to these http://www.ebay.com.au/itm/4x-SMD-Ta...item35d388d70c
              • denilloo
                • May 2013
                • 60
                • indonesia
                This work for me
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Originally posted by bonniedoon
                  Yes
                  • bonniedoon
                    • Jan 2015
                    • 22
                    please could someone check these links to see if they would be ok to fix my a300
                    http://au.rs-online.com/web/p/tantal...itors/7887457/
                    • coelectron
                      • Mar 2014
                      • 58
                      • Argentina
                      it's oK
                      • LENOVO-A880
                        Not A Bad BIOS
                        • Feb 2014
                        • 79
                        • MALAYSIA
                        You can try to use ceramic capacitors to replace your Toshiba Satellite A300 NEC tokin. You can get the replacement capacitors from RS-Components Australia with this PART NO: GRM31CR60J107ME39L. There are some successful testimonials from this forum by just using at least 10 of these ceramic capacitors from these badcaps mega thread...
                        https://www.badcaps.net/forum/showth...t=8991&page=12
                        https://www.badcaps.net/forum/attach...1&d=1362533466
                        and also this one for MSI-CR400 which has the same shutdown problem
                        https://www.badcaps.net/forum/showpo...&postcount=105
                        take a look at this... added some on the pads along with the original nec tokin chip but not really neat or just put them all 10 of the capacitors as a replacement for any tantalum one....
                        https://www.badcaps.net/forum/attach...0&d=1296545075
                        "If you cannot do great things, do small things in a great way."
                        -Napoleon Hill
                        "The chip that functions abnormally will be desoldered, as they say."
                        -Charles Stross
                        "Why is it you're always too small or too tall?"
                        -The Mad Hatter
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          I found that ten of GRM31CR60J107ME39L were needed sometimes.
                          I have been using four of 2R5TPE330M9 2.5V 330UF for a year or so now.
                          If a lot are needed, they can be found on AliExpress for good prices.
                          • bonniedoon
                            • Jan 2015
                            • 22
                            Thanks peoples for giving me your inputs, very much appreciated.
                              Toshiba Satellite A300-1RZ Specification for Upgrade or Repair
                              This specification for the Toshiba Satellite A300-1RZ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1RZ boardview and A300-1RZ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Satellite...
                              09-06-2024, 05:27 AM
                              Toshiba Satellite Pro A300-1MK Specification for Upgrade or Repair
                              This specification for the Toshiba Satellite Pro A300-1MK can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1MK boardview and A300-1MK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                              Toshiba Satellite Pro A300-22J Specification for Upgrade or Repair
                              This specification for the Toshiba Satellite Pro A300-22J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-22J boardview and A300-22J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                              Toshiba Satellite A300 A300-14S Laptop Schematic
                              Quanta BL5S Santa Rosa - Rev 1A...
                              11-01-2024, 07:49 AM
