Dell 2407WFPb monitor issue
  • Deritsuku
    • Aug 2014
    Hello everyone!
    I'm new here, and hopefully I can finally get some help.
    I apologize if this topic was already posted somewhere before. I'm still learning the ropes.
    So here is what is going on:
    About a little while ago, I had gotten a Dell 2407WFPb monitor for about $20. I was uber excited since this was the largest monitor I've owned (24"), and I know these things don't come cheap brand new.
    So I set up the monitor, plugged everything in, and booted up the computer. Everything worked fine, the picture looked great, and so on and so forth...
    And then something happened. The picture disappeared. I waited for a few seconds since I thought my graphics card was adjusting the picture, but nothing happened. So I tried to shut off the monitor. I noticed that monitor buttons would not work, no matter what. I couldn't turn the monitor off, bring up the menu, and so on and so forth. I had to unplug it to turn it off. So I waited about a minute and plugged the monitor back in and turned it back on. Same thing happened again. I waited a little bit longer, and that was when I noticed horizontal white lines dancing up and down the screen. So I unplugged the monitor again. I decided to open the monitor up to look for any burn marks, popped capacitors, ect. ect. The board was clean. So I checked all of the fuses. All of them were fine. So, with the case apart, I plugged the monitor back in. Even though the problem repeated itself eventually, the monitor remained functional for much longer.
    What is wrong with the monitor, and how can I fix it so that I can get it up and running properly without any problems?
    Many thanks in advance, Derrick.
  • SuperJames
    Dell G3 17 3779 Weird power cycling and shutdown/restart issue
    by SuperJames
    This one's a weird one, and still unsolved despite it having gone back to Dell once.
    Specs
    i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
    Backstory
    I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
    10-23-2023, 04:09 PM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Ven
    Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
    by Ven
    Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
    Issue Description:
    1. CPU Overheating to 100°C
      • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
      • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
      • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
      • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
      • Thermal
    02-12-2025, 03:57 PM
  • NotEnough
    Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
    by NotEnough
    I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
    What I've Tried So Far:
    • Reseated the cables.
    • Reinstalled AWCC and AlienFX services.
    • Attempted BIOS downgrade but no improvement.
    • Inspected ribbon cables for damage.
    • Explored the possibility of BIOS or
    10-19-2024, 01:34 AM
  • computerbacon79
    Dell Inspiron 3480 All in One corrupt Bios issue
    by computerbacon79
    The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
    05-06-2025, 06:43 PM
