Browsing some sites CPU Temp goes higher!
+ More Options
Posts
  • ivtec
    • Dec 2008
    • 1967
    Hi guys: why when i go to some sites the Fan just speeds up and CPU temp goes sky high?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Browsing some sites CPU Temp goes higher!
    probably sites loaded with flash....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      • 31015
      flash isnt too bad,
      i'v seen the cpu load jump on sites with a lot of java on them.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        That too...
        Team : 49813
        Join in!!
        Team Stats
        • jts1957
          • Dec 2008
          • 38
          Sure you didn't mean flesh?
            • 31015
            try this!! flesh/flash - if this dont slow your system nothing will!!!
            http://www.xcams.com/en/
            • reaper57
              • Sep 2014
              • 216
              • Norway
              Yup java and flash can make your cpu do that some times, but as long as you lave good thermal paste a clean heatsink and a working fan it shouldn't get too high! How hot does your cpu get? This is probably a problem with your cooling.
              Keyboard not detected, press F1 to continue...
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                even scrolling a page with a lot of content can cause cpu spikes, not just plugins.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Flash or Javascript. Fortunately things are getting better with HTML5.
                  A working TV? How boring!
                  • SteveNielsen
                    Retired Tech
                    • 2327
                    I agree with Reaper, there's a problem with cooling the CPU. In normal operation the CPU temp will increase with the workload but if it is jumping sky high then it is a cooling problem.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Also a very outdated browser will do that. I have this problem with Opera 11/12 on certain websites. Best example is with IE6, though. The only websites it won't choke on is oldschool plain HTML ones (you know, the ones without flash banners and simple GIF graphics - remember those? ).
                      I suspect scripts are the root of the problem. Flash only adds insult to the injury .
                      • sfuk
                        • Jan 2015
                        • United Kingdom
                        First thing is first get a decent cpu monitor. Coretemp / HWmonitor. Second it is always a good idea to ensure your browser is up to date. You would be surprised of the memory leaks in the older browsers. Memory usage = cpu usage. The posters above are correct. If your cpu is not colling properly then you got a problem. Clean out your fan and heatsink and also renew the thermal paste. Clean both heatsink and cpu with something like isopropranol or a cpu cleaner. (it breaks down the old paste) finally decent cpu paste (be sparing to much does the reverse job) Attach and check your monitors if no better come back to us.
                        • ivtec
                          • Dec 2008
                          • 1967
                          Thanks guys; i did the CPU thermal paste,cleaned fan,it's much better but still goes high,on a sports streaming it goes as high as 76c and fan speeds up and on just browsing on most sites 65 degrees,
                          i've red that this HP DV5 1254 US this is Linux Ubuntu 14.04, runs hotter than other models,
                          my other HP DV6 1259 with Win7 runs much cooler 35c
                          • reaper57
                            • Sep 2014
                            • 216
                            • Norway
                            Oh, it's a laptop, now I get it. 65C seems a bit high, but still close to what I would expect from most dv5-1xxx notebooks. What are your gpu temps? The cpu isn't soldered on the motherboard like the gpu so I wouldn't worry about it too much, as long as the gpu isn't too hot. But if the cpu is at 76C, then the gpu is not far behind. Can you try a windows install with all of the correct drivers and codecs? I have the feeling that the gpu isn't being used for the decoding and the cpu is getting most of the load.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              For a DV5 these temperatures are normal. Actually they're low. "Normal" CPU operating temperature for that is around 80-85C. Yeah, their cooling sucks big time.
                              The GPU on that model is integrated into the Northbridge, it's the Intel GMA4500MHD. These are known to fail sometimes, but it's a very rare event. So i would say you are safe. There isn't much you can do about the temperature anyway. Besides drilling some extra vent holes in the bottom case of course.
                              • ivtec
                                • Dec 2008
                                • 1967
                                Thanks guys here a screenshot on Espn3
                                • ivtec
                                  • Dec 2008
                                  • 1967
                                  here 2 more screenshots of temp in a IPTV sports and Bad caps forum
                                  • reaper57
                                    • Sep 2014
                                    • 216
                                    • Norway
                                    Wow 55-58 average and 61 max, that's great! The phenom II in my DV6 is between 47-53 when watching video, when using the on-board graphics. Mine has a better cooler and a better thermal design and isn't that much cooler than yours. So I would say that those temps are perfect!
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      Technically memory leaks (versus memory wasting) should not cause more CPU utilization. Memory leaks means that memory that was allocated but lost all handles, which means the program has no way of accessing that memory again - so at worst that memory would eventually swap out. During swapping the CPU has to idle while waiting for the hard drive to read/write and will cool down somewhat.
                                      This is contrast to memory wasting - where a program could keep multiple tables around and even do linear searches on them - this will cause more CPU activity.
                                      Those temperatures do not look that bad. Recently I had to deal with my i7 - it was starting to beep. When I ran thermal monitoring it was hitting 90C (and was going higher - until I stopped the CPU) when I was running full blast, all four cores (8 threads) compiling for Gentoo. This wasn't normal - it had been just fine a while ago. Opened the case, used compressed air to blow out the massive amount of dust that built up on the heatsink/fan, and all is better, down to 79C or so when running full blast.
                                      • tmcw
                                        Drying Oven - Preset Temp Fail
                                        by tmcw
                                        Here's an unusual one...
                                        This is a Gallenkamp oven, used in a laboratory space, goes up to 220 Celcius, but is usually maintained at about 115 Celcius. Used for drying glassware, molecular sieves, and so on. Oven is in excess of 20 years old.
                                        It heats up fine, there is an orange light on the front that indicates that the unit is heating, and when it reaches the preset temp, the orange light goes out. All good so far.
                                        However, after the preset temp is reached, the temperature continues to rise, power to the heating elements isn't cut off.
                                        01-21-2021, 03:11 AM
                                      • foshland
                                        MSI MAG Z390 Tomahawk BIOS temp, allways at 0ºC and CPU goes protection 800Mhz
                                        by foshland
                                        Hi to all, my motherboard (bought second hand as faulty, but now working after cleaning the ram slots) have a strange failure that shows 0 Celsius degrees in BIOS, because of that, the CPU goes to protection mode and gets stuck at 800Mhz.
                                        Since its a 8-9 Intel generation, I know the CPU temp is the hottest temp of the cores (as i have read in intels documentation) so its not a diode or sensor on the board.
                                        External temperature (motherboard temp) is working OK, 27ºC more or less
                                        In windows, all the software I have tested shows correct the Core temps
                                        12-16-2023, 09:08 PM
                                      • mosfetratus
                                        concerning gtx675m vram temp
                                        by mosfetratus
                                        Is 98C vram temp are safe? Less demanding games goes 80ish.
                                        Funny thing, there were old non stock thermal pads very botched, so i replaced them. After, temperatures remained the same, but performance (fps) improved significantly. With both thermal pad application GPU core temp was similar.
                                        furmark goes about 104C, amperage keeps rising so do temps.
                                        01-30-2025, 08:41 AM
                                      • tvguy12012012120
                                        Samsung UN55NU6900F Standyby voltage is 1V higher than expected, is this a problem?
                                        by tvguy12012012120
                                        This is the zombie UN55NU6900F I wrote about in this original post.
                                        It originally was completely dead with no standby voltage. After some poking around, I found the solder at RM819 (see pictures) failed. I removed it from the board, it tested fine, resoldered it, and now the TV works.
                                        The expected standby voltage at the reference pin is specified to be 11.8V but it's reading 12.8V. Couple questions:
                                        1. What could cause the standby voltage to be 1V higher than expected
                                        2. Is this a problem
                                        3. Could it have led to the failure at RM819, or was that...
                                        02-12-2025, 11:22 AM
                                      • m1ch43lzm
                                        by m1ch43lzm
                                        05-12-2025, 08:37 PM
