Hello. Does anyone know which programmer supports the MXIC HX77L25650FM142 chip? I am using an XGecu TL866 II Plus, but it does not read this chip. It comes from a 12th Gen Dell 3460 PC
Bios programmer
Tags: None
that chip is locked in 4bit (quad i/o) mode from the factory,
most programmers only program serial-flash in 1bit mode.
a T56 or T76 can probably do it.
i had a similar issue fixing an MSI motherboard and a T56 got it done.
try running your software without the programmer and put the demo-mode to T56, then see if the part is listed.
T56 & T76 lists MX77L25650F @SOIC16 in it's docs
Select MX25L25635F or MX25L25673G and uncheck "ID check" , you`ll be able to read/write to it then.Comment
You can still use the regular 1 bit SPI commands to read/write even when QE bit is set
Andromedus_81 you can also add the chip ID C27519 to the database, using MX25L25673E as a template (C22019)
Select MX25L25673G, then press +Add button, change the name and the chip ID (C2 20 19 to C2 75 19)
MX77L25650F is on the T48 database by the way, they just didn't add it to the TL866II Plus databaseComment
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by ArzigolHello everyone!
I am looking for experienced BIOS modders who can help analyze or unlock the BIOS of my Acer Nitro Lite 16 NL16-71G.
Please note that this post was written with the help of ChatGPT because my English is limited. My native language is Russian. If anything is unclear, please let me know and I will do my best to explain.
Laptop Information
Model:
Motherboard:
CTE_NB_NL160P1G_RTH (NB6807C)
CPU:
Intel...-
by zlr8rlooking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
cheers
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
MOBO: RO 15 17 WHL 2GB MB / 18706-2
Attached;
1. My saved bios using a programmer
2. Dells Bios updater .exe (v1.16)
3. Dells Bios recovery file
4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
5. Image of ME...-
- Loading...
