VirtualBox
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    VirtualBox
    http://www.virtualbox.org/
    Its a virtualization platform. Currently checking it out with fedora6 guest winxp host. Looks good.
  • gonzo0815
    • Feb 2006
    • 1600
    Re: VirtualBox
    How fast is it? from my experience, MS virtually PC was the fastest x86 emu i had been running compared with VMware (comparing a emulated Red Hat linux on w2k host using Virtual PC with Red Hat host running emulated w2k with VMware).
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: VirtualBox
      i have no idea. not tried other virtual hosts.
      it took all afternoon to get the guest additions installed.
      finally i was having FC6 bug where .586 kernel was installed not .686
      then manually edit xorg.conf and finally get 1280x1024 res..........
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: VirtualBox
        now i wanna do this again and i forgot uuuuuuuh
        • ivtec
          install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
          by ivtec
          Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
          01-17-2025, 12:54 PM
        • Faber88
          R9 290x GPU Dead?
          by Faber88
          Hi everyone, just got a R9 290x. I checked the main rails and seemed the resistances were present, then I connected it to the test bench and found 12v - 5V - 3.3V - 1.8V - 0.8V present. Forgot to mention the card was probably water cooled, came as you see in the picture with some coating probably to protect the components from condense (?) I am not an expert. Anyway no image is shown and apparently not even the System is booting. When the system is booting usually my keyboard light up but it does not when the card is on. Tried to not connect the two 8 pins or to connect only one, the system seems...
          11-12-2022, 02:47 PM
        • RWS93
          Apple A1990 / Board number: 820-01041
          by RWS93
          Brand: Apple
          Model: A1990
          Problem: I am not an Apple kind of guy to start with. But I am quite experienced with motherboard repairs in general. So the laptop is stuck with 5v 0.250A and does not negotiate 20v. Same symptom on all 4 USB C ports. When charger is plugged the amps start at around 0.060 then go trough: 0.100 - 0.180 - 0.230 - 0.244 and stay like this. Laptop responds to the power button: once I hold it long enough current goes down to 0.060A and then up to previous levels.
          Board clean, no liquid damage, no corrosion....
          04-11-2024, 03:43 PM
        • Dreigas
          Laptop, Bios and some phones schematic database
          by Dreigas
          About a year ago, I was struggling to find schematics whenever I needed them. As a programmer, I saw an opportunity and wrote a few scripts to automatically gather a large database of them. Today, I've decided to share it with everyone, because good things should be accessible to all.
          What's included? Over 14,000 laptop schematics, as well as some BIOS files, and about 1,000 phone schematics.
          Everything is compressed in a RAR format and is over 140 GB. (Since it's such a large file, your browser might show a warning.)
          I plan to host the...
          08-20-2025, 09:58 AM
        • electronx
          Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
          by electronx
          I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
          1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
          According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
          If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
          06-26-2025, 03:27 AM
