Dell Poweredge score
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Yup, here comes yet another ratdude pictorial. Grab your popcorn, as this one is fun! (aren't they all?).
    Today's guest is a Dell Poweege 830 Pedistal server:
    ...That I bought for $20:
    The good news: It inluded the keys for the lock. The bad news: it's is less than complete condition (mostly there)
    It had 3 of the four HDDs with it:
    I haven't tested them yet but presumably they're good (unlike the drives in my parents file server, which this machine will replace). OT: If you have a drive similar to these you'd like to get rid of (trade/sell), PM me, as I may try to get a 4th drive and caddy (although I may just RAID 5 it and call it a day).
    If those drives are stock, for a late model P4/Pentium D this system is awful new; as we'll see the RAID card is somewhat recent too.
    It originally ran Server 2003:
    The inside was, well, a mess:
    Everything is there, minus the Raid's BBU (which probably was never there but at $15 a pop Genuine used, I'll snare one) and some (I2C?) 5 or so wire cable between the SAS caddy and the card it's all there; It will need a new CPU latch (as one is busted, hence why the heatsink is on the ground)... Oh, and I totally dig the latched ribbon connections. Not even Supermicro and Tyan go that far! (although ususally there isn't room).
    The CPU is a Pentium 4 630 (prescott 2M HT 3.0GHz) and it has a measly 1GB of DDR2 RAM. I have a 3.2GHZ version in the current file server (a repurposed emachine) and I have 8GB of ECC DDR2 (which supposedly is compatible) sitting that I may toss in... the RAM may be overkill for a file server though.
    It had a couple kickass cards:
    That's an LSISAS1068 SAS card... no BBU. I hear it's pretty spiffy though (shame it's using 72K drives)... 256M of RAM (ECC DDR2). I have a 512MB DDR2 module of the same type somewhere... good idea to swap?
    And then there is the SCSI host card:
    I have NO use for such a thing... but holy cow. Monster of a card (not HW raid though, I bet those are real monsters).
    It wouldn't be a BCN post without a bad cap:
    3 KZJ's, one blown. And it had to be a size/voltage/value combo I don't happen to have in my stash... and since I have to order stuff anyway, I'm not gonna hack in an 8mm.
    Regarding the missing cable, the connectors are:
    The PSU is a beast:
    Score?
    Questions:
    1. I'll probably just get a replacement heatsink clamp... but if you know of any better compatible coolers, say so.
    2. I'll probably do a fresh install of the OS (rather than clone my old install) and merge the specifically tweaked config files. Any suggestions on a headless (no GUI) linux distro? I was on Debian and it ran pretty well... I mostly use arch but IMHO that's too bleeding edge for this (too many updates).
    sigpic
    (Insert witty quote here)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Dell Poweredge score
    not bad for 20 bones!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Yeah, once I get caps (check your PM) and the CPU latch (and BBU batt) It will be trucking.
      Best part is it may become free since it will become my parents print and file server... I know, she's overkill x100... I could almost web host on the thing. Nah, If I wanted to do that I'd get out my two K8W's in the junker pile ("unusuable" AGP bridges of doom).
      sigpic
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        The I2C cable is unobtanium... as it seems the SAS option was a bit rare.
        It's a longer one of these:
        http://www.ebay.com/itm/Genuine-Dell...item4d17cbb618
        Which I will buy and splice extensions on since NOBODY has the stock version of. The backplane's connector shell was almost completely ripped off the pins when I got it, so I bet the old cable was ripped and tossed.
        Oddly enough I also found a 100% unused Dell audio to HDA cable... may be good to have if for whatever reason I put a HDA compatible card in a dell.
        sigpic
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Ended up ordering this:
          http://www.ebay.com/itm/131352503791...%3AMEBIDX%3AIT
          which happens to have the also unobtainium heatsink mounts and I2C cable. The extra CPU upgrade and a spare board is icing on the cake.
          sigpic
          • Compgeke
            • Feb 2014
            • 524
            Looks a lot like you have a PERC 5/i. Quite a nice card for how cheap they are, I have one here and a PERC 6/i in my Poweredge 2950.
            One nice thing is the ram is upgradable and you might be able to flash LSI firmware to it, people seem to argue on whether it works. If you ever end up pulling it out of the system you can also get adapters to use it without a backplane (SATA breakout cable).
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              ^Nah, I'll just up the RAM and see if I can flash the firmware.
              From what I can tell SAS wasn't an option on the 830; this one is a hodge podge of two different systems (hence why the hotswap module has chassis mount). It's possible that that's why i couldn't obtain the correct cable either. Looks like I'll have to make my own cable and hope it works.
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Well Shit. Potential bad news about the RAID Card
                From what I'm reading since it's a dell card linux may not be compatible... hopefully it is w/o a bucnh of firmware hacking bull pucky (it's not even SAS per se). Also, the RAM is not upgradeable; even if it accepts an upgrade it will only use the 256MB it was designed for.
                Worst case I whack in my 3ware 9500 and make a SATA adapter for the backplane power cable (and ditch the backplane all together).
                sigpic
                  • 31090
                  change the firmware on the card with uniflash.
                  • blasterboomer
                    • Dec 2013
                    • 135
                    • United Kingdom
                    I got a poweredge 1950 off ebay for £80 with 2 quad core xeons, 4gb ddr2, both psus... added 6gb extra ram to it for a total of 10GB installed 2 1tb sata drives and now use it as a webserver... I need more ram though, was hoping to get atleast 2 8gb sticks for it
                    • Compgeke
                      • Feb 2014
                      • 524
                      Unless it's a weird one I've used both a Perc 5/i and 6/i under Linux and never had issues. Which specific card is this one anyways?
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        perc 5/i.
                        If it works, then sweet... this will be a kickass build then.
                        In a trade for the server, I get from my parents $145 in Black Friday Harbor Freight stuff: Flux core welder, Auto-adjust helmet, and a 40 pack of shop towels (although I think that has more to do with that my mom doesn't want to wash my dirty ones ).
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Board #2 came in yesterday
                          Oddly the caps in question were NOT KZJ's... but 3 470uf 16V;s WERE... and on top of that week 50 2005 HM's (those OK?)
                          sigpic
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            Yes, they will be fine.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              ^thought so, since it was that late in the year.
                              sigpic
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                I doubt I'm going find a deal like that at WinCycle.
                                ASRock B550 PG Velocita
                                Ryzen 9 "Vermeer" 5900X
                                Arc A770 16 GB
                                eVGA Supernova G3 750W
                                Alienware AW3423DWF OLED
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Although it's taking another ~$40 to get it to running condition (and some I2C wire mods). Still, she'll be a nice one... First one to have hotswap drives even.
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Built it up last night, man it is bitchy about RAM.
                                    Only likes 1 Rank ECC DDR2, beeps at 2 rank or non-ecc.
                                    and one of the two included modules was DEAD... looks like i'm buying more RAM. Fucker.
                                    sigpic
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      Ordered 4 of these:
                                      http://www.ebay.com/itm/1gb-PC2-3200...item4d28999d35
                                      Hopefully that fixes it... and once again I have 8GB of ECC 2 rank RAM that I can't do shit with.
                                      sigpic
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        Possibly the same type of issue my Dell Inspiron 530S has, where the slots have trouble keeping the RAM modules aligned.
                                        (Simply moving the case can cause that issue. Don't you hate that?!)
                                        Arc A770 16 GB
                                        • omega
                                          Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                                          by omega
                                          Hello all,
                                          as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                                          Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                                          02-09-2024, 03:34 PM
                                          by momaka
                                          03-12-2025, 03:42 PM
                                          HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                                          This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                                          09-06-2024, 11:39 AM
                                        • harp
                                          Comparing FreeNAS, FTP server, SMB server, multimedia server...
                                          by harp
                                          I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
                                          I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
                                          Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
                                          What is general difference between this products, and what be most useful...
                                          01-04-2024, 02:44 PM
                                        • Fireballcz
                                          Windows 2016 server L2TP/IPsec VPN - two subnets
                                          by Fireballcz
                                          Hello, please how to properly configure VPN in this environment?
                                          I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
                                          Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
                                          2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
                                          I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
                                          I have no problems with VPN connection...
                                          07-29-2022, 03:20 AM
