Panasonic toughbook vs Compuke presario cq57
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    tell me this: why is a toghbook from 2008 faster than a presarion cq57 from 2011? the CPU is the same clock speed, both are duel core, both use the same SSD, same OS install, etc.
    the presario takes 56 seconds to boot and the toughbook 10 seconds. whats going on here? is compuke that much crap?
    Follow the white rabbit.
  • lti
    • May 2011
    • 2553
    Re: Panasonic toughbook vs Compuke presario cq57
    I wondered the same thing when I got my Toshiba laptop, although the difference in performance wasn't as bad as what you're seeing. I can only guess that the newer low-end hardware really is that bad, and benchmarks are designed to give newer hardware higher scores to try to sell more new computers. I don't think it's actually the manufacturer of the computer or its hardware (the Compaq is probably made by Quanta, just like my Toshiba).
    What CPUs do they have? Did you make sure the SATA controller is in AHCI mode? Does the Compaq still have its factory OS image? How much RAM do they have?
      • 31086
      ramspeed? bus speed? slow bios?
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        ramspeed is the same 5300, both controllers were in AHCI mode and boot time is measured from the time I tapped enter at the GRUB menu.
        both have 4gb of ram, the compaq has an AMD a300 apu and toughbook has an Intel centrino duo.
        both have the same (cloned) opensuse 13.2 install, then to push things further in favor of the compuke the image was installed on it then cloned to the toughbook.
          • 31086
          Linux - good.
          disable any graphic loader and boot in framebuffer mode.
          then watch the boot text.
          unless it's just generally slower on one - which may be a drive-interface settings issue, it may be hanging for a while probing something on the board.
          one of my machines does that probing the ide bus - it may be trying different ata modes to find slow devices.
          (i dont have any, but it may still be looking)
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            Linux - good.
            the compuke died. no boot. thats why i have the toughbook now.
            • Compgeke
              • Feb 2014
              • 524
              Clock speed isn't everything. There's also the cache, core, bus speed, instructions ecc.
              Something like a 2 GHz Core 2 Duo will usually be faster than a 2.8 GHz Pentium D simply from the processor design - it's a lot more efficient.
              Looking at the two, the CQ57 has an AMD E300 or E350 or other similar chip which is a low-end budget processor. Fairly slow honestly but they're made to be as cheap as possible.
              The Toughbook most likely has a Core 2 Duo chip. The Core 2 Duos were made to be mid to high end for their time and as such are generally going to be faster than any low end AMD currently. The Haswell Celerons are starting to out perform the original C2D Mobile chips but AMD isn't.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                the panny has centrino duo. IIRC it has a long architecture much like a P4, but from the era of C2Ds obviously. and yeah, the AMD in the compuke is a E300.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  centrino duo just means a dual core intel with intel wifi and chipset.
                  IIRC that was the moinker used for core duo's with the centrino platform... but C2D's may have also been covered (I've seen them on i945 chipsetted systems, which were both).
                  sigpic
                  (Insert witty quote here)
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    So I remembered wrong.... It has Intel WiFi and Bluetooth.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      I have a thread where a CQ61 failed. It appears to have LEDs that blink once every certain amount of seconds.
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • c_hegge
                        • Sep 2009
                        • 5219
                        The AMD APU in the Compaq explains the slowness. They are absolutely hopeless performers. An older C2D like in the Toughbook will easily outperform it.
                        That's right. The Centrino name for the CPUs went on thoughout the C2D era and was only dropped with the introduction if the Core i_
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          The E300 is very, very, very slow as a CPU. Clock speed isn't everything. It does have a fairly capable graphics core though.
                          A working TV? How boring!
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Originally posted by th3_un1qu3
                            the e300 is very, very, very slow as a cpu. Clock speed isn't everything. It does have a fairly capable graphics core though.
                            qft
                            Arc A770 16 GB
                            • goontron
                              5000!
                              • Dec 2011
                              • 4108
                              • US
                              qft
                              noted.
                              • venkatrao
                                • 7
                                • india
                                help me bios presario cq57
                                • Compgeke
                                  • Feb 2014
                                  • 524
                                  Can you be a bit more specific? Are you trying to flash to a newer version? Change some setting? Get into it?
                                  A new thread would probably help you better anyways.
                                    HP Compaq Presario CQ57-497SG CQ57 Specification for Upgrade or Repair
                                    This specification for the HP Compaq Presario CQ57-497SG can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the CQ57-497SG boardview and CQ57-497SG schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                    09-06-2024, 05:27 AM
                                  • aa10aa10
                                    Panasonic Toughbook CF-33 mk1 BIOS repair
                                    by aa10aa10
                                    Good day,
                                    I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                    I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                    01-21-2025, 06:13 AM
                                    HP Compaq Presario CQ57 Laptop Schematic
                                    HP Compaq Presario CQ57 Laptop Schematic...
                                    10-14-2024, 06:38 AM
                                  • eukal
                                    Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
                                    by eukal
                                    Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
                                    I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
                                    I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
                                    I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
                                    07-01-2023, 01:00 PM
                                  • Nedim Merdan
                                    Panasonic toughbook CF-D1DW200FZ motherboard DL3UP1969CAA schematic
                                    by Nedim Merdan
                                    Does anyone have the schematic for toughbook cf-d1 mk1 motherboard model is DL3UP1969CAA thanks in advance
                                    12-07-2024, 02:22 PM
