Goontrons main (AMD) rig V3
    • 31154
    Re: Goontrons main (AMD) rig V3
    no, they are the ones that keep asking for a security smartcard or password to boot.
    the intel chipset needs a heatsink, but they designed it wih the wifi card going over the chip before they realised it.
    so they bodged it by sticking a sheet of thick ally foil over the chip - then fitting the wifi card.
    the result is it lasts about as long as a european warranty, then the soldering fails.
    you have to remove the wifi, and the foil.
    then reflow the chip and bond a real heatsink to it.
    obviously the space for the wifi is then gone.
    • luke10050
      • Mar 2013
      • 209
      Originally posted by c_hegge
      The CPUs themselves are rarely the problem. The real problem is that, when the manufacturer goes cheap on the CPU, they naturally cheap out elsewhere too, including on the motherboard.
      What I really hate is the E series APUs. I have an ASUS laptop with an E-350 APU right next to me now which I am fixing for a customer. I can't believe anyone would put up with a PC this sluggish. Then again, the Intel Bay Trail based Celerons (N2806 for instance) aren't much better.
      hey, i love my dell inspiron 1122 (m102z) i was silly enough in 2012 to buy a $900 pc based around an amd e-350, it did have a half-a-day battery life though (and still does). Honestly, they are good for a 11.6" notebook with a fast drive and a decent amount of ram, i only bought it as it was relatively light (if only i had known about lenovo x series back then).
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Re: Goontrons main (intel) rig V3
        Originally posted by stj
        you obviously never had any HP NC62xx series laptops then.
        the only fix is a reflow, a custom heatsink and losing the wifi.
        I know the Nc6000's were plagued with max1986 chips of doom... I got a dead one to part many moons ago (I was lucky, it had a 1gb DDR module in it!)
        sigpic
        (Insert witty quote here)
          • 31154
          max1986 chips?
          what's that about?
          the problem i know is with the main large intel bga.
          i got a dead one with 4gig of ram and a 1.7ghz cpu for free btw just needed a drive.
          (and a reflow)
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            max1986 chips?
            what's that about?
            (and a reflow)
            Some weird IC that was failure prone... and would cause a no-POST condition. A new chip would last only as long as the old one did too.
            dit- it's the max1987 chip, not 1986. bad memory over here.
            sigpic
            • blasterboomer
              • Dec 2013
              • 135
              • United Kingdom
              #26
              whats this about the AMD chips being defective? ive never heard of this... although i mainly use intel, my server uses an AMD FX6300
              • c_hegge
                • Sep 2009
                • 5219
                A netbook, maybe. But there's no excuse under the sun for using the E series in a full sized 15.6" laptop. You can easily fit a bigger chip in there, and, unless you really strip windows 7 back (like in the starter edition bundled with netbooks), or run XP, they are horribly slow.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  #28
                  Not the chips. The position in which they were fitted in. On the NC6000 motherboard, the MAX1987 controlling the CPU Vcore, is very very close to the edge of the board, and there's a screw right next to it. If you move the notebook a lot, the connections to the MAX1987 will break due to board flexing. It's a design flaw of this particular notebook.
                  Last month I had a NC6000 in for servicing with several issues (no sound/no touchpad/random no POST). The sound was due to a broken headphone jack, the touchpad ribbon had shorted out due to someone's negligence (could have actually been my own, last year when i cleaned it), and the no POST was the MAX1987.
                  All i did was redo the soldering on the MAX1987 and all was fine. And you know, it's around 9 years old. I'd say it held up fine.
                  A working TV? How boring!
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Funny, redoing mine had no effect. Odd. The laptop is history now.
                    sigpic
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      #30
                      well, you thought the Quantum would be the oldest thing on this computer? no, im now using an IBM model M keyboard.
                      Follow the white rabbit.
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        #31
                        I approve the Model M keyboard upgrade
                        I have one as well, but I prefer my Dell QuietKey since it has a Windows and menu keys.
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          #32
                          the superkey on my system is ALT, so i have no need for a windows key.
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Phenom Is, whose numbers end in "00" have a defect.
                            OTOH, I'm happy with my FX 8350!
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • DynaxSC
                              ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                              by DynaxSC
                              I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                              Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                              Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                              The behaviour is also really very strange, i.e.:
                              • The disk shows always up in BIOS - so it is recognized, so far so good
                              • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                              02-23-2025, 01:33 PM
                            • welp
                              PS5 Disk Tray issues.
                              by welp
                              I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
                              Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
                              Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
                              So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
                              With that knowledge I preceded to check all the fuses for the 12v rail on the main...
                              12-19-2024, 02:04 PM
                            • chth96
                              LG GCC-4521B cannot read any disk
                              by chth96
                              I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
                              But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
                              And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
                              But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
                              02-13-2024, 07:31 AM
                            • madura2010
                              DAY11AM6E0 hard disk drive and optical disk drive not detected
                              by madura2010
                              Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                              i checked the connectivity of ribbon=good communication with hard and motherboard
                              changed hard disk and checked=3f0 error persist
                              sata power=+5v available
                              Then checked data capacitors=all good
                              Then checked data lines path connectivity to pch=all good
                              reflashed...
                              03-12-2023, 09:09 AM
                            • SuperAman
                              PS5 EDM-010 3 Beeps
                              by SuperAman
                              Getting 3 beeps only when console is plugged into power, no lights. I was thinking a possible NOR issue but the uart codes are leading to something possibly more serious? EDM-010 disk edition. I didn't try clearing the error codes yet, wanted to backup the NOR first, CH341A programmer comes tomorrow.
                              Error code: 80810001
                              Description: General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
                              Error code: C00C0002
                              Description: VRM Controller Failure, Check Mosfet (6414A) Located Side-A, Below Sony Interactive Entertainment Inc. Check Infineon XDPE14286A...
                              09-06-2025, 08:25 PM
