Goontrons main (AMD) rig V3
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    follow up of my thread here: https://www.badcaps.net/forum/showthread.php?t=41099
    got my new rig built up and running. its a nice unit with a 4 core AMD phenom at the same clock as my old Pentium (left in the) D(ust). it has RAID and hot swapping drive controllers, and the all important IDE port for my quantum bigfoot. now with Se7en pro installed it also had a graphics card installed and has a 400w Delta PSU.
    Code:
    *-cpu
         description: CPU
         product: AMD Phenom(tm) 9500 Quad-Core Processor
         vendor: Advanced Micro Devices [AMD]
         physical id: 4
         bus info: cpu@0
         version: AMD Phenom(tm) 9500 Quad-Core Processor
         serial: To Be Filled By O.E.M.
         slot: AM2
         capacity: 2800MHz
      *-memory
         description: System Memory
         physical id: 10
         slot: System board or motherboard
    *-display
            description: VGA compatible controller
            product: G80 [GeForce 8800 GTX]
            vendor: NVIDIA Corporation
            physical id: 0
            bus info: pci@0000:01:00.0
            version: a2
            width: 64 bits
    *-network
            description: Ethernet interface
            product: 88E8071 PCI-E Gigabit Ethernet Controller
            vendor: Marvell Technology Group Ltd.
            physical id: 0
            bus info: pci@0000:02:00.0
            logical name: enp2s0
            version: 16
            serial: 00:1f:e2:3c:1e:e6
            capacity: 1GB/s
            width: 64 bits
    *-multimedia
           description: Audio device
           product: SBx00 Azalia (Intel HDA)
           vendor: Advanced Micro Devices, Inc. [AMD/ATI]
           physical id: 14.2
           bus info: pci@0000:00:14.2
           version: 00
           width: 64 bits
    *-disk
           description: SCSI Disk
           product: WDC WD2500AAKX-0
           vendor: ATA
           physical id: 0.0.0
           bus info: scsi@0:0.0.0
           logical name: /dev/sda
           version: 1H15
           serial: WD-WCC2EXU90098
           capabilities: partitioned partitioned:dos
    *-disk
           product: ST31000528AS
           vendor: ATA
           physical id: 0.0.0
           bus info: scsi@2:0.0.0
           logical name: /dev/sdc
           version: CC46
           serial: 5VP96BRN
           capabilities: gpt-1.00 partitioned partitioned:gpt
    *-disk
           product: QUANTUM BIGFOOT
           vendor: ATA
           physical id: 0.0.0
           bus info: scsi@7:0.0.0
           logical name: /dev/sdd
           version: 0G00
           serial: 382900626224
    i replaced the stock CPU cooler with one from arctic. i got for free since the fan was dead, and mind you the unit didn't even touch a CPU, it still had the layer of compound that the factory puts on the copper surface. a dell tornado fan was put on in replacement.
    the main OS is OpenSUSE Tumbleweed running from the WD.
    Follow the white rabbit.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Goontrons main (intel) rig V3
    Code:
    *-cpu
         description: CPU
         physical id: 4
         bus info: cpu@0
         slot: AM2
         capacity: 2800MHz
      *-memory
         physical id: 10
    *-display
            physical id: 0
            version: a2
            width: 64 bits
    *-network
            physical id: 0
            version: 16
            capacity: 1GB/s
            width: 64 bits
    *-multimedia
           physical id: 14.2
           version: 00
           width: 64 bits
    *-disk
           vendor: ATA
           physical id: 0.0.0
           version: 1H15
    *-disk
           vendor: ATA
           physical id: 0.0.0
           version: CC46
           serial: 5VP96BRN
    *-disk
           vendor: ATA
           physical id: 0.0.0
           version: 0G00
    Replace that Phenom with a 9550 (or any that ends in "50") because of an AMD F-up. They're defective!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      ....and turn that sorry excuse of a quantum bigfoot into scrap aluminum....
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Sparkey55
        • Jan 2010
        • 1523
        Get a Deathstar. Go out in a big bang.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          BIOS is patched. as for the quantum: i love the sound of it when Windows does what it does best, thrashes the disk
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            They sound like any old slow HDD....sounds like gravel in a coffee can....
            Team : 49813
            Join in!!
            Team Stats
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              no, bigfoots have a distinct sound, rocks in a coffee grinder inside a tin box.
              • c_hegge
                • Sep 2009
                • 5219
                erm, why does the title of the thread suggest this is an Intel rig?
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  intel, as in the architecture. x86. if you want to fix that go right ahead.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    It's not a BIOS bug. It's a defect and AMD pretty much recalled them.
                    Arc A770 16 GB
                      master hoarder
                      • May 2008
                      • 12175
                      Nice enjoyable upgrade in performance, yes?
                      Although, IMO Pentium D is not all that bad. The long architecture and all makes it still handle flash and video encoding/decoding well. Just not very efficient due to high clock speed (for those times) combined with the relatively large manufacturing process (what was it, 90 nm?).
                      Yeah, please don't remind me .
                      Those Bigfoots make my 5400 RPM IBM Deskstar 305030 seem like some sci-fi alien technology.
                      Last time I tried to install Windows XP on my 3.2 GB Bigfoot, it took over 2 hours for the setup to finish. No, HDD was NOT set to PIO mode, although it could have been dropping into it due to bad sectors. All I remember is that every now and then, the HDD would make a click-click-beep sound (i.e. sector reallocation), and then go back to normal "rocks in a coffee grinder inside a tin box" trashing operation .
                      Ugh what a slow turd
                      The only thing I find interesting about that HDD is that on the back, there is a hole and a clear sticker on top of it, through which you can see the top (or bottom?) platter and arm for one of the heads. As the HDD initializes, you can see the arm move in a very cool pattern - which is what makes that unique initialization sound of the Bigfoot.
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        Let's face it, AMD makes inefficient unreliable products. Can't fix that as easy as you can fix a thread title! lol
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          TBH there may be a reason most of my operational computer crap is intel (minus my main rig which is twin Operons)... AMD doesn't make junk but for the most part, at least since the core2, intel has made good, solid products.
                          sigpic
                          (Insert witty quote here)
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            tbh there may be a reason most of my operational computer crap is intel (minus my main rig which is twin operons)... Amd doesn't make junk but for the most part, at least since the core2, intel has made good, solid products.
                            +1
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16956
                              IMO, AMD's entry level stuff is very inferior to Intel's equivalent. Opteron stuff, yes sir, I'll rock 'em!
                              Team : 49813
                              Join in!!
                              Team Stats
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                Most definitely! I barely ever see an Intel laptop at work with a bad motherboard. If it is Intel it's an older nVidia one. Just yesterday I diagnosed bad motherboard on a Toshiba that was still under the original 1 year warranty! Yeah, AMD is that bad, and they still haven't fixed their crap.
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  ^ honestly Sun/oracle SPARC could kick intel or AMDs ass anyday.
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    Re: Goontrons main (AMD) rig V3
                                    The CPUs themselves are rarely the problem. The real problem is that, when the manufacturer goes cheap on the CPU, they naturally cheap out elsewhere too, including on the motherboard.
                                    What I really hate is the E series APUs. I have an ASUS laptop with an E-350 APU right next to me now which I am fixing for a customer. I can't believe anyone would put up with a PC this sluggish. Then again, the Intel Bay Trail based Celerons (N2806 for instance) aren't much better.
                                      • 31019
                                      you obviously never had any HP NC62xx series laptops then.
                                      the only fix is a reflow, a custom heatsink and losing the wifi.
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        Let me guess, they're the ones that BSOD at stock clocks without a cooling mat. (Even though that's not normal to have a crash, even at 90 C, when not overclocking)
                                        (and shut downs)
                                        Arc A770 16 GB
                                        • DynaxSC
                                          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                          by DynaxSC
                                          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                          The behaviour is also really very strange, i.e.:
                                          • The disk shows always up in BIOS - so it is recognized, so far so good
                                          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                          02-23-2025, 01:33 PM
                                        • welp
                                          PS5 Disk Tray issues.
                                          by welp
                                          I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
                                          Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
                                          Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
                                          So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
                                          With that knowledge I preceded to check all the fuses for the 12v rail on the main...
                                          12-19-2024, 02:04 PM
                                        • madura2010
                                          DAY11AM6E0 hard disk drive and optical disk drive not detected
                                          by madura2010
                                          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                          i checked the connectivity of ribbon=good communication with hard and motherboard
                                          changed hard disk and checked=3f0 error persist
                                          sata power=+5v available
                                          Then checked data capacitors=all good
                                          Then checked data lines path connectivity to pch=all good
                                          reflashed...
                                          03-12-2023, 09:09 AM
                                        • chth96
                                          LG GCC-4521B cannot read any disk
                                          by chth96
                                          I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
                                          But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
                                          And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
                                          But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
                                          02-13-2024, 07:31 AM
                                        • Eleways
                                          Apple Macbook A1707 Hard disk
                                          by Eleways
                                          Hi
                                          I've an Apple macbook A1707 with Hdd defect.
                                          This product don't work with a normal Hard disk, but the hard disk it's a BGA component on the logic board.
                                          My question is:
                                          Can i exchange the hard disk, by desolder the bga Hard disk and replacing this?
                                          Can i replace with a different one (es 500 gb instead of 250 gb)
                                          This Macbook has T1 security check.
                                          Thanks and best regards
                                          Luca
                                          02-18-2022, 04:23 AM
