My Gigabyte B650 chipset motherboard came with two wireless antennas, and due to the mechanical force of the back of the desktop computer rubbing against a wall, they have broken. Ordered a replacement pair of antennas and they physically do not fit for two reasons, 1) because the new antennas are male and so are the outputs from the motherboard, and 2) because the new antennas I ordered have (male) RP-TNC connectors, which I learned (too late) are "reverse polarity" as well as being "TNC", and the output connectors on the motherboard are SMB? (I think. Whatever is standard.)
I like the new antennas because they are very long, and I assume that means they can pick up more RF, and read something about "patterns". I searched for an adapter or cable to go from SMB (male) to RP-TNC (male) but couldn't find anything. With a 2 ft. adapter cable I could fasten the antennas to the wall and that would work very nice; getting them away from the back of the desktop so they don't get damaged also.
I've already spent $25.00 in two failed attempts at replacing these antennas cheaply (there are two) and so now I have decided to learn what I'm doing before spending any more money. I have a lot of questions now.
as for the cable type if one is specified or if they let u choose, rg60 is better than rg58 to reduce losses in the cable like stj warned but since its only a short run of a few feet, (2 ft like u said) it shouldnt matter. even better, try to get tnc female to right angle 90° rp-sma male adapter cable to avoid the cables getting mangled again from being squished up against the wall but if something else sticks out of the io backplate or chassis, the right angled cable will get in the way and it wont fit. u have to do all the necessary measurements yourself as thats the limit for remote assistance via the internet as we dont have the physical cable, case, motherboard etc. to check for u.
