I'm trapped in a time warp!
  • pentium
    • Mar 2006
    • 2778
    Just today I had two systems reset themselves to November 12 in the year 2094, 5:15 in the afternoon.
    One was my armada 1700 and the other was my NeXT white box system which had a pentium cpu.
    What the heck is going on?
    Find Nedry!
    Check the Vending machines!!
  • Spacedye69
    • Nov 2005
    • 698
    • US
    Re: I'm trapped in a time warp!
    Check your foil helmet for pinholes...
    • pentium
      • Mar 2006
      • 2778
      *Checks helmet*
      No holes.
      If this is the Y2K bug it's seven years (almost eight) too late.
      Find Nedry!
      • titomno2
        Gaming Laptop Zephyrus S17 TFT not detected every time !
        by titomno2
        Hi guys,
        I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
        So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
        On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
        Then the screen won't work for a long period of time.
        If I wait 1 or 2 hours it work again most of the time.
        When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
        01-19-2025, 08:27 AM
      • flat-earther
        Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
        by flat-earther
        I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
        To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
        I have opened the camera and I think there is enough room to add something inside to accomplish this:
        The camera is powered by a 3.7V nominal single cell lithium ion battery.
        So I need to connect another battery in...
        06-08-2025, 02:00 AM
      • OscarAV
        HP Pavilion dm4-1065dx long time to get the power led on
        by OscarAV
        I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
        I have made a quick search for my laptop but I have not seen anything similar.
        I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
        09-23-2024, 05:53 PM
      • BigOof
        Pioneer RM-07 Active monitors cutting out from time to time
        by BigOof
        I have a pair of Pioneer RM-07 monitors that I bought a while ago. When I was testing them I noticed that one speaker would cut out and I thought it was just a bad cable connection. At the price they were being sold for I was willing to take a risk on them. However, 6 months later and the one monitor still has the same issue. Most of the time it works, but there are times that the power LED is on but I get absolutely no sound. I can hear the relay clicking on/off sometimes and then it will/won't work depending on what it feels like. I've tried XLR and RCA inputs with the same issue. There's no...
        12-18-2024, 04:35 AM
      • nieljosiah
        HP Notebook - 15-ba017ax (LA-D711P Motherboard) turns off randomly after some time
        by nieljosiah
        I've had this laptop for 8-9 years, and about a week back, it started malfunctioning. When I press the power button, the power LED comes on for about 5secs and turns off. The fan also doesn't spin at all during this time. But, if I press the power button, and then manually spin the fan, the laptop boots up and the fan starts spinning on its own. Even if I do this, and the laptop boots up, it turns off (hard shutdown) after some time between 10secs and 1hour randomly. I've tried checking the fan voltage and it's at zero volts when I press the power button without spinning it, but when I spin the...
        08-17-2024, 02:19 AM
