Bent and broken CPU pins
  • sparker1
    • Sep 2011
    • 359
    Hello, I have a motherboard that I somehow crushed a bunch of CPU pins on an LGA1200 CPU socket. I am only at hobby skill level for soldering etc but I want to try and repair the board. Is it easier to replace individual pins or the whole socket? I have seen a few youtube videos and people seem to have more success replacing pins than the whole socket. I don't have a BGA fancy heater but have a decent hot air station and a makeshift bottom heater. Any thoughts?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5401
    • New Zealand
    • Electronics and computer repair
    I haven't done any BGA work at all, but I imagine replacing individual pins may well be easier assuming they can be released from the socket assembly somehow, which seems like an interesting concept.
    Do you have a link to any videos showing this?
    I guess you can watch the videos and try to follow along. Does your heater have temperature or power control of any kind? You will need it so you don't overheat the board and melt/warp the socket.
    However you try, I think you should definitely practice on something else first. The risk of ruining the board on a first attempt is high.
    -David VanHorn
    • sparker1
      • Sep 2011
      • 359
      Hi Agent24, I tried removing pins from a donor board and it was very difficult for me. This guy makes it look easy. https://www.youtube.com/watch?v=mUzc...1GMeS&index=59
      • eccerr0r
        Heat sink plastic pins (intel specific) cracking? Just fakes?
        by eccerr0r
        I'm not sure if this is still pervasive but back in the Socket 775 and on towards a lot of the 115x series, Intel heatsink fans used those nasty to set pin-in-hole retention systems to hold the heatsink on the motherboard. Not only there's a potential to bend and crack the motherboard, I've had a few of these plastic pins blow up and the heatsink falls off. I have this one machine that constantly breaks these pins that I ended up ghettomodding it with screwlocks and a bunch of nylon washers. Not as tight as before but at least the cpu doesn't overheat anymore when the plastic pins crack!...
        12-31-2025, 10:07 AM
      • madan1
        Diesel heater emergency power supply / poor man's UPS
        by madan1
        Hello everyone.
        Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
        12-18-2022, 08:05 PM
      • hamsteyr
        Help with Dell Inspiron 15 5567 BAL20 LA-D801P
        by hamsteyr
        Trying to repair this board for learning purposes. I have a working board as reference, but I am unable to figure out what is wrong with said board.
        I'm no stranger to micro soldering and I have successfully repaired many other devices in the past, but I only know how to replace and solder stuff on well, not diagnose what actually is broken if that makes sense; i.e. I only have physical technical skill, not knowledge.
        Machine Model Number
        • Dell Inspiron 15 5567 BAL20 LA-D801P Rev 1.0 (A00)
        Specifications​
        • Intel Core i5-7200U (SR2ZU)
        • AMD (216-0889018)
        • 16GB DDR4
        • 1TB SATA
        04-28-2026, 06:28 AM
      • F-18
        MSI twin frozr GTX 750 not shown in device manager
        by F-18
        Hello Newbie here..., few years ago i bought a broken twin frozr gtx 750, seller said that theres heavy stutter issues in every game tested. i inspect it a little and find two tiny capacitor torn out near the pcie x16 gold pins, i assume it will be running in 8x ? the furmark-like gpuz test showed that there's indeed a heavy stutter and low fps but i tried this with EXP GDC and a laptop.
        Few months ago i bought a broken Twin frozr gtx 750ti with unknown issues, i didnt test it and jump straight to thinking that i probably need to solder everything that the gtx 750ti have but gtx 750 didn't...
        11-07-2025, 11:12 AM
      • jdryyz
        Gigabyte GA-8IPE1000-G v4 burnt & broken trace
        by jdryyz
        So this happened today.
        Not sure if the popped and bulging caps contributed to the blown trace, however. Although, I am well aware this board comes from the bad cap era, it had no visible signs of trouble prior to me having started this retro PC project. In fact, all caps looked pristine with no bulging. And, yes, I am also well aware that not all bad caps need to have visible signs of trouble for them to be bad. Lesson learned.
        I think I was building the perfect storm with this event, as I had both an FX 5200 AGP card *and* a Voodoo3 3000 PCI (which...
        08-23-2026, 11:17 AM
