I have my friends pc here. It will not boot. It has an MSI KT4V motherboard and hangs while posting with the message checking NVRam.. It used to start after a couple of retries. Now it will not get past this. I have tried swapping memory with a known good stick and cleared the CMOS and replaced the battery with a fresh one. I even replaced the bios chip from my old KT4V and it still hangs. All the caps look good and they are United Chemicon. Any Ideas?
Checking NVRam..
Re: Checking NVRam..
Its not an IDE device. When I tested a different power supply I plugged in only the motherboard and video card. I did not apply power to an optical or hard drive. There couldn't be a problem with an IDE device if the data cable was connected and not the power could there?Comment
Yes. Unplug the cable also. When the bios fires up and its not getting the signal its looking for from the cable, or there is a short, it will hang.Comment
*&*%^$&#)_&*^_#$ !!!!!!!!!!!!!!!!!!!!!!!!!!! I just got the new motherboard and read your post. I unplugged all the IDE devices and it posted! I was lazy and didn't feel like breaking down the whole system so I just assumed it was the board. The NVRAM thing is misleading. I guess sometimes you have to learn the hard way. Oh well. I am a donkey and I guess I have a new motherboard. My friend will be happy though. Thanks for the information. I think it is his cd drive that pooped out. Oh Well.Comment
If you are going to swap the motherboard anyway, take it out of the case and put it on the bench, with a different power supply, and no cards or devices other than the keyboard (and video card if it does not have onboard video). Try it that way and see if it boots.Comment
Pop into the BIOS and see if there is an option called something like "Reset Configuration Data", generally in the PCI/PNP config section. Every time I've had that problem of systems locking up at the checking NVram stage I've found enabling the Reset Configuration Data option cured it.
Its an option that automatically gets set back to Disabled on a successful boot.Comment
Hello, does anyone here have a backup of nvram with resettable ink chip?
Thank.07-14-2025, 01:18 AM -
by piernovLaptop model: Thomson THN14B
Board model: C116C VB1
Working BIOS
Clean TXE (2.0.0.2077, original: 2.0.0.2075)
Clean NVRAM
Windows key offset: 0x415014 (set to "ABCDE-FGHIJ-KLMNO-PQRST-UVWXY", change before flashing)
PS: problem was partial short on PS7516 5V boost converter (near the 2R2 inductor) which causes symptoms that look like no POST problem....-
Channel: BIOS Requests ONLY!
The operating system often hangs after any graphics operation like scroll/zoom/menu open/button click. It is the same after swapping all parts (CPUs: dual Opteron 2216 or 8435, RAM: 8x1GB or 8x4GB, power supply : 800W or 1000W, graphics card : original Quadro FX 3500 replaced with GeForce 7300 LE to decrease power) one at a time, and trying several operating systems (Windows 7/10, Linux, FreeBSD; 32 and 64 bit versions of all of them). But if the motherboard has been sleeping for months/years, the first few minutes are more stable before it warms up. This seems to come with... -
by madan1Hello everyone.
Got a catalyst 2960 from the usual scrapyard - ebay.
It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
The switch fails to boot due to the following POST error:...-
Channel: Troubleshooting & Designing Networks
by HexelHello!
I need help identifying part name of IC in QFN16 packadge under SSD, near audio jack and 1206 capacitors (marked on photo). Unfortunatelly there is no refdes of that part so that is only info I can provide. I took boardview here on forum for revosion 2.0, but it doesn`t have this part at all, not just moved. Maybe someone have relevant schematic or BV.
Notebook was poured with coffee and someone already tried to fix it but as usual made jusy worse. I`ve restored all mobo defects and now it powers up, starts OS booting but hangs on OS logo. I believe missing part may... - Loading...
