Ratdude's Main Rig V4.1
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Ratdude's Main Rig V4.1
    It might be an ampere limiter in the BIOS interfering. Possibly for artificial obsolescence...
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Same BIOS as the board that will run them, so not likely. At least in software.
      It's probably something really stupid... like less than 20 I/O connections to the CPU not existing or the like.
      sigpic
      (Insert witty quote here)
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Originally posted by Topcat
        My X6DA8 ran them, both sockets. The pic I posted was only one socket populated for POST testing purposes. I did however run into this with the X6DAL, as I mentioned in the thread, it would only run one CPU.
        Missed this.
        Anything "Special" done? Was the X6DA8 on the latest BIOS?
        Both CPUs are good... maybe you have a different revision board?
        sigpic
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Nothing special, whatever the latest BIOS is from their site, I'd have to fire it up to get the version number. I'll also check the revision number of the board. My X6DAI also had no issues with the Paxies.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            reflashed stock BIOS (in case SLIC was the issue), nope, no good.
            My board is a revision 1.2
            Looking on ebay:
            found this, same thing without SCSI, but also a 1.2:
            https://www.ebay.com/itm/Super-Micro...IAAOSwCGha8FZj
            The only other thing I saw that's worth my time was this, but it's also a 1.2:
            https://www.ebay.com/itm/Supermicro-...UAAOSw5JJZkv~b
            Didn't see any reasonably priced DAi's or DA3's... so Paxville might be a fail for me? Grr...
            Maybe I'm better off to reflow the dead X7DWA-N and put it in here.... Edit- off-topic, but those boards are re-appearing:
            https://www.ebay.com/itm/Supermicro-...oAAOSwwoZa5Cec
            (who the hell puts a workstation board in a server, seriously?)
            https://www.ebay.com/itm/X7DWA-N-Ser...kAAOSw3Sla373B
            Too bad I'm about to blow a lot of money on travel... otherwise, 4.1 might be getting a REALLY BIG upgrade Maybe if nobody bids, they'll relist with a lower starting bid.
            sigpic
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Decided to try her out again... still only showing 4 CPUs. I rebooted to try to shut off HT (to see how that affected things)... and dead. Spins fans.
              Nothing was hot to the touch...
              Tomorrow (or whenever I get to it) I'll pull the CPUs and see if installing the irwindales revives it. If not, she's dead...
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Played with it tonight... she runs!
                Issue was either a loose RAID card or bad RAM connection. Swapping CPUs didn't help (although given the Paxville rejection, it needed to happen anyway). Reflashed my SLIC BIOS, all better. Good as new.
                sigpic
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • Asraf Atb
                  Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                  by Asraf Atb
                  Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                  Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                  I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                  01-27-2025, 05:02 PM
                • JSin21
                  Compatibility of main boards between different variations of samsung MU6100
                  by JSin21
                  Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                  I have Samsung Smart TV UA65MU6100WXXY version DA01
                  Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                  11-27-2023, 04:54 AM
