Ratdude's Main Rig V4.1
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Ratdude's Main Rig V4.1
    She's in... but due to work today I didn't have time for pics.
    But here's what I know:
    -the RAM I ordered is USELESS. It's the G model, the "2 LANs" they referred to are pissant D-link cards. Good thing I still have 8GB DDR sitting.
    -the front door was included but the bottom hinge on the case was broken... oh well...
    -There are two newer looking SATA hdds installed.
    -Lots of weird PSU adapters by the drives. IDK WTF they were thinking...
    -The floppy is for show, no cable
    -The coolers sorta suck, No PWM. Looks like it was made for the HP coolers I modded for V2, so I may see about getting two more of those for cheap:
    http://www.hypermicro.com/ProductDes...697-003&key=it
    I'll check to make sure they fit first... but the mounts used in this sytem are "through the board" like those, not "on the board" like the X5DA_ systems
    -Some jackass stole the rear fans and swapped them for non-PWM yate loons. I'm going to see about getting replacements from SM (along with the one broken PCI latch)
    -I can't find intenal USB header #2... I thought i read that these had 4 internal ports. Oh well, I may throw in my mitsumi floppy card reader combo and use an NEC USB card.
    -it has a Small business server 2003 COA, if anybody wants it.
    -I have no idea on getting the PCIe to unlatch.. same for removing the drives/caddies.
    More (and pics) late tonight, after work. In the mean time, anybody have a use for 16GB of ECC DDR2?
    sigpic
    (Insert witty quote here)
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      SHIPPED: Supermicro X6DAI-G2 Server Mainboard
      The first thing you'll hate about that case is the racket it makes.... I've build a couple of those cases as servers....even with the fan controller idling everything, it still made a lot of noise.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        I know, I've been in your office before. All those 80 mm fans...
        sigpic
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          With a good fan controller, they're pretty quiet, really not much louder than any off the shelf workstation. The server cases are even worse, they have higher RPM fans, our workstation cases aren't near as bad.....but disable the fan controlller.......wind tunnel and sounds like a jet engine!!
          Team : 49813
          Join in!!
          Team Stats
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            They're all ppm as is the mobo... it was designed to be quiet as per the manual.
            sigpic
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              No pics, been too busy.
              However, these I know:
              -the rear fans were never included, as part of the "superquiet workstation" configuration.
              -The system runs
              -The PSU fan is always on (everell's dream?)
              -The two HDD's are dell-badged WD RE 160GB... 7200RPM
              -I found the 2nd USB header, it's hidden below the uppermost PCI slot
              -The GPU is an MSI nvidia of some sort; ATM majaro is downloading so I can lspci and find out
              - The CPUs are 2.8 GHz... I'll want to upgrade that...
              TC, I know what you mean about the fans... ouch! It's better with the 4 pin workstation option.
              The coolers work and all... but they are LOUD and being intel there is no switching them... I pulled them, it looks like the HP ones I linked are a direct swap (faster fans, but they're PWM).
              Suggestions?
              edit- yay, post #13,000!
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                The GPU is an Nvidia 7300LE.
                Found out the onboard RAID isn't 7 friendly... but I may try again. In the mean time I'll nlite an XP impage with a known good driver so I can at least get XP on for my 7 to activate (I'm using an upgrade copy, since the last time I SLIC'd an SM it was a complete failure and killed the board).
                sigpic
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16956
                  -The system runs
                  Suggestions?
                  Yea, I had a hunch you'd want to change those fans.... What PSU is in that? Is it a single or a redundant? The 865W singles I have, even when the system is powered off, the PSU fans run at low speed.
                  As for CPU, are you feeling lucky with a paxville gamble? Otherwise, its a single core @ what, 3.4GHz? I think the nocoma/irwindale went up to 3.8GHz, but I've never seen one. I'll have to look through my xeon collection, I think I have some 3.2's around here somewhere.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    645W single.
                    I'll see what I can grab on ebay... but if you do have something better, I'm up for trades (as I'm gonna put that 16GB of RAM on FS in a bit)
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      got 7 on it, won't activate (probably due to me not setting the CMOS clock until midway).
                      CPU-Z says I have a pair of 2.8GHz Nocona's (no shit given how old the BIOS was, it was many updates out)... Irwindales here I come (not checking paxville as the making of a new mobo tells me it isn't supported on this).
                      sigpic
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Still bitched about activation... had to call it in. Turns out my K8WE was still being shown as tied to the key, as it's since been SLIC'd and the certification/key swapped, which freed up this copy.
                        sigpic
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16956
                          The only activations I ever do are for customers.....otherwise, its never necessary with 7. My S2K8 is a VLK, it always activates online no matter what....I've got it on probably 6 systems right now.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16956
                            I checked my Xeon pair I had....the 3.2's I now remember I stuck in a precision670 and traded them away years ago. I had another pair that I completely forgot about.....the forgotten score!! Matching pair of 3.6GHz Irwindale engineering samples (unlocked multiplier)!! These are the 2mb L2 cache versions. hmmm...not sure if I want to part with these or not....oddballs for sure. I tested them in my precision 470. Is that 16gb of DDR2 ECC you're selling all matching sticks? Are they 1-rank or 2-rank? What chips are they?
                            Team : 49813
                            Join in!!
                            Team Stats
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Yup, I'll check when I get home tonight.
                              sigpic
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16956
                                I'll keep my fingers crossed that they are 1 rank. The 7525 chipset is bitchy about all slots populated with 2 rank
                                Team : 49813
                                Join in!!
                                Team Stats
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  It's 2 Rank.
                                  They're Nanya HP pulls.
                                  edit- does this make my RAM junk?
                                  sigpic
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16956
                                    It's 2 Rank.
                                    Not junk, just limits compatibility with some chipsets, unfortunately including the 7525....
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16956
                                      Here's the CPU-ID screenshot of these CPU's... I put some different (less but 1-rank) memory in this old tub of a Dell, and it hasn't been bitching memory codes at me....this board/chipset really hates 2-rank DIMM's.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        Sounds more like a DIMM slot that has poor contact. I have finicky DDR 2 DIMM slots on a 2008 Dell Inspiron 530 S. (LGA 775)
                                        When it bitches a RAM code, I must reseat the RAM and try again. And just moving the PC case can cause the motherboard BIOS to bitch a RAM code!!
                                        (At least if the motherboard flexes)
                                        Sometimes, it won't even bleep, instead, I just get "turbo fan syndrome", which lets me know that I must reseat the RAM again!
                                        For the same PC that I worked on in August, 2011, I believe I found the real problem, I highly doubt it's the northbridge.
                                        ASRock B550 PG Velocita
                                        Ryzen 9 "Vermeer" 5900X
                                        Arc A770 16 GB
                                        eVGA Supernova G3 750W
                                        Alienware AW3423DWF OLED
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          Picture time... (bless my mess, I've barely had time to clear a spot for the beast + 2 LCD's)
                                          An overview in my current setup:
                                          The upper bay is empty but I plan to add a card reader there. More on that later. The middle is the DVD Burner out of V2.5, which was swapped for a similar but uglier HP burner I had (I've scored a few lightscribe PATA burners lately). The lower is an all-handy floppy drive... because why not... and for some reason it booted slow/inconsistently with two PATA optical drives.
                                          The COA:
                                          I blurred the codes, but that's what I have codes for. Not that I'll use any of them, but if somebody else cares, let me know.
                                          Inside the case:
                                          I swapped GPUs as it was easier to toss in a crap Quadro FX 1400 than it was to swap cables on one of my LCDs. I do have different (HP pulled foxconn) coolers on the way (I managed to break one of the fans, so that sealed it long term). I also have some Irwindale CPUs on the way, but I won't elaborate on them until I have them.
                                          Yeah, it has some broken card clips... Anybody know if I can order replacements?
                                          And yes, I know the wiring needs cleaned up... once the parts are more finalized I'll get zip tying.
                                          The two 160GB HDDs:
                                          Right now I have 7 on one and nothing on the other since intel/MS didn't make a win7 driver for the ICH5r's raid function... While I'd love to run a massive 10K array with a 3ware card, it's not economically feasible. Suggestions for a better (and somewhat low cost) setup? I do have space for 8 drives.
                                          PSU info:
                                          I looked inside the PSU last week, it's beefy. What's unfortunates is the lack of plugs, as I only have 3 non-motherboard strands. One is the only one long enough for the DVD drive (2 molex), one is for the FDD and HDDs (2 molex and a Berg, with a 2 port SATA adapter), and the last is hanging for a PCI-e adapter. I know one is suppossed to use two strands for said adapter, but what am I supposed to do here?
                                          The back:
                                          Card reader wise, I'll probably go with another AFT 3.5" of some sort (tried and trued), since every 5.25" reader I've seen is either USB 3.0, has fan controllers or the like (BS I don't need), or is a cheesy POS. That being said, I'm all ears for suggestions.
                                          Otherwise, suggestions on the PSU situation, the HDD situation, and/or GPU upgrades is appreciated.
                                          sigpic
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • Asraf Atb
                                            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                            by Asraf Atb
                                            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                            01-27-2025, 05:02 PM
                                          • JSin21
                                            Compatibility of main boards between different variations of samsung MU6100
                                            by JSin21
                                            Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                            I have Samsung Smart TV UA65MU6100WXXY version DA01
                                            Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                            11-27-2023, 04:54 AM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
