Ratdude's Main Rig V4.1
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Ratdude's Main Rig V4.1
    I could also try paxville CPUs for cheap:
    http://www.ebay.com/sch/i.html?_from...sl8ma&_sacat=0
    $10 a CPU? I may see if i can works some best offers or something, as I don't want to spend a lot but it would be an awesome test (and nobody has to gut a rig over it). But first I'll wait for the system to come in; for all I know it already has such CPUs installed (unlikely)
    sigpic
    (Insert witty quote here)
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      DDR2 ECC is cheap....like the FB memory my X7DWA-N uses. they're pretty much giving it away, as not much on the consumer market hardware supports it. 20-dollar gamble on the paxvilles, yea.....try and let me know!! If it works, that'd be an idea for mine if I could find another 7525 board that also runs them.
      I need to update my thread as well. did some totally awesome case modding....I havent had to take an angle grinder to a case in many years!!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Uh oh... I've dremeled cases before but an angle grinder, on a case?
        (although they are fun to use )
        sigpic
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          ye, this one was heavy gauge steel, and I have to whack a pretty good chunk off it.
          Team : 49813
          Join in!!
          Team Stats
          • c_hegge
            • Sep 2009
            • 5219
            I've used an angle grinder to cut out the IO shield area on a slim Dell Vostro case which I might just build into a HTPC (when I feel like forking out for an SSD and HDD for it).
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Crazier Idea: Anybody know if Tulsa Xeons will run on these?
              Since (from what I can tell) the SM X6DA_ series is for DDR2 Netburst applications, and the X7DA_ was for the core based ones (they correspond to intel's workstation chipset releases)... and from what I can tell the tumwater chipset was intel's last netburst dual-xeon chipset.
              If that be the case, screw paxville, I'll make the jump to tulsa (TC, didn't you once mention having a set of those kicking around?)
              sigpic
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I have a pair of them.....even the precision 470 wont run them. I think there;s 2 board in the world that will run those.....and one of them is some really strange form factor huge ass quad socket supermicro.
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Ok, I won't go there then.
                  sigpic
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    http://www.supermicro.com/products/m...8501/X6QT8.cfm
                    That will support tulsa processors.....the only one I've seen. I think there's some obscure Tyan that does as well, but I could not locate it.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Figures. Looks like my K8WE is still the better platform (but both systems will be nice).
                      sigpic
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Nope, it appears Supermicro made X6DA3's and other models for paxville. The boards look the same though, so it's possible that I did get one. I won't know until I have the system in front of me.
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Took a closer look, it's an X6DAE-G2 (as it had 2 LANs as per the seller's description). No Paxville support. Bummer!
                          (oddly they did make an SLI compatible version too... but it used DDR1 and was the crappy PCIe 8x version of SLI, not the full 16x SLI my K8WE has).
                          edit- here's one that will do paxville, for not too much $$: http://www.ebay.com/itm/Supermicro-X...item2596c8cf84
                          (even after shipping from germany, that's not bad at all)
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            It gets weirder... according to the manual, the G2 models in addition to two LANs also are the only ones with DDR2... the G's do use DDR1. Damn Supermicro made this confusing... like mid 90's Mac models...
                            edit- looks like 2 LANs in the grainy picture, look by the parallel port. 1 would be shorter.
                            sigpic
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              I havent read the manuals, but different RAM on the same basic board & chipset seems a wee bit erroneous. Memory type is a factor determined by what the chipset supports rather than a simple board revision. Makes zero sense.
                              that one in Germany....tempting...
                              Team : 49813
                              Join in!!
                              Team Stats
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                The tumwater chipset supports both, and SM made boards with the chipset both ways.
                                sigpic
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16958
                                  Interesting for sure.....but quite bizarre....
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    nope, this is actually pretty common. Later C2D chipsets were like this (such as in my Asus x83v), as they could do both DDR2 and DDR3 (mine did DDR2). Some desktop boards for the budget market (ECS and ASROCK) actually had both on board, as an upgrade path (the latter did the same with AGP and PCIe 16x).
                                    sigpic
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16958
                                      I've never seen it....and I've seena lot of boards over the last 12 years....but I have seen old socket7 boards with SIMM and DIMM slots on the same board, so certainly not impossible.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        I've seen boards that have DDR and DDR2, and also AGP and PCI-Express. They've all been broken/dead though.
                                        • Topcat
                                          The Boss Stooge
                                          • Oct 2003
                                          • 16958
                                          Now that I think about it, I have seen some boards with both DDR1 and DDR2 slots on it.....had to really think back on that....but yea. There weren't a lot of them.
                                          That german one is no longer for sale.... That is the same model I mentioned in another thread last week, only us based one, the bozo wanted $599 for it. I emailed him, and he never responded.
                                          Team : 49813
                                          Join in!!
                                          Team Stats
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • ygorsan
                                            by ygorsan
                                            🧩 Problem Summary:
                                            • I
                                            07-28-2025, 08:34 AM
                                          • Asraf Atb
                                            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                            by Asraf Atb
                                            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                            01-27-2025, 05:02 PM
                                          • JSin21
                                            Compatibility of main boards between different variations of samsung MU6100
                                            by JSin21
                                            Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                            I have Samsung Smart TV UA65MU6100WXXY version DA01
                                            Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                            11-27-2023, 04:54 AM
