Help me understand Absolute Persistence and Wolf Security on HP laptops
  • MTT97
    • Dec 2025
    • 26
    • Sweden
    Not too long ago i bought a used HP Probook 440 G8 from an online market place. The bios is locked, seller does not know the password so i'd assume it's a company laptop that he got (which is normal here in sweden that you get to keep the device).
    I could still access the boot menu and create a fresh install of Windows. However, i just learned about Absolute Persistence and Wolf Security and they could monitor anything you do in Windows, including browser and such. Can someone confirm if that's the worse case? The bios is locked and i can't really confirm if Absolute is enabled/active, but i do see the Wolf Security logo appearing on start up. I just want to know in worse case possible, are they able to monitor my activity in Windows despite a fresh install? Location trackng is one thing (because i have an invoice and seller information), but tracking my personal activity in Windows without me knowing is just creepy if that's the case.
    • 32045
    soo.
    i dont know about this - BUT
    i know about COMPUTRACE that is in most bioses and sounds similar.
    computrace is dormant untill activated (i dont trust that!)
    once activated it will INSERT FILES into Windows AND Linux to turn it into a remote terminal that can call home, spy on you or format the harddrive.
    if i had that machine i would dump the bios and replace it or try to edit it to remove UEFI extensions related to this crap.
    AND try to disable the ME too - thats intel's microcontroller hidden in the chipset with similar features!
    • m1ch43lzm
      • Mar 2019
      • 3488
      • Peru
      Wolf security is some security software suite (antivirus + some extra stuff targeted at businesses) + Sure Start, it prevents tampering with the BIOS itself and Secure Boot keys, there's also options to recover the MBR/GPT and "Virtualization Based BIOS Protection" for UEFI drivers
      https://www.hp.com/us-en/security/en...solutions.html
      You only get the logo at boot if you already reinstalled Windows and didn't install Wolf security from the HP support page for your model; it's available for all Pro/Elite/Z series PCs and laptops (I didn't even install it after reinstalling Windows on mine)
      HP Wolf Security provides protection for small and mid-sized organizations, and stops a broad range of attacks, including phishing and ransomware, without requiring security specialist staff or complex configuration. Also included is the HP Wolf Security UI framework and the Security Update Service.
      They also sell Wolf Pro subscription separately, has some extra stuff compared to the regular Wolf Security for Business https://h20195.www2.hp.com/v2/GetDoc...e=4AA8-1794ENW
      Absolute (formerly Computrace) if it's enabled it can silently install when you connect to internet after reinstalling windows, if it's disabled it can't install itself (or it shouldn't, at least); it has a BIOS component that does that; on HP you can't set it to Permanently disable from BIOS setup itself, you have to use HP BCU or HP CMSL
      It's for tracking missing/stolen devices, you get a DeviceFreeze screen at boot (and a password input box) if it got remotely triggered; supposedly Absolute (the company) can remove it from their database if you can prove legal ownership
      HP BCU: https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
      Usage: Run from command prompt as administrator
      C:\SWSetup\SP143621>BiosConfigUtility.exe /get:config.txt
      Open config.txt and check if it's "Inactive"; if it's already "Active" you can't disable it easily (need to backup the BIOS with external SPI programmer and do some things to it, besides formatting the drive in another PC first)
      Should look like this (example from Probook 450 G9)
      Code:
      Permanent Disable Absolute Persistence Module Set Once
          *No
          Yes
      Absolute Persistence Module Current State
          *Inactive
          Active
      There's an option to "Permanent disable Absolute", it's only possible if it's set to "inactive" and you know the BIOS admin password/have no password set
      Originally posted by stj
      soo.
      HP Sure Start will fix the BIOS if you tampered with/modded it, besides the BIOS itself on HP laptops (at least the code sections) is signed so a custom BIOS will brick it, or best case Sure Start will "self heal" it, there's 2 SPI flash chips on those laptops (one on top side of the board, main BIOS, and the other one in the bottom side, the "EC" BIOS)
      You also have Intel Boot Guard, the OEM signing key is permanently fused in the PCH, good luck with that
      Same with the Intel ME, it will complain that it can't recover ME firmware at boot if the ME region in BIOS is corrupted/tampered (besides really long boot times, if it boots at all, among other issues such as SSD not being detected)
      AFAIK Absolute (formerly Computrace) can't do anything on Linux if enabled, they only support Windows, macOS and ChromeOS (that's what they say)
      https://www.absolute.com/platform/requirements
      • MTT97
        • Dec 2025
        • 26
        • Sweden
        Code:
        *No
        Yes
        *Inactive
        Active
        That was very informative, thank you.
        • berrylinx
          Dell Latitude 7400 2-in-1 bios with absolute persistence lock
          by berrylinx
          Dell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
          Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
          Thank You....
          09-15-2025, 03:02 PM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • Trademark
          Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
          by Trademark
          I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
          This is NOT a BIOS password removal request.
          I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
          Laptop Information
          • Model: Acer Predator Triton 16 PT16-51-99GL
          • Motherboard: DA0ZQDMB8AE Rev. E
          • Main SPI flash: Winbond W25Q256JVEN (32MB)
          • Secondary
          07-22-2026, 08:57 AM
        • cr4zychriss
          by cr4zychriss
          • Rebrand: PC Specialist
          11-14-2025, 04:04 PM
        • Darksands
          Need clean BIOS dump: Dell Pro 14 Plus PB14250 (CMF34 Rev: A00) - Freezes on Dell logo
          by Darksands
          [SOLVED]
          Laptop: Dell Pro 14 Plus, PB14250
          Motherboard: PWB CMF34, Rev (A00).
          Service Tag: 3YLQ8F4.
          CPU: Intel® Core™ Ultra 5 processor 238V (8M Cache, up to 4.70 GHz) FCBGAEXX, Tray. Ordering Code: QQ8076606106. Spec Code: SRPN5.
          BIOS Flash Chip: Winbond 25R512NWEQ.
          BIOS version (via ME Analyzer by TechNoDev): 20.0.11.1815_COR, FITC 20.0.0.1329, SKU Corporate.
          Symptoms & History: Initially, a black screen appeared, then the laptop rebooted, entered BIOS Recovery, and the flashing process started. After the flash and a reboot, it freezes...
          09-13-2026, 03:15 AM
