asus x502ca motherboard wont recognise wifi
  • ciki
    • Aug 2014
    • 132
    • Ireland
    Hi have laptop asus x502ca with motherboard hannstar j mv-4 94v-0 e89382 but no wifi ,try to change another wifi card but same so probably card not getting power because of bad weld or failure components .Any suggestion please or should I put her in oven for baking thx
  • diif
    • Feb 2014
    • 6978
    • England
    Re: asus x502ca motherboard wont recognise wifi
    Check it's not disabled in the BIOS and the drivers are correctly installed before doing something extreme like sticking it in an oven. It's not been turned off by the hotkeys by mistake has it ?
    • ciki
      • Aug 2014
      • 132
      • Ireland
      No I check bios and hotkey for airplane mode
      • ciki
        • Aug 2014
        • 132
        • Ireland
        Its not showing in device manager too.
          • 31028
          factory wifi, or a replacement?
          • ciki
            • Aug 2014
            • 132
            • Ireland
            Factory card and also try 2 different
            • reaper57
              • Sep 2014
              • 216
              • Norway
              I've seen similar issues a few times, and almost always it has been right before a chipset/graphics controller failure, due to bad solder balls condition. If you are planning on a homemade repair I wouldn't recommend an oven "fix"/reflow. It is much better to use a heat gun and flux (no-clean flux).
              But you should not start reflowing things on your board, before you are 100% that a bad chip connection with the motherboard is the problem.
              Keyboard not detected, press F1 to continue...
