SuperH-based Arduino?
  • japlytic
    • Oct 2005
    • 2086
    So far, I have found Arduino-compatible boards based on architectures other than the Atmel AVR, which include ARM, PIC, MIPS and SPARC.
    But I am curious if there are any Arduino-compatible which uses the Hitachi/Renesas SuperH architecture.
  • japlytic
    • Oct 2005
    • 2086
    Re: SuperH-based Arduino?
    Question answered: I have searched again, and there are Arduino-compatible boards which have the Renesas SH7216 containing the SuperH core.
      • 31201
      is it worth it?
      i mean, the pi b+ and the new stuff like orange-pi, bannana-pro and odroid series have loads of io but dont need a seperate pc to program them.
        Renesas H8S/2112 R4F2112 R4F2112R - 16-Bit Single-Chip Microcomputer Datasheet
        H8S Family / H8S/2100 Series
        Ordering codes:
        F2112TE25V F2112BG25V F2112LP25V
        The core of each product in the H8S/2112 Group of CISC (complex instruction set computer) microcomputers is an H8S/2000 CPU, which has an internal 16-bit architecture. The H8S/2000
        CPU provides upward-compatibility with the CPUs of other Renesas Technology-original microcomputers: H8/300, H8/300H, and H8S.
        As peripheral functions, each LSI of the group includes a serial communication...
        10-23-2024, 02:33 AM
      • supravit2000
        PS4 slim SAD-001 board - how to tell the Renesas ic is bad?
        by supravit2000
        Hi, folks! I am not pro, just watch videos and try to find the error - sometimes it works.
        So I have been sold a ps4 with no hdd which should only be replaced. The machine boots up to safe mode and after assembling a new ssd, the update process returns an error su-42118-6 (sometimes SU-41333-4) which after some research, I found out that the console is for the bin as the renesas ic must be bad. The bd drive indeed shows no signs of working order (the button for eject still beeps, though, but a cd is not accepted at all). All the fuses on the board are fine, so are the caps/resistors....
        10-03-2023, 02:54 PM
      • Donny2derby
        Could you run a 3 phase motor using Arduino?
        by Donny2derby
        If you connected in the control wiring onto an inverter could an arduino programmer be used as the controller?
        In my (limited and attempting to learn mind) using the right set of code and some simple wiring this would be relatively simple to achieve??
        Yes?? Or if not can someone tell me why please 🙂
        Thanks 👍🏻
        03-28-2024, 03:22 PM
      • hinisa
        Xiaomi router freezes at boot after re-capping
        by hinisa
        I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
        When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
        After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
        Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
        07-08-2023, 05:58 AM
      • OrangeJulius
        Exploring Arduino book
        by OrangeJulius
        Am going through the Exploring Arduino 2nd edition by Jeremy Blum. One of the projects is a servo motor being controlled by the Arduino that is powered by a separate 5v supply the author suggests to build. Is a 7805 regulator with two 10uf electrolytic caps. One running from power in lead to ground, the other from power out to ground. The servo sounded like hell. I double checked, replaced, then completely removed both caps. After removing, the servo ran a lot better. I've noticed the author suggests this power supply setup in a few projects. Should i just completely do away with the caps on the...
        06-01-2021, 05:46 PM
