fan circuits
    • 31094
    fan circuits
    so i have a bit of kit with 5v fans that have a tacho output.
    and you cant get them cheaply.
    so i got some 12v fans.
    but the tacho output is 12v.
    datasheet says max output is 4ma
    how to not damage the circuit.
    i was thinking putting the tacho through a 3k3 resistor and then puting a 5v1 zener between the ground and tacho pins on the board connector.
    any other idea's?
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: fan circuits
    If you run the fan on 5V, I think the tachometer output wire should also have, at the most, 5V on it.
    Now if you are running the fan on 12V and want it to output a signal of max. 5V on tacho, then yeah, you would need something to clamp down the signal. The 5v1 zener might work. A simple resistive divider might also work too if the 12V rail doesn't go too high.
    I'm not all too familiar with the signal on the tachometer wire (whether the signal is pulsed or continuous), but the above two methods should work IMO.
      Re: fan circuits
      Can we see the spec of the fan?
        • 31094
        Re: fan circuits
        no you cant, they are cheap chinese crap.
        but the fan tacho is pretty standard so if you look at a datasheet from delta for example, you will get the idea.
        the output is from the magnetic sensor usually that is used to syncronize the motor poles.
        i'm including the datasheet of the original failed fans.
        the replacements will be running at 12v, they are needed for a reason and i need the airflow.
        infact the tacho is for a safety circuit that kills the power to the chip if the fan stalls!
        • FrancescoV
          Onkyo HT-R390 no sound output, video output ok
          by FrancescoV
          Good morning everyone,
          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
          The firmware reported is the following:
          M:1.00/11107BLP
          D:?.??/????????
          O:1.00/11107AL
          The DSP firmware given the question marks seems corrupt.
          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
          05-11-2025, 02:59 AM
        • emil_t
          RTX3090 working fine but fans not spinning
          by emil_t
          Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
          04-12-2024, 06:54 AM
          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
          by sam_sam_sam
          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
          I bought this from an eBay seller but unfortunately they only had one
          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
          I bought three of from them to also make battery packs with this output power limit in mind
          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
          04-23-2025, 05:50 AM
          Corsair CX750M [Model 75-002019] - burned output toroid inductor
          by momaka
          Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
          So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
          09-19-2021, 08:44 PM
        • flibidy
          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
          by flibidy
          I have here a Magnum IA.100 which belongs to my parents.
          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
          What Ive done........
          01-01-2025, 01:26 PM
