USB problems
+ More Options
Posts
  • pentium
    • Mar 2006
    • 2778
    USB problems
    I never really noticed it until now but it seems I am having trouble with four USB ports.
    there are four sockets next to the ports (they work fine) and two plugs for an additional four on the board close to the bios (these don't). I am using one standard run-of-the-mill usb brackets with their metal plate removed and the MSI D-Bracket.
    and when I plug even just one port in I get momentary power and then suddenly I lose all power. It sounds like the poly fuse is kicking in but I don't see why.
    Here is the pinout for both plugs:
    1-Vcc
    2-Vcc
    3-usb0-
    4-usb1-
    5-usb0+
    6-usb0+
    7-gnd
    8-gnd
    9-No pin
    10-usb0c
    I looked over several sites and the pinout checks out fine. Witout this I can't use my front card reader or usb port let alone my rear connections. What's going on?
    Who was it again that said they had an MSI K7N2 Delta2 mobo? Would you be able to confirm the pinouts?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • pentium
    • Mar 2006
    • 2778
    Re: USB problems
    Not even a clue?
    Find Nedry!
    • stretch0069
      Screwed Up Super Moderator
      • Oct 2003
      • 2658
      • oooo ess aaaaaaaaa
      Re: USB problems
      Did you check those cables for possible shorts???
      Seems odd that everything is fine until you plug those cables in....
      "Its all about the boom....."
      Guns kill people like spoons made Rosie O'Donnell fat.
      We now return you to your regularly scheduled drinking.
      "Fear accompanies the possibility of death.....calm shepherds its certainty"
      Originally posted by Topcat
      AWD is just training wheels for RWD.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Re: USB problems
        I had a similar issue with an Iwill DVD266u-RN.... I plugged in one of those headers, powered the system up, and puffs of smoke came from the southbridge, and that was that. board was toast. Nothing was plugged into the header, so I couldn't blame any devices. Since then, I've never used one on any of my personal systems......you know, once bitten twice shy..
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • pentium
          • Mar 2006
          • 2778
          Re: USB problems
          I'll try checking for a ground short tomorrow. I had no puffs of smoke on my system. Voltage checks found no undervoltage problems either.
          Find Nedry!
          • pentium
            • Mar 2006
            • 2778
            Re: USB problems
            I have tried several different combinations and none of them work.
            It looks like I will need to stuff a self-powered hub into the case and go off that.
            Now I need a 4-port hub.
            Find Nedry!
            • pentium
              • Mar 2006
              • 2778
              Re: USB problems
              What do we have here?
              I has plugging a usb cable in the back of my system when U suddenly saw a glow and started to smell smoke. I shut the system down and proceeded to find out what had happened.
              It seems the 5V line had somehow managed to short to ground and the light and smoke was from the trace burning up and not the fuse. If my case is live, this might explain why the poly fuse keeps tripping.
              Find Nedry!
              • pentium
                • Mar 2006
                • 2778
                Re: USB problems
                You know, the frame just might be live. Another thing I am having a problem with is that the system will instantly come back on if I shut the system down. (you hear the drives spin down and the front led's go off but then everything comes back on like the power button is being pressed). If you also have a USB bracket installed and plugged in and then you shut the system down (by pulling and reconnecting the main plug because it will come back on) and then power on with the front switch, the PSU will kick out and will only allow the system to come back on once you disconnect the usb bracket.
                I'm only pulling the system out if it's dead necessary. Do we suspect something came loose?
                Find Nedry!
                • pentium
                  • Mar 2006
                  • 2778
                  Re: USB problems
                  I am now 100% positive mt case is live.
                  I was crawling over the case to adjust a cable when I felt my arm tingle. It wasn'y a high voltage shock but it was something.
                  What does that narrow down to?
                  Find Nedry!
                  • Neo2_000
                    • Apr 2005
                    • 180
                    Re: USB problems
                    Have you checked the pinouts on your mobo USB headers. These are NOT always the standard RWGB.
                    You can cause serious to your mobo if you take that foregranted as a friend of mine recently found out the hard way.
                    • pentium
                      • Mar 2006
                      • 2778
                      Re: USB problems
                      I'm positive that the headers are fine.
                      The ports used to work fine.
                      Find Nedry!
                      • Tom41
                        • Oct 2005
                        • 336
                        • England
                        Re: USB problems
                        That sounds like ground leakage, or faulty earth/ground connectors. I don't know the exact details of what happens, but when you touch a 'leaky' appliance while touching something else that is grounded, you get a small shock.
                        I have several devices that tend to do that, most of which have no earth connection (supposed to be double insulated). If I am touching something that is grounded, like a pipe (or even the floor), and a small part of my body makes contact with the leaky appliance, I feel a sharp 'prick' - as if I touched a sharp sewing pin.
                        You know there's something wrong when you open your PC and it has vented Rubycons...
                        • Harvey
                          • Apr 2007
                          • 264
                          Re: USB problems
                          USB is supposed to be short circuit/mis-wired proof. I guess not all manufacturers follow the standard.
                          • pentium
                            • Mar 2006
                            • 2778
                            Re: USB problems
                            Hmm. The strange thing was I was on carpet so my arm must have been touching both the problematic area and an area where there was a good ground.
                            They do follow a standard now. The trace burning out and the poly fuses constantly kicking out are signs of that. There is also a missing pin on the USB headers so the plug is installed only one way.
                            Well, since I don't have anything to do with the system yet (I need to buy more ram), I guess it won't hurt to strip the system down and find the problematic device.
                            Find Nedry!
                            • pentium
                              • Mar 2006
                              • 2778
                              Re: USB problems
                              I know you are going to hate me for making a multi-paragraph report from my testing but you can sent all complaints to MSI. They made the board.
                              I completely stripped the system down and laid the board and psu on a piece of cardboard to be positive there were no shorts caused by the standoff's , the card slots or the rear ports.
                              This system apparently feeds 5v out of the USB headers even while the system is off (for waking and starting the system via USB keyboard and the system needs to have been on at least once before it does this)
                              I first removed one of my screwups (I had one usb connector on each of the headers reversed so it was shorting itself) and then checked for voltage. I got 5 volts and I then proceeded to plug one usb socket into the header. I then plugged my card reader into that and I got the front LED on it to light up.
                              knowing that power was going to the device, I then used a screwdriver to short the pins for the power switch. The led on the card reader went out instantly and the voltage dropped from 5V to 1.45V. I then unplugged the bracket from the header and the voltage went up to 5V. I then removed the card reader from the usb bracket and installed a light that only feeds from the grounf and 5V line and ignores the rest of the leads to the usb port.
                              With the system still on I plugged the adapter back into the header and the lamp lit up. I then left the lamp plugged in and the proceeded to turn the system off by once again shorting the pins for the power switch. As soon as the system shut off, the lamp got brighter than it was when the system was on. The voltage however only increased by .1 volts.
                              I switch the green and white leads, the data leads, on the on the bracket plug (see the photo I posted earlier) and then plugged the card reader in again.
                              The LED was on when the system was off but once again, when the system was turned on the led went out.
                              I can't make no sense of this.
                              Find Nedry!
                              • gg1978
                                • Dec 2004
                                • 431
                                Re: USB problems
                                Exactly what motherboard do you have in there?? It sounds like your USB devices are being powered by +5VSB, and not regular +5V.. A lot of boards have an option to jumper a given pair of USB ports to either power off +5 or +5 VSB.. Given that most PSU's are current limited to 2.0 amps or so on +5VSB, i'll usually jumper the USB ports to power off +5V.. This way the ports aren't "hot" while the PC is turned off, and it preserves current on the +5VSB rail for stuff that really needs it, like your motherboard or PCI cards that need to be able to wake the PC up.. If i do leave a set of USB ports set for +5VSB, its usually one pair on the ATX back panel, where i would plug in a keyboard or mouse, as some keyboards do have a key on them to turn the computer on.. A keyboard doesn't take much power..
                                It appears your extra ports are wired correctly, as the red wires are +5, the whites are D-, the greens are D+, and the black are groundd, and the one extra black on pin 9 is the shield for the USB cable, which is definately recommeded for USB 2.0..
                                edit: on a side note, it almost sounds like your card reader is tripping the overcurrent protection of the ATX power supply, on the +5VSB.. It almost sounds like the MSI board swtiches the USB ports between the +5VSB when the board is "off", and +5V when the board is "on".. There may be a BIOS option for the USB power thing too.. Might be worth a look..
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Re: USB problems
                                  I thought that the card reader was tripping the system out but if
                                  I connected it to one of my PCI USB cards the thing would work fine.
                                  I have an MSI K7N2 Delta2 motherboard with an athlon 3000 (+?) installed. I didn't really check for jumpers.
                                  EDIT: If I were to cut the current power trace for the USB headers and then wire a 5V lead from one of my unused drive plugs to before the fuse on the USB ports, would this fix things?
                                  Find Nedry!
                                  • pentium
                                    • Mar 2006
                                    • 2778
                                    Re: USB problems
                                    Here's one of the problems.
                                    I was looking at the wrong manual. I was looking at the platinum series
                                    This board is the one I have and right now I am going to check over it's manual.
                                    Find Nedry!
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      Re: USB problems
                                      well, whatever I did while I had the case stripped has eliminated the leaky ground.
                                      I still can't figure out what's causing this problem yet though and I still need someone to ok my fix before I whip out the soldering iron.
                                      Find Nedry!
                                      • jean luc ferre
                                        laptop hp g72 b52sf screen problems
                                        by jean luc ferre
                                        on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                        the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                        i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                        i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                        06-07-2025, 03:27 PM
                                      • pickledegg
                                        Dell Inspiron 7501 / Vostro 7500 (2020) - eDP connector pinout/panel compatibility question
                                        by pickledegg
                                        Hello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
                                        I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...
                                        10-02-2024, 04:54 PM
                                      • Hondaman
                                        USB problems?
                                        by Hondaman
                                        Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                        (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                        I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                        08-12-2024, 03:26 PM
                                      • clabr
                                        Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                        by clabr
                                        Need help to solve some problems with this laptop.
                                        After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                        After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                        Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                        Before this had happened I observed some other problems:
                                        When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                        12-02-2021, 08:09 AM
                                      • maleksa
                                        Korg Kross2 Service Manual and LCD pinout
                                        by maleksa
                                        The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
                                        However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
                                        Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
                                        From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
                                        10-11-2024, 05:54 AM
