Floppy drives and cables
  • Maxxarcade
    • Jul 2006
    • 973
    I still have my original Teac floppy drive from back when I built my 286 computer... I still use it to make the occasional floppy for older machines, diagnostics, BIOS updates etc.
    Problem is, my new motherboard has the floppy connector at the bottom, and I have a full tower case that has the floppy at the very top.
    I figured I have two options. Either make my own extra long cable (I have the stuff to do it at work), or I can upgrade to a multi-card reader/floppy drive that uses USB, since I also have an unused internal USB header. Though don't most combo drives still use floppy cables along with USB?
    Anyone know what the maximum cable length for a floppy is? I probably need a 26" cable at minimum, to get around the cards and the bigass Zippy power supply
    If I remember right, I paid over $50 for the floppy drive in the early 90's
  • pentium
    • Mar 2006
    • 2778
    Re: Floppy drives and cables
    They can get pretty damn long in cases.
    I got an extra floppy cable with one of my systems and you could simply plug it into the end of your old drive.
    You could also try splicing in a new section of cable too.
    Does that board have 5 1/4" support or did that end with the new socket A boards?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
    • Maxxarcade
      • Jul 2006
      • 973
      It does seem to support 5 1/4" drives, I can select 360K or 1.2M in the BIOS. I know WinXP doesn't like anything other than a 1.44MB 3 1/2" though.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i remember floppy cables 3' long for those full tower cases with the fdd at the very top.
        • Rainbow
          • Aug 2005
          • 1374
          I made long IDE and floppy cables for testing purposes. The floppy cable works fine. The IDE cable works fine on most boards but doesn't on some. It's a good quality indicator - if it does not work, the board is probably crap.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            yes
            • Tom41
              • Oct 2005
              • 336
              • England
              Do you mean like this tower I have? (left of picture)
              https://www.badcaps.net/forum/attach...achmentid=2724
              AFAIK, the floppy cable in that machine is no longer than in other PCs I've seen, ones that have the floppy drive in the middle (often next to the power button).
              Oddly, both my P3 and Athlon 2GHz machine have the floppy drive in the centre of the tower, but the Athlon 1GHz machine (used to be running WinME, now running XP) has the floppy at the top!
              You know there's something wrong when you open your PC and it has vented Rubycons...
              • WNG
                • Sep 2006
                • 354
                That looks like an In-Win full tower. I had a similar one but sold it recently along with the extra long cables it came with.
                I think mine was 29" long. Had I kept it, I would've been happy to give it to you.
                “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
                We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
                • Maxxarcade
                  • Jul 2006
                  • 973
                  My case is actually an Inwin Q2000AX. I've been trying to find another one because I like the layout, but they seem to be discontinued. I think it was one of the last cases I bought that actually had some weight to it. I think it was approaching Lian-Li price range though...
                  EDIT: The bottom pic was taken before I upgraded my motherboard... The new one has a 24 pin plug right on it, so that cheesy adapter isn't there anymore.
                  The Zippy PSL-6700P power supply was a bit tight, even in this big case. BTW I bought that power supply after seeing a post about the internals of it here
                  • pentium
                    • Mar 2006
                    • 2778
                    Damn son, you have a lot of space above your PSU.
                    Find Nedry!
                    • eccerr0r
                      It's 2025: do you know where your 5¼" floppy drives are?
                      by eccerr0r
                      Oh wow.
                      As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                      Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                      Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                      Weird. Seems the PC drive is having trouble clamping...
                      07-07-2025, 12:49 AM
                      by momaka
                      03-12-2025, 03:42 PM
                    • goodpsusearch
                      Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
                      by goodpsusearch
                      Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
                      First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
                      05-05-2024, 02:04 PM
                    • eccerr0r
                      failing hard drives after sitting for years...
                      by eccerr0r
                      With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                      Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                      Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                      03-02-2023, 10:33 AM
                    • abajor
                      Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                      by abajor
                      I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                      I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                      The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                      Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                      04-23-2024, 11:43 PM
