Supermicro curse strikes again
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    #81
    Re: Supermicro curse strikes again
    nice score.
    did one up for a local business a few weekends ago.
    the "ablecom" power supply gave up.
    total recap fixed that.
    still a lot of life in that platform.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Board came in, I can boot from it's chip but since the EATX versions didn't have a SATA version my onboard SATA is non function (can't boot from HDD).
      I also can't hotflash as phlash16 sees the board as being the wrong model when I use the DAE chip and when I hotswap a different chip, it whines about memory managers being in place.
      Also, Uniflash isn't working right; I tried copying the DAE image off the chip and then wrote it to the ebay chip and the chip doesn't boot anymore. good thing I didn't try it with the DAE's chip... I think the issue is the bootbock BS.
      So, it looks like short of cannibalizing a non-EATX X5, I'm SOL (For some reason I remember trying to get a chip from supermicro and it not working out?). Damn.
      Edit- what the hell, I tried emailing supermicro. Wish me luck.
      sigpic
      (Insert witty quote here)
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        When I built the replacement system for "big mama", the new SM board had a BIOS quirk that caused it to not allow it to boot from my 3ware SATA RAID controller. I emailed them, within an hour, they sent me a BIOS revision that wasn't even released yet, flashed, problem solved. My point, their support was superb!!
        Good luck!!
        I got an email from the seller I bought this latest SM experiment from, it shipped today. I guess that BIOS from that board won't do you any good if it can't be cloned and/or hotflashed.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Good luck!!
          nope, all X5DAL's use the same BIOS image. The X5DAE/DA8 use a different image though (SCSI addons instead of SATA addons). So, no pressure, but indeed an X5DAL-G chip would be a drop in replacement.
          sigpic
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            Yes, i know the chip would work...but that would simply render another board dead, theres nothing to be gained unless the BIOS can be replicated. Did you test that other board to see if it works?
            Team : 49813
            Join in!!
            Team Stats
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              As I don't have another set of coolers, no.
              Supermicro told me it's too old but to check with the RMA dept. just to be sure.
              Dun dun dun... She may be dead. and I don't have another EATX case. damn.
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Found a place that has blank chips:
                https://www.rocelec.com/parts/results/all/?s=N82802AB8
                Too bad they require $50 minimum... damn. Now I see why BCN was born!
                edit- some place called freelance electronics has one in stock... for $10. $10 minum order... I'll try it. Hell,what's left to lose here?
                edit2 - NM, as if I can't write the DAL bios, then what for? the link to ^ is here btw:
                http://rcfreelance.com/searchresults...mber=N82802AB8
                I'd need another bIOS chip with the right bios to boot up, and then use the blank to hopefully write. TC, If I shipped you a chip, would you be dumb.. er, I mean kind enough to try a hotflash? No pressure but I had to ask.
                sigpic
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  Sure, send it to me.....with a lab rat board to try it on, nothing to lose. My shipdesk machine was a different story....but this other one, yea, if I hose it, I wouldn't lose any sleep.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Well well well... SM says $20 shipped for a chip. I have to fill out and scan in a form but for $18 + $2 shipping a chip is mine. Easy fix IMHO... I'll also order a blank chip probably and try to hotflash a backup (so I can mod one with SLIC w/o the risk of a complete fuckup like I've seen).
                    Anybody want to buy/take an X5DAE with 2 CPUs and a mangled cooler mount (somewhat mushroomed)?
                    sigpic
                    • brethin
                      • Dec 2008
                      • 1907
                      I am interested, I could use another machine with PCI-X slots as a server for my 64bit Firewire 800 cards and external drive bays. Send me a PM with the details and what you want for it $ wise or if you need something in trade.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16959
                        My SM bargain arrived, and just like I thought....tossed a GPU and some RAM in it and away it went....so if you need a BIOS copied, I've got a good one...but a fresh chip directly from SM, I don't think that will fail....unless you put it in backward or something...
                        Thanks for the heads-up on the ablecom power supply. this one works, but I guess it needs to come apart to be recapped....I wonder if I know someone that can do that?!
                        Team : 49813
                        Join in!!
                        Team Stats
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Yup. The chip is in the mail.
                          sigpic
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            #93
                            just remember to not grab the soldering iron by the pointy end!
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              #94
                              Waaaa?
                              • i4004
                                • Oct 2006
                                • 2029
                                #95
                                clever (russian?) girl, she knows such a big iron makes no sense, so she's trying to make a pencil out of it!
                                <wink>
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  WTF happened to my thread?
                                  Once I get the chip and get it installed it will be back on topic.
                                  sigpic
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16959
                                    LOL...I hope so!! You'll have un-done your goofup that you blamed on Supermicro!! Remember the BIOS Savior from yesteryear? Those were awesome back in the days of experimenting with CPU microcodes, memory timings, and onboard peripheral firmwares (usually RAID controllers). Might try to find one before the next BIOS hacking experiment.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      the only devices from yesteryear that I know of is POST cards... I'm too young and my dad didn't do BIOS mods or anything super hardcore like that (hence why I never was exposed to such). I will see about obtaining such...
                                      (I never blamed supermicro... I was referring to a personal curse after a PDSGE went belly up not too long prior).
                                      sigpic
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        It uses the RD1-PMC4 kit... which, like all other Bios Savior kits, is out of production and from what I could find unobtainium. Damn.
                                        sigpic
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          Yay:
                                          http://www.ebay.com/itm/INTEL-N82802...item2c8be38b24
                                          made an offer for two of them... cheapest source yet. I'll try to hotflash those off the new chip from supermicro and then, if they both work after the fact, I'll use one of them for modding (the SM sourced one will stay stock).
                                          sigpic
                                          • ugamazing
                                            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                            by ugamazing
                                            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                            08-31-2022, 07:34 AM
                                          • feherhollo
                                            WSON8 NEW Bios Chips READ, ERROR, ETC.
                                            by feherhollo
                                            I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                                            I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                                            For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                                            11-26-2023, 09:33 AM
                                          • Prott
                                            [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                            by Prott
                                            Hello dear badcappers!
                                            The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                            Backstory:
                                            After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                            If there is a way to narrow down which memory module is faulty it would make my life much...
                                            06-03-2024, 12:05 PM
                                          • LukeDavis
                                            Is there a list of known dodgy ATI Radeon chips?
                                            by LukeDavis
                                            Hello again! (People are likely going to get tired of seeing posts from me lol)
                                            I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                                            While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                                            1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                                            2. ATI Mobility Radeon X1600 and the...
                                            02-16-2024, 04:34 PM
                                          • piernov
                                            NVidia bumpgate
                                            by piernov
                                            Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                            Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                            May complete this post at a later date with more details.
                                            Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                            03-27-2021, 10:34 AM
