esr meters
  • MORPHOGEN
    • May 2014
    • 14
    • scotland
    esr meters
    Hi would you advise me on not buying an esr metere from ebay. Im not seeing many shops thst sell them in the uk does anyone in the uk know where i would get a real one from and a trusted shop seller.
    Also do i need any other kinds of meters too check my motherboard for shorts etc .
    Thanks in advance im just a beginner but would like too learn.
    You can only get better by playing a better opponent. Teach me.
  • trebo
    • 514
    • Wales, UK
    Re: esr meters
    I bought my ESR meter from Maplin they have stores all over UK
    its a Peak Atlas esr60, they can be upgraded to the newer version for a price by the manufacturer, it reads Capacitance as well
    a good Digital multi meter is priority, but its best others recommend what one, good ones come at a cost
    • JJR
      • Mar 2013
      • 171
      Re: esr meters
      I bought this model last year, used it a few times, works ok.
      http://www.ebay.co.uk/itm/new-Capaci...item4acd010b5b
      • MORPHOGEN
        • May 2014
        • 14
        • scotland
        Re: esr meters
        Yeah thanks. I seen some on ebay but looked like foreign junk home made fakes. Ill check out the maplin store.
        • MORPHOGEN
          • May 2014
          • 14
          • scotland
          Re: esr meters
          Yeah i seen those jjr i wasnt sure on the quality thanks for the reply.
          I think i posted this in the wrong section immsorry.
            Re: esr meters
            I bought version 1 may be 2 years ago for the tech to use, just bought v2 last month.
            https://www.badcaps.net/forum/showth...888#post443888
              • 31157
              Re: esr meters
              hey, what happened to the russian guy selling the dual-display esr+uf unit?
              • Mess
                Beginner question. Did I find a short?? HP dax31mb1aa0 REV A motherboard
                by Mess
                Hi beginner here, so I'm not sure of I've done this right 😅 trying to diagnose my laptop's motherboard (dax31mb1aa0 rev a). I don't quite know how to read the schematic, so I'm attaching the pictures of the motherboard and the measurements.
                I was attempting to measure resistance to GND on inductors. I disconnected motherboard and used "continuity testing" setting on my multimeter. I put black probe to Ground & red probe on an inductor. Did I measure this right? Am I correct to think that 0.3 ohm measurement indicates a short circuit? Thank you for your help!...
                09-15-2024, 09:56 AM
              • howardc64
                Where do repair shops buy MB replacement batteries?
                by howardc64
                Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                07-25-2024, 10:42 AM
              • dbuergi
                MacBook Pro A2338 liquid damage repair for a beginner?
                by dbuergi
                i have a A2338 with water damage on the logic board. Cleaning it showed some heavier corrosion around U7000 and surrounding caps. Some are totally broke.
                I get 5,2v when using both USB-C Ports but until now i didn't make any more tests.
                Since i'm a beginner i want to know next possible steps. I'm not afraid replacing the intersil 9240hi but the other parts with 1mm or 2mm scare me and i don't know where to get replacements.
                I fixed other laptops but this ist my first apple device ....
                07-24-2024, 09:48 AM
              • Bladiblad
                HP RTX 3060 with bad cap (beginner project)
                by Bladiblad
                I have an interesting project here. I have a HP RTX 3060 12GB VRAM GPU with a shortcircuit between a (what I believe is) a coil and a cap. The short circuit is so bad that it will trigger a failsafe on the PSU.
                I'm a beginner in this field and have managed to do only very simple board repairs so far. I have basic understanding of the components (mosfets, caps, nand chips) but completely diagnosing a board with schematics would be challenging. In this case though, I'm going to hope that replacing only the two shorted components will bring the card back to life (if none of the IC's...
                06-14-2024, 06:42 AM
              • CanukTuk
                Beginner Tutorial for using RCUnlocker to remove BIOS password?
                by CanukTuk
                Kinda new to this, so hoping you will all give me a bit of a pass.
                I came to this forum because need to remove the BIOS password on an HP EliteBook 850 G1.
                I understand that I need to dumpt the BIOS to a dump file, process the dump file with RCUnlocker, then write the modified BIN file back to tthe BIOS chip.
                Is there a beginner guide anywhere that describes the entire process for doing this?
                I am reallly in the dark regarding which tool or tools are required to extract the BIOS dump file, then write the modified BIN back to the BIOS chip. The guides I have...
                03-24-2024, 02:54 PM
