ATI x1650 AGP card fan LOUD
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    This is a pretty good old graphics card that performs well for gaming, however the fan is very loud. Is it safe to slow it down or even turn it off? Even after running a game for hours it never gets into the red zone on the Catalyst Control Center temp meter with max "ATI Overdrive" clocking. I've cleaned the heatsink fins, the fan has been lubed, but it has always been very loud since day one and still is. If I slow it or unplug it I can throttle the clock settings down to min and I'd think that would help. I'm not so much interested in running it overclocked as I am in using it for its 512MB RAM and eliminating the use of integrated graphics but it is just too damn loud.
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: ATI x1650 AGP card fan LOUD
    If it's only a two wire fan it probably runs at +12V all the time (full speed), which is why it's loud.
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      Yes, it is a two wire.
      • brethin
        • Dec 2008
        • 1907
        Do not turn the fan off or you will cook the card.
        You can slow the fan down if you have good case cooling and that will help, just make sure you monitor the cards temp.
        You could also replace the fan / heatsink with water cooling if it being loud bothers you more than the $ it would cost.
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          Thanks yous. I don't want to fry the GPU so I won't run without the fan at all. I tested the fan with the card out of PC running on 5v and it starts up fine and spins very nicely and much quieter and still moves air. The PC case I use it in runs pretty cool. I'll try it out running at 5v rather than 12v and monitor the GPU temp and see how she does.
          Steve
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            I have it doing fine on 5v now. Not getting any hotter than before and is much quieter.
              • 31204
              if you have the space, you can get better sink/fan units for gpu's
              i dont know what yours looks like,
              but i have an ati 8960 here that i retro-fitted wih a thermaltake blue-orb.
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                Well, space is a limitation. This is in a Dell GX270 which is the only 1/2 way decent computer I have working with an AGP slot. The card is too tall to fit unless I leave the top 1/2 of the case opened, which of course makes the PSU and CPU fans louder too. Anyway the GPU fan is much quieter now so it's not nearly as loud at 5v as when the fan was running on 12v, and I can live with it for the time being. Now all I hear is the CPU and PSU fans. I may buy or make and AGP slot extender and mount the card in sideways so I can close the case.
                  master hoarder
                  • May 2008
                  • 12175
                  You should have checked the GPU temperatures before doing the fan mod. And don't trust the Communist Control Center - that software is a piece of turd. A "red zone" means nothing. For all you know, that could be at 80C+, which is way too high for any BGA chip.
                  Use either Speedfan, GPU-Z, or RivaTuner to monitor the temperatures of the GPU (you may have to try all three, since not every one of them is able to read the GPU sensors properly). If GPU is over 60C idle, I would strongly suggest you leave the fan as is - that is, if you want that video card to last. Alternatively, you could try 7V (red fan wire on 12V and black wire on 5V) or 8.7V (red fan wire on 12V and black wire on 3.3V).
                  If nothing, try a different heatsink. Possibly a 2-slot one if it fits. The X1650 isn't exactly power-hungry, so you don't really need a huge behemoth either.
                  Post some pics of the video card's heatsink. If you're crafty, you can mount a CPU heatsink on there and that should keep the temperatures low even with a very slow fan.
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    Sorry I missed your reply until now. Better late than never Thank you for the advice.
                    I did check the temps before and after the mod and I have since run the software you suggested. SpeedFan does not read the GPU info that I can see. GPU-Z does and it agrees with Catalyst. RivaTuner also is not showing temp data.
                    I've had the fan running on 5v for a month and no ill effects, no over heating, it stays about the same temp as before so I'm not concerned about it now. I will probably move this hardware all into different case so I can close it up properly and put the GPU fan back on 12v then. I need to get it all in a bigger case anyway now that I've decided that this setup is working well for me.
                      • 31204
                      RivaTuner is for nvidia chips.
                      • SteveNielsen
                        Retired Tech
                        • Jun 2012
                        • 2327
                        Yeah, I know but it does detect my ATI card and shows quite a lot of information about it, just not any temperatures.
                        • mitsus78
                          • Jul 2014
                          • Greece
                          You could try passive cooling.Something like this:
                          http://www.arctic.ac/eu_en/accelero-s1-plus.html
                          • c_hegge
                            • Sep 2009
                            • 5219
                            That wouldn't fit in to the OP's GX270 case
                            • mitsus78
                              • Jul 2014
                              • Greece
                              oops, you are right. I didn't notice that
                              • ThePCDoctor
                                Retired Tech.
                                • Sep 2011
                                • 59
                                I had (still have) a video card that I really liked, but....
                                it had one of those tiny little fans that set down inside the GPU heatsink.
                                I had cleaned and re-oiled it several times and one day I noticed it was not turning at all. It was frozen solid. I was surprised that the GPU was not fried. A web search for that little fan was not forthcoming, so I did what I usually do with any such problem.... I got innovative!
                                I removed the two-wire fan from an old K6 CPU cooler and after removing the OEM fan, I glued the new fan down on top of the heatsink, with my HOT-Glue gun.
                                It not only kept the GPU nice and cool, but it was as quiet as a "mouse blowing bubbles in a feather bed". That was several years ago now, and that Vid card is still working in my backup PC. Total Cost=$00.00 , because I used spare parts I already had in my junk box.
                                So when life gives you lemons..... make Lemonade.
                                Cheers mates!
                                The Doctor
                                Experience is truly the best teacher.
                                Backup! Backup! Backup! Ghost Rocks!
                                • TCB
                                  • Jul 2014
                                  • 8
                                  I have saved more than a few video card fans (from being noisy and from being inop) by disassembling the fan after removing from the card, cleaning it well, then adding a drop or 2 of machine oil in the pocket where the fan spindle mounts into the motor assembly and reassembling.
                                  Just a suggestion.
                                  Hope it helps someone :-)
                                  TCB
                                  • SteveNielsen
                                    Retired Tech
                                    • Jun 2012
                                    • 2327
                                    Thanks for the suggestions guys. I've repaired and replaced some fans before so I know those methods. I don't have a suitable fan for replacement and due to the mounting I have been unable to remove the fan for repairing it. I think the sound is more due to the size and design of the fan and heat sink than anything else. It has always been noticeable sound. Running it off the 5v source has worked out well so far, however in doing so it bypasses the fan speed control on the card so I don't really like that even though it has been working fine at keeping the GPU at a good temp.
                                    What I am planning to do is take the motherboard out of the GX270 case and put it in a Dimension 2400 case. I haven't checked yet but I hope the MB will fit that case. If so everything will fit inside properly and be in a closed case, then I will move the fan back to the original connection and see how it sounds. I may try again at that time to pull the fan off and service it.
                                      • 31204
                                      one problem you may find doing that is the base the heatsink screws down onto is probably the gx270 case and not a X-frame on the bottom of the motherboard.
                                      i know the newer machines are like that.
                                      so you may need to salvage a heatsink mounting base from a dead atx motherboard.
                                      • SteveNielsen
                                        Retired Tech
                                        • Jun 2012
                                        • 2327
                                        Thanks for the heads up on that. I am currently using the GX270 and the 2400 is the only other working PC not in use so I'd have some down time here. I don't like down time. The other working PCs I have are in use by my wife and daughter. There are other cases I could conceivably use but I don't care for them for various reasons. They are basically just being parts holders of old mobos and PSUs right now, i.e. they're junk waiting to be cannibalized.
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                        • Kemer
                                          Graphics Card mounting frame
                                          by Kemer
                                          Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                                          As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                                          I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                                          What worries me right now is the possibility that...
                                          09-14-2024, 08:57 AM
                                          HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                                          This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                                          09-06-2024, 08:30 AM
                                        • FZG
                                          EVGA Nu Audio Sound Card - Not Working
                                          by FZG
                                          I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                                          The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                                          I found...
                                          03-07-2025, 11:44 AM
                                        • benwaterson
                                          Gigabyte Aorus 1080ti - card not initialising
                                          by benwaterson
                                          Hi there.
                                          Have searched various forums but haven't come across the exact issue I am having.
                                          Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
                                          I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
                                          Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
                                          02-05-2022, 11:42 AM
