Paper tape readers
  • pentium
    • Mar 2006
    • 2778
    Paper tape readers
    It's not the most modern, it's not the most compact but for them good ol' 8-bit systems they are truly unique.
    I was looking through a book talking almost completely about mods and other cool things you can do with your TRS-80 (dated 1982) and one cool thing I came over was a partial schematic for a paper tape reader. That had me thinking about what to do next.
    I then saw this and realized that I could finally make some use of my jar full of 555 chips and other cool IC's I got when our school was cleaning it's shelves.
    Now even though I only have a little bit of google, that manual and the small amount of photos and partial diagrams that made mention to the Raeco TPR-1, I still need info on some of the precise parts.
    -What's the LED spacing between holes? Is a special LED needed?
    -Punch tapes are 1" wide, right?
    -What speed should the tape be fed at?
    Uh oh. There goes the bell. I'll finish off later.
    Find Nedry!
    Check the Vending machines!!
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    Re: Paper tape readers
    you need a girlfriend..........
    actually, sounds like something cool to do just for the hell of it. my problem is that i'm a good project starter.....baaaaaaad project finisher.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
    • gonzo0815
      • Feb 2006
      • 1600
      i totally agree with that.
      • pentium
        • Mar 2006
        • 2778
        No. First a NeXT cube and THEN a girlfriend.
        I looked over the schematics again and found that there were a few component listings hidden off to the side. I managed to copy it down onto a sheet of paper and I now have the schematics and a full parts list. The only items I worry about is the two IC's (4502) the lamp block (MRD150) and the track that the tape lays on while it is being read. That looks like it would need to be machined. Besides those parts, it's a very simple project (Only two IC's and the rest is just resistors, framing and soldering.
        If my scanner was working I would post it.
        Find Nedry!
        • Paul S
          • Sep 2006
          • 326
          I used to run CNC (Computer Numerical Control) machines in a machine shop. I went to night school to learn to program them. They first taught us how to program the old NC machines that used paper tape to hold the programs. We learned how to read the tape directly, just by decoding the punched holes.
          Maybe you can find an old NC tape machine and use the reader from it.
          I may still have my old schoolbook from that class.
          • pentium
            • Mar 2006
            • 2778
            Do you know how rare it is to find the paper tape itself, let alone the reader?
            I wonder if I can not only interface this with the TRS-80 but also my apple IIe, Vic-20, C64 and one of my older pc's.
            Find Nedry!
            • Paul S
              • Sep 2006
              • 326
              Did you know that there is a wiki on paper tape?
              http://en.wikipedia.org/wiki/Paper_tape
              Also, here's some images of the machines used to punch them.
              http://blinkenlights.com/classiccmp/friden/
              Most of the paper tape machines were tossed in the junk pile years ago. But, some tech schools may still have one in a back closet . Check with the CNC training departments.
              P.S. I found a source for tape.
              http://www.wncsupply.com/paptape.html
              • pentium
                • Mar 2006
                • 2778
                Hey thanks for the info.
                I have been given clearance to use the milling machine once my metal shop project is done. I can then make the paper track which will keep the paper and the sensor aligned. I still need to know how wide the average roll of paper tape is and the spacing of the holes and their sizes.
                Find Nedry!
                • Paul S
                  • Sep 2006
                  • 326
                  There was a link at the wiki to paper tape specs:
                  http://www.srcf.ucam.org/~jsm28/ECMA-10/
                  There are two sizes 1" (25.4mm) and 5/8" (17.45mm)
                  There even is a description of the tape reading mechanism, with exploded view diagrams.
                  • pentium
                    • Mar 2006
                    • 2778
                    How did I miss that link?
                    Yay! I now have all the info I need to make the paper track.
                    Find Nedry!
                    • Paul S
                      • Sep 2006
                      • 326
                      I'm not sure how you will make a punched tape, but the machine that I used, in my CNC class, looked something like this:
                      Teletype ASR33
                      or this:
                      Flexowriter
                      I came across this page of a CNC book, it has some more tape specs:
                      CNC Progamming Handbook
                      As a side note, I actually worked at a company that made some of the original NC Tape Machine Centers, Kearney & Trecker. It was in the late 1970's, and tape machines were no longer being made. But they had a large number of them in the shop, that they used to make parts for the newer model CNC machines.
                      I ran a DeVlieg Jigmill and did the final machining on the gearbox (knee) for there line of manual milling machines ((K&T milling machine). When my machine was down for a while, I was assigned to clean the offices. I remember the room where they punched the tapes. They used a plastic type tape (Mylar?) and the little pieces that were punched out were all over the carpet. They were very difficult to vacuum up!
                      That's about as close as I got to the tapes.
                      Paul
                      • pentium
                        • Mar 2006
                        • 2778
                        I heard our local archive has a few rolls of punched tape but no reader.
                        Heh, I like seeing how paper tape rally helped CNC machines in the early days. So far that's the only place they seem to have been used en mass.
                        Find Nedry!
                        • PeteS in CA
                          • Aug 2005
                          • 3579
                          • USA, Unsure of Planet
                          I remember seeing board testers being run by paper tape when I was at Kaiser Electronics (now part of Rockwell, iirc). This was back in the late 70s. Kaiser made/makes display avionics for military aircraft. The project that used the tester was for the F-14, which means the machine was an at least an early-mid 70's design. I don't remember whether a version of the tester was used on boards for the 60s-vintage A6 project. I worked on the F-18 head-up display (I saw HUD S/N 001 go out the door) and A-10 projection unit projects.
                          PeteS in CA
                          • RetroComputingGrotto
                            IBM LTO 7 Tape Drive - Dust Sensors??
                            by RetroComputingGrotto
                            I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                            I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                            09-19-2024, 01:54 AM
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
                            HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio ProDesk 400 i5-6500 Specification for Upgrade or Repair
                            This specification for the HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio boardview and ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                            09-12-2024, 03:28 PM
                          • triplefour
                            LG 75UN8570AUD panel issue fixed with tape.
                            by triplefour
                            I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                            add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                            07-17-2023, 10:22 PM
                          • CapSnap123
                            Sensor on Aurora AS1018CD paper shredder doesn't work
                            by CapSnap123
                            I'm getting frustrated troubleshooting a paper shredder. The way the shredder normally works is when you turn the power on, nothing happens until you insert a piece of paper. There is an IR shredder in the shredder and inserting the paper breaks the beam and starts the shredder motor. But now the motor runs constantly, even when no paper is inserted. I've replaced the photodiode and the IR emitter. Also the relay makes a nice clicking sound so I assume it is working too. I don't know what else to check. Here's a photo of the circuit board. The red and black wires marked IR - go to the...
                            04-20-2024, 03:57 PM
