External Drive Enclosure
  • davg
    • Sep 2008
    • 536
    I have a HP media bay drive enclosure with a 500g sata hard drive that just quit?? I get a message "the usb device not recognized?? I have connected my HD inside my computer and it works fine so the fault is with the enclosure?? I can connect a 30 gig laptop drive and it works fine. It sure sounds like a power supply problem any ideas what to look for?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: External Drive Enclosure
    yes, it sounds if some power rail has sagged out of limits. is this that hotswap wannabe on a HP desktop or is it the real (4 bay) thing here https://h30094.www3.hp.com/product/s...tno/661618-B21?
    Follow the white rabbit.
    • davg
      • Sep 2008
      • 536
      Its the hot swap for HP Desktop, a personal media drive that can be either used in a media bay or just used as an external enclosure
      • davg
        • Sep 2008
        • 536
        Like this one
          • 31159
          so open it and lets see the guts!
          • davg
            • Sep 2008
            • 536
            Thanks as soon as I get an opportunity I will post some pictures in the meantime it has a cooling fan and I am not sure it is spinning up?? could this cause the problem?
              • 31159
              unlikely - does it have a tacho output?
              • davg
                • Sep 2008
                • 536
                I did check the fan and it do work. so your are right not likely the problem No tech output that I can see.
                • davg
                  • Sep 2008
                  • 536
                  As promised here is some pictures
                    • 31159
                    nice.
                    plug the psu in,
                    and meter the voltage on the 2 things that look like regulators - u13 and u14
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5014
                      • New Zealand
                      U2 looks like a DC-DC converter with that big diode and inductor connected to it
                      -David VanHorn
                      • davg
                        • Sep 2008
                        • 536
                        Originally posted by stj
                        nice.
                        plug the psu in,
                        U13 looks like BA33P reading left to right (with ground on top) Black on center pin, red on pin 1- 3.297v and red on pin 3 - 5.11v
                        U14 looks like CB18p reading left to right (ground on top) black on center pin red on pin 1 - 1.783v red on pin 3 - 3.296v I don't have a date sheet so not sure which pins are in or out
                          • 31159
                          pin 1 is output - and they seem o.k.
                          they are 1117 compatable 3v3 and 1v8
                          i suspect the initial 5v is from the switching supply mentioned by agent24
                          so power-wise that only leaves the 12v to check.
                          i cant see any access to the connector solder-joints - best to plug it into a harddrive & meter the connections on the drive-side.
                          it's the wide-part.
                          did you try it with a 3.5inch drive, or a 2.5inch one?
                          2.5 wont need 12v.
                          • davg
                            • Sep 2008
                            • 536
                            Reading 5.17v only. 12v is missing?? 3.5 inch drive will not work a 2.5 inch drive will work just fine
                              • 31159
                              then you found the fault - trace the 12v contacts back & see where they lead.
                              • davg
                                • Sep 2008
                                • 536
                                Success!!! at least temporarily?? The fault is with a ribbon cable that connect the front and back boards. This cable has separated from the board with the sata connector dropping the voltage to that board. I am not sure if this ribbon cable was soldered to the two boards or just glued in place?? right now I have soldered it but it don't look pretty however it do work but sometime I get a message "the hard drive need to be formatted before use"
                                  • 31159
                                  maybe it's pulling too much current for the connections - see if the 5v & gnd have the same poor looknig connections.
                                  • davg
                                    • Sep 2008
                                    • 536
                                    Thanks stj.Yes it do and I will be going back over the thing later to try and fix up the poor solder job (soldering not my specialty)
                                    • davg
                                      • Sep 2008
                                      • 536
                                      I just tried the original 500 gig 7200rpm drive in this unite and I am still getting "the usb device is not recognized" (The drive do work connected inside my computer) Also I but in a 250gig into this unit and it will work?? I have not re-soldered yet
                                        External hard drive/cd rom enclosure-printer port interface recap power supply board
                                        by sam_sam_sam
                                        I going to modify the enclosure to except the new USB 3 interface
                                        The 3.5 enclosure do not have internal switching power supplies and use a small switching wall wart power supply really
                                        I need a cd rom drive for my new computer and do not want to use a 2.5 cd rom drives
                                        The switching power supply in the old enclosure has nice heat sinks and has a cooling fan in the enclosure that is the main reason why I want to repurpose for this project
                                        https://www.ebay.com/itm/231205428647
                                        I will post some pictures of it when I get the usb 3 to IDE...
                                        04-08-2023, 05:42 PM
                                      • eurowill
                                        a2141 820-01700 internal display not working / external works
                                        by eurowill
                                        Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
                                        Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
                                        07-23-2024, 10:06 AM
                                      • m710q_flash
                                        Toshiba HDTW230XS3CA 3TB external drive died
                                        by m710q_flash
                                        I had been using this hard drive for a while, and it worked fine only going back and forth between 3 computers.
                                        Plugged it into an older computer that happened to have a really loose USB port. Light flashed once and died, never to be powered up again. Not sure if it's relevant that the USB port was loose.
                                        Anyway, now it doesn't power up at all, it's been sitting on my desk for years and figured what the heck, nothing to lose as I'm not going to pay someone to fix it, maybe I can learn something from it.
                                        Removed the case, figured I would look for anything...
                                        11-01-2023, 12:28 AM
                                      • federalhouse
                                        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                        by federalhouse
                                        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                        **Background:**
                                        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                        **What I've Tried So Far:**
                                        1. I accessed
                                        08-01-2024, 07:03 PM
                                      • perfm2
                                        HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                                        by perfm2
                                        So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                                        Steps taken in my usual process.
                                        Reset security settings in the BIOS
                                        Ensure existing HD comes up into the OS
                                        Shut down the laptop and disconnected the main battery
                                        Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                                        Replace battery connector and close up the laptop
                                        Insert my USB drive with my Windows 10 image I've...
                                        03-21-2023, 08:45 PM
