looks like the registry is going screwy...
  • pentium
    • Mar 2006
    • 2778
    Fater many hours of work I was halfway through configuring and fully installing all the hardware and software for my new dual PII system when the unthinkable happened.
    I had finished installing the creative MPEG decoder card and was powering the system on and was finishing boot.
    It first started with an error window after login:
    Originally posted by RUNDLL
    Error loading mmsys.cpl
    Invalid access to memory location
    Noticing that my sound control panel was gone, I checked the device manager and shure enough my sound card was having a problem. the problem was that the registry was corrupted. That was it.
    I then tried to remove the bad driver and was halted almost at once:
    Windows could not load the installer for MEDIA. Contact your hardware vendor for assistance.
    It then gave another window saying that it could not be removed and took me back to the device manager. I thought of a bad driver so I opened IE and almost instantly it froze up.
    I had to end it and then I kept on looking around. I then went to the administrarot control panel and this time the entire control panel froze and ending it caused explorer to reload.
    Now i knew something was wrong.
    I had not yet installed norton system works and so I popped the install cd in and when autorun started I got this:
    The application failed to initilize properly (0xc0000005). Click OK to terminate the application.
    I then tried an older copy of system works and got the same error.
    I then opened my computer and tried manually opening the setup but after a moment, my computer froxe and I had to end it and make explorer reload.
    I then tried windows explorer and once again it froze up.
    I finally made success by manually running norton system doctor off the cd.
    It meant I had to open the command window and manually locate the program.
    After it was done testing. I fixed the errors it found (not many since no modules were installed on the system to make a complete scan) and then restarted.
    Once again I got the error involving mmsys.cpl and once again, every program froze one way or another.
    Knowing these types of errors they ARE registry problems and I don't know what the hell caused them. I was using drivers designed for windows NT for the sound card but after I removed all the cards I installed, programs were still freezing and complaining about memory locations.
    The installer for the MPEG card driver closed complainging about a corrupt dll and that something was i the memory location it needed to use. I also had safe mode hang while booting and both sticks of ram passed all memory tests.
    So I pretty much can't do anything now and I do not want to reinstall windows. It took two hours just to install all the updates and software needed to get most of the hardware configured and I have not even started with installing software.
    Find Nedry!
    Check the Vending machines!!
  • pentium
    • Mar 2006
    • 2778
    Re: looks like the registry is going screwy...
    It turns out the drivers themselves were the problem.
    I replaced my Vibra 16XV card with a spare AWE 64 and using my driver cd I was able to install the proper drivers. After a restart everything cleared up and I was off and running again. I can't believe a single bad driver caused so many problems.
    Find Nedry!
    • bgavin
      • Jan 2007
      • 1355
      Use GHOST when you build a system, so when it craps out you have a safety net under you. Working the high wire without a safety net is always dangerous.
      If you suspect hardware, etc, another solution is test build your machine under VMWare. The more I use it, the more I like it. VM saved me a ton of CDs during my 3-day marathon to build an unattended XP Pro cdrom with all my registry tweaks.
      • Gibon378
        What caused the BSOD?
        by Gibon378
        Hello there!
        I was doing some usual stuff, browsing the internet, listening to music, coding, etc. and my computer froze. It looked like the website couldn't process the request (logging into the account, there was the loading symbol) and it took a few seconds, then my computer totally froze except for the mouse cursor. It lasted for about a minute and I got the BSOD. It happened yesterday and today (just now).
        I managed to get the MEMORY.DMP content, but I don't really understand it. Could somebody help me?
        Code:
        ************* Preparing the environment for Debugger
        06-23-2023, 06:20 AM
      • phantomEVO
        [help] 820-00840: no ssd, no usb, wifi froze
        by phantomEVO
        i don't know the history of this board…I'm pretty sure that u3900 was touched/changed (i don't know why)
        Motherboard boot with “no disk error.”
        Tried another disk, same error!
        It can't see usb bootable from both usb
        USB stick light stay on fixed
        As soon as i try to boot in Recovery and write the password, it hangs, and then reboot
        any help?​
        03-22-2024, 02:51 AM
      • SluggerB
        Panasonic TH-50PX80 killed by lightning strike, help me save her!
        by SluggerB
        Yes it's a 17 year old Panasonic plasma!
        I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
        06-04-2025, 07:02 PM
      • VcemPzd
        Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
        by VcemPzd
        Hello everyone !
        My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
        04-28-2025, 10:14 AM
      • lapot2
        The Best and Fastest BIOS Flasher for Modding Under $2
        by lapot2
        Recently, the Raccoon Flash Explorer programmer has appeared.
        It allows you to flash BIOS chips from any device without installing programs and drivers, and also very quickly make small changes without a long rewrite of the entire memory to change a few bytes.
        Very easy to use and intuitive, even a housewife can handle it.
        You can use absolutely any system binary file editor (HxD, WinHex, etc…) on any operating system, the possibilities are not limited by the ugly built-in editor like other programmers.
        It has full cross-platform support, works...
        04-21-2025, 09:37 AM
