Ridiculous lengths to install an OS...
  • Elysarian
    • Mar 2013
    • 200
    • United Kingdom
    So I finally picked up a replacement machine for the Dell Poweredge 2600 from ebay, a Gen 4 HP Proliant DL380...
    It's not a massive improvement (it has a pair of 3.6GHz netburst Xeons where the Dell had 2.4's) - the big difference for me is it supports 64 bit CPU's and possibly dual-core ones.
    Problem came with getting Win2k8 onto it - I have a VLK and disk but the machine only has a CD drive...
    No problem you say, make a bootable USB stick - no go, I have none spare and want this machine running ASAP.
    What I did do is copy the relevant files from my install DVD a VM on my desktop machine and set it up as a PXE server
    Nice learning experience for me here as I've only ever done this with desktop OS's in the past
    Anyone able to beat that for convoluted?
  • mariushm
    • May 2011
    • 3799
    Re: Ridiculous lengths to install an OS...
    Years ago, I used to install FreeBSD on servers by using the small installer cd (maybe 20-30 MB). I was simply telling it to download everything straight from the internet.. the university in town had an official freebsd mirror so the downloads were coming through at 100mbps - it was faster than copying from CD
    ... back in the days of 386, a friend of mine was using dos navigator and null modem or other schemes to copy files to other systems, it worked better than using floppies.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Been there, done that.
      I have a pxe boot server I built about 2/3 years ago. I got tired of losing install discs or getting to the point of scratched from over-use and wasting time burning new ones. Now practically all my tools are booted over the network and I keep a usb stick for off-site repairs.
      Essentially I built two PE boot discs from the Windows Deployment Toolkit now known as MDT. With a few batch scripts and a driver pack, one for 32 and one for 64. The batch scripts waits for the network to be available then mounts a smb share and loads additional batch scripts from the share. This allows me to change things without having to rebuild the PE every time I need add something to it.
      One of the batch script is the O/S Selector. whatever I choose, it calls for a batch script that then mounts another smb share with the windows setup files, and executes the setup.exe. Then fromt here typical windows install.
      I also got Windows XP pxe install, I have PE make a partition and format the drive and then mount the xp share, start the setup.exe and specify setup should copy the setup files to the drive. I enter in all the information I need. reboot, tell the famous blue setup to install to C: and boom done.
      The ISOs are about 150MB each, and tftp is butt fucking slow, so I use gpxelinux to grab the ISO from an http server. I keep the large files on a local webserver and linux live disc on NFS.
      It works well enough for what I do.
      • mockingbird
        • Dec 2008
        • 5484
        There's always this option:
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          That reminded me of my first install of Win95 using floppies for a customer that refused to pony up for a CD Drive......wasn't fun and took most the day. Got about 80% through it and ran into the usual bad one....... Thankfully, I didn't have to abort the install, I called a buddy of mine who happened to have the win95 floppies as well and bummed his to finish the install... I charged this guy by the hour. I ended up smiling at the end of the day knowing that it'd have been cheaper for him if he had upgraded his Packard Bell to the 4x CDROM like I tried to tell him.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            What did that even have? If you were installing '95 on it, probably 4 or 8 MB of RAM originally.
            Charged by the hour- bet that taught 'em!
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              It was a Pentium 100 with 8mb that I maxed out to 32MB. Had 72 pin FP SIMM's in it. This has been almost 2 decades ago, and I still remember it... Yea, I think he learned his lesson....I sold him a new machine shortly after that.
              Team : 49813
              Join in!!
              Team Stats
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                I know Arch linux supports some odd install modes... the oddest (which I haven't done before) involves using another arch rig and chrooting to the new root drive. Kinda like the biological process (used by yeast cells among others) called budding.
                sigpic
                (Insert witty quote here)
                • Heihachi_73
                  • 713
                  A CD drive? Does it have a floppy drive and LPT ports as well? Does it even support SATA?
                  • Elysarian
                    • Mar 2013
                    • 200
                    • United Kingdom
                    It has a slot for a floppy drive but none installed - as for SATA... SAS is an option on these machines but no SATA (the CD drive is a laptop format one, I tried a couple of DVD drives in there but couldn't get it to boot from them)
                    This particular server is the U320 SCSI version (I plan to put the 146GB drives from the Dell in it when I have time).
                    It is a rack mount server, not a desktop machine
                    • cheapie
                      null
                      • Jul 2010
                      • 849
                      Debian has that too (they call it debootstrap), and it's the only way to install Gentoo.
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        ohh ohh, I can't imagine you of all people would make me lol today
                          ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                          This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 03:28 PM
                        • CG2
                          Janome DC3050 Sewing Machine Pedal Resistance
                          by CG2
                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                          04-14-2023, 07:53 AM
                        • japlytic
                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                          by japlytic
                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                          Tried (only with keyboard/mouse connected):
                          • BIOS + database update
                          • Using latest Windows 11 image built with official image creation tool
                          • Previous setup version for Windows 11 installer
                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                          06-19-2025, 04:59 PM
                        • Soulzink
                          Samsug washing machine. Power supply DC41-00189a board issue
                          by Soulzink
                          I am trying to fix a samsung washinmachine power supply main board.
                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                          The power supply board reference is the following: DC41-00189a
                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                          04-19-2025, 06:26 AM
                        • 24gsm
                          MacBook Pro A1708 install macos fail
                          by 24gsm
                          hi to all
                          i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                          after enter to recovery and format hdd 1to .
                          after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                          can help please
                          Serial Number: FVFXP0U0HV2J
                          Config Code: HV2J
                          Find My Mac: OFF
                          04-16-2025, 03:57 AM
