Normal temps on a Pentium 4 2.8E (1MB L2, H.T. & 800FSB)
  • grss1982
    • Mar 2007
    • 225
    • Philippines
    First of all specs:
    P4 2.8E
    Intel 865GBF Mobo
    512mb DDR400 (2x256)
    32mb TNT2 M64
    60gb Maxtor HDD
    ATX Case with 2 Fans0 (1 front & 1 rear)
    Enermax (Dual Fan) 350W PSU
    My question:
    Under Intel's Active Monitor thingy I get a 62 C on the Processor Temp with nothing running!!! :-o
    Is that normal for this processor? OR is my cooling setup inadequete?
    Any help is deeply appreciated.
    THANKS. :mrgreen:
    CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
    GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
    Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
  • dungbeetle
    • May 2007
    • 94
    Re: Normal temps on a Pentium 4 2.8E (1MB L2, H.T. & 800FSB)
    Is that with a stock heatsink and fan? Sound kinds of hot. You may want to check it with another method in case the sensor is wrong. I just put a new fancy heatsink on my new pc and it really made a difference. Also used Arctic Ceramic heat sink compound.
    Regards,
    db
    • grss1982
      • Mar 2007
      • 225
      • Philippines
      Yep, its stock.
      Although it quite different from the stock fans of earlier p4's since the one I have now has a copper base?
      Bottom Part of my heatsink is similar to this:
      • dungbeetle
        • May 2007
        • 94
        I just checked my readings on my other pc. Intel board that I just pulled a Celeron 2.4 P4 out and replaced with a Prescott 3.0 P4 and luckily I jotted down before temps (at idle I think) and here is what I got:
        Processor zone:
        Before: 46c-114f
        After: 61c-141f
        Zone 1:
        Before: 37c-98f
        After: 41c-105f
        Zone 2:
        Before:39c-104f
        After: 45c-113f
        So I guess I better get another Zalman 9500LED cooler as that thing keeps my Core 2 Duo at room temp! I guess the Celeron ran pretty cool after all. No wonder its hot in here
        Regards,
        db
        • grss1982
          • Mar 2007
          • 225
          • Philippines
          @dungbeetle:
          AMAZING!!!
          That's the same reading I was geting as well.
          So is my setup in danger of getting roasted? IIRC, Before this the onlly high temp i've ever seen from a rig was 52c on my Sempron 2500+/ECS N2U400A Combo and that was at FULL LOAD!!!
          • dungbeetle
            • May 2007
            • 94
            I don't think you have to worry but I would definitely invest in a good heatsink-cooling option like a Zalman from NewEgg. I got those readings from my bios and now I just installed the Intel Active Monitor (latest version) and my processor is running at 54c. I think I read the Prescotts run hot and the max range is around 70c so that said, I would still get some better cooling The Zalman 9500LED on my other system is most excellent.
            Added: Its also 88 degrees fahrenheit in my room right now. Time to turn on the AC!
            Regards,
            db
            • dungbeetle
              • May 2007
              • 94
              Just a followup with my AC turned on in my room to 78 degrees. My current readings are:
              48 Processor (about the same as before proccessor change 1 degree hotter)
              33 Zone 1 (much better 4 degrees cooler)
              38 Zone 2 (1 degree cooler)
              which is almost back to my Celeron temps. Ambient temperature is an important part of the equation My Core 2 Duo runs at about room temp And you have to remember the fan speed is controlled by the motherboard for the cpu so those reading can and will change.
              Regards,
              db
              • WNG
                • Sep 2006
                • 354
                Prescotts run very hot, hence the earned nickname of Preshotts.
                IMHO, I've not had or seen satisfactory performance from Cu/Al sandwiched heatsinks.
                Improvement is only marginal. Go with an all Cu heatsink.
                “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
                We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
                • grss1982
                  • Mar 2007
                  • 225
                  • Philippines
                  I did, did'nt do much. The all Cu heatsink was a TT Volcano 7+, IIRC.
                  • toastygoodness
                    • Jul 2005
                    • 813
                    that prescott CPU is actually running at average temp. mine runs about that too (maybe 75% that with a gigabyte rocket cpu cooler). my brother's Prescott also runs at that hot. But with those cooling devices you shouldn't worry, unless you live in a humid and hot area like southeast asia.
                    • grss1982
                      • Mar 2007
                      • 225
                      • Philippines
                      Uhmmm....
                      Yeah I do live in Southeast Asia.
                      The Philippines to be exact.
                      Anyways are saying that 57c to 60c temp when your first log in to windows XP is normal, and that 66c to 67c at full load is normal for the prescotts?
                      • Azurael
                        • May 2007
                        • 25
                        My Presler doesn't run THAT hot :o
                        • grss1982
                          • Mar 2007
                          • 225
                          • Philippines
                          Uhmm...
                          I just realized that i might have been quite a n00b when applying the paste to the processor.
                          Reading through the net i found out something about a rice grain or BB size blob of Thermal paste to be applied on the center of the IHS of the P4 proc.
                          I actually applied something like 4 times the size of 1 rice grain.
                          Well do another re-apply tonite, and see what happens. :-)
                          • dungbeetle
                            • May 2007
                            • 94
                            Arctic Silver Ceramic is what I use and you are correct, the size of a grain of uncooked rice or 1/2 of a bb is all you need. For more detailed instructions look here:
                            http://www.arcticsilver.com/ceramique_instructions.htm
                            Regards,
                            db
                            • grss1982
                              • Mar 2007
                              • 225
                              • Philippines
                              @dungbeetle:
                              uhmm...
                              Cpu-z if it helps:
                              Just curiuos why is it running at 1.7v????
                              don't this this run like 1.4v or something?
                              A bios check though revealed taht its was running rought 1.4v to 1.3v.
                              Incidentally when I checked the bios, the proc is identified as a 2.8 "C" not a 2.8 "E."
                              Bios upgrade perhaps?
                              • dungbeetle
                                • May 2007
                                • 94
                                If you go to Intels site and select your motherboard you should be able to see if it will run that processor and if so, sometimes its a BIOS upgrade to fully support it. I had to look at the serial number on a white sticker to verify mine would run the 3.0 Prescott. Definitely check for a BIOS update.
                                I just ran CPU_z and mine is running at 0.800 volts there. Are you running the default settings on your BIOS?
                                Regards,
                                db
                                • grss1982
                                  • Mar 2007
                                  • 225
                                  • Philippines
                                  Yes I am.
                                  Also I did the "rice grain or BB size" thermal paste application and temps have dropped to 58c at startup down from 60c.
                                  0.800 volts? O_o I guess CPU-Z really isn't that accurate when it comes to voltages, huh?
                                  • dungbeetle
                                    • May 2007
                                    • 94
                                    CPU-Z isn't very good. I deleted it already I checked my reading in my BIOS and they are as follows:
                                    +1.5V in: 1.467V
                                    Vccp: 1.329V
                                    +3.3V in: 3.327V
                                    +5V in: 5.236V
                                    +12V in: 11.937V
                                    I was in the middle of e-baying so I just posted what CPU-Z showed Now I had a minute to reboot... It seems like CPU-Z may conflict with the Intel Active Monitor too.
                                    Hope that helps, I am running a D865PERL with a Prescott 3.0 proc.
                                    Regards,
                                    db
                                    • grss1982
                                      • Mar 2007
                                      • 225
                                      • Philippines
                                      @dungbeetle: Thanks for the data.
                                      Anyways, just wondering which one is actually the vocre?
                                      "Vccp" or +"1.5V in"?
                                      Thats exactly the same reading arrangement I have with the 865GBF, but i'm still confused which on is processor vcore?
                                      Anyways, I'm gonna do another re-seat of the heatsink once again, but I will try to use a different thermal paste.
                                      maybe that would help. I HOPE!!!
                                      • dungbeetle
                                        • May 2007
                                        • 94
                                        Vccp is the power supply voltage for the processor core.
                                        Regards,
                                        db
                                        • Instafixx
                                          Macbook A2179 820-01958
                                          by Instafixx
                                          Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                                          The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                                          I checked the Power Sequences below and found this -
                                          Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                                          PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                                          PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                                          05-20-2023, 05:19 AM
                                        • cook
                                          HP Power Supply 6632A: Fast Mode vs Normal Mode?
                                          by cook
                                          FAST MODE vs NORMAL MODE
                                          I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
                                          I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
                                          06-07-2020, 05:32 AM
                                        • eccerr0r
                                          <taps> So long, Pentium III, Athlon XP, and older...
                                          by eccerr0r
                                          Well, looks like they did it.
                                          Rust, the "secure" language used for firefox and librsvg, no longer work on AthlonXP, Athlon, Pentium III (Katmai and older), Pentium II, and anything older. Because of rust's decision to call "i686" at least a Pentium 4 (with SSE2), these older machines have been left out to pasture. Not sure how hard it is to remove SSE2 instructions from rust's instruction scheduler and still produce a working binary...
                                          I've been depending on these old machines to keep on working as they still share the same instruction set...or...
                                          02-09-2021, 01:01 AM
                                        • FShahid
                                          Dell Inspiron 7520 (Intel/AMD) LA-8241P Freezing Issue
                                          by FShahid
                                          Hi I have Dell 7520 which has i7-3632QM as well as AMD 7730M Discrete Switchable GPU.
                                          This is BACO Switchable meaning the AMD GPU can only "render" and cannot work as alone as it depends on iGPU for output.
                                          Attached is the datasheet for LA-8241P which shares common with Inspiron 5520 and Vostro 3560. Link to Schematics: https://cdn.badcaps-static.com/pdfs/...a856347d78.pdf
                                          The laptop has worked flawlessly for last 9 years, with CPU temps never exceeding 90*C and GPU barely reaching 80*C on gaming/full load.
                                          Since...
                                          04-26-2022, 04:41 PM
                                        • beetle1303
                                          Sony KD-65X7000E - Screen double images for first few minutes then back to normal
                                          by beetle1303
                                          I have gotten this Sony KD-65X7000E TV completely dead. According to owner TV was working fine and suddenly blackout and not able to power on again.
                                          Checked and found D751 rectifying diode shorted, replaced and now power up and working almost normally:
                                          1) On power up - display double images, and flicker once every few seconds.
                                          2) After 3-4 minutes at this state - display suddenly back to perfectly normal (although there are few horizontal lines at the bottom of screen).
                                          3) Leaving on for few minutes, power off and on again will repeat the same...
                                          03-11-2023, 02:07 AM
