New Server
  • MixMasta
    • Feb 2006
    • 142
    Re: New Server
    Other things you may want to look at if you are bored...
    Make sure php is installed as a module w/ IIS (probably is)
    Use phpMyAdmin to view statistics about the mySQL server use. Make changes to the mysql cnf file to optimize speed based on whats in red (phpMyAdmin is nice because it highlights potential problem areas in red, though not everything in red is necessarlily bad or fixable)
    Try accessing mySQL with named pipes instead of TCP (I assume you run them on the same computer. this is sometimes trickier then you would think with windows versions of php and mysql, obviously mysql will need to have named pipes enabled in the cnf file. According to the php manual here, http://us.php.net/function.mysql-connect , anytime you use localhost it should try to use named pipes by default. I have however found this to not be the case, and to force it to connect to a named pipe, you should use '.' as the connection string [vBulletin may have this all automated for you already?])
    Anyways, just some tips from a former php programmer...
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      Re: New Server
      I'm the farthest thing there is from a programmer!! LOL The SQL server is running localhost, so I assume (from what I read in the link), I have it configured that way. I was thinking down the road of a backend dedicated database server, but that would be down the road when I build my rack. The buildup for that will be a good 6 month long process, since I am essentially starting from ground zero with my servers again... I miss big blackie already, but with all the sites I run and things I do, I outgrew her....
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Azurael
        • May 2007
        • 25
        Re: New Server
        ...Why Windows?
        Surely some Linux Distro or (preferably IMHO) FreeBSD with a LAMP setup would be more stable, secure and fast. I'll use Windows as a desktop OS, but certainly not on my home server
        Plus, it's not like IIS is well known for its security and reliability. You can run Apache on Windows too, if you must?
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          Re: New Server
          hahahahahahahaha (old joke)
          • MixMasta
            • Feb 2006
            • 142
            Re: New Server
            Whats badcaps average hits per day anyways? Peak concurrent sessions (on non slashdot days!)?
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              Re: New Server
              Originally posted by Azurael
              ...Why Windows?
              Funny. I've had more issues and dataloss problems on linux servers than I ever have on Win servers. This particular one is using IIS, but I do have another winbox running apache (long live virtual hosting). The windows versus linux debate will go on for eternity... Like coke versus pepsi, democrat versus republican, or GM versus ford... I use what I like, as I'm sure you do as well.
              Mix, I'll check the server log and find out, I never really kept track.
              Team : 49813
              Join in!!
              Team Stats
              • Azurael
                • May 2007
                • 25
                #27
                Re: New Server
                I think I'd worry more about IIS than Windows per se... IMHO Windows only has a reputation for being insecure because of idiots configuring it and dodgy hardware (neither of which apply here!) but IIS is amongst the buggiest code to come out of Redmond.
                I don't think the OS debate is like Coke vs. Pepsi; that's subjective, whereas it's basically a proven fact that Linux-based servers have longer average uptimes than those running Windows, whatever the reason for that may be. I can't think of a scientific way to prove Coke tastes better than Pepsi or visa versa. I'm certainly not an advocate for Linux or the mentality behind its development and distribution, however.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  #28
                  Re: New Server
                  you did not take into account what an admin is most comfortable with. Regardless of whether linux has longer average uptimes, an admin should go with the os which he is most competent at and this will result in the best performance, reliability, uptime etc that he is capable of delivering.
                  I question the whole idea of uptime anyway cos if a server has years and years of uptime i would be asking whether its hardware was being serviced and upgraded at all.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16956
                    Re: New Server
                    I agree. I am not impressed by a server with a million year uptime, whooptie doo doo... I cycle parts regularly (mainly hard drives), usually once every year or two. I also reboot when there's updates for the OS. Longest uptime I've had on a win server was 11 months, and that was only broken because the power went out, and the UPS batteries couldn't run it anymore. The 'coke v pepsi' is very comperable to linux versus windows comparisons. In simple terms, some like linux, some like windows. I have nothing against linux, it's a very powerful OS, but I prefer windows. On that note, I've never had a winserver compromised, and I've used winservers since 1997, since that's every linux junkie's first gripe. I guess I'm just a windows brat.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • MixMasta
                      • Feb 2006
                      • 142
                      Re: New Server
                      I assume Topcat is probably using a hardware firewall/router type device like most windows user do (including me). That said, many people don't realize that Windows 2K/XP has a very powerful ipsec firewall implementation that works almost too well (egress is tricky to restrict yet not stop services like dns from functioning correctly). Its buried in computer management, but here is an ok tutorial if anyone is interested (its not perfect and there are a couple mistakes in it that will stop things from working correctly).
                      http://homepages.wmich.edu/~mchugha/w2kfirewall.htm
                      Note: This is not the same as the firewall that comes with Win XP SP2.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16956
                        Re: New Server
                        For a firewall, I've used Neowatch for ages. it does a pretty good job of keeping the bad guys out. I also have things restricted pretty good at the router (cisco 3600 series).
                        Team : 49813
                        Join in!!
                        Team Stats
                        • toastygoodness
                          • Jul 2005
                          • 813
                          Re: New Server
                          not to be a naysayer or anything, but didn't Secunia or somebody release a report that Windows (especially server) had the least security holes? plus uptimes don't prove squat - it's just like saying you can stay up the longest out of all your friends. you may be awake, but you won't be able to function that well. i've always rebooted my servers, whether my win2k3, archlinux, or netbsd server at least once a week.
                          • Logistics
                            • Apr 2007
                            • 721
                            Re: New Server
                            Originally posted by bgavin
                            I run my business off a 384/1500 ADSL line, but I'm tired of the line errors from 40+ year old copper in the street boxes.
                            Perhaps you have a poor connection between the jack and your in-house box. Make some new cables using some extra CAT5, including the cable from the jack to the modem. This is ridiculously over-rated for ADSL, but who cares.
                            • Spacedye69
                              • Nov 2005
                              • 698
                              • US
                              #34
                              Re: New Server
                              Most security issues are caused by configs, not the OS. I agree with Will, run whatever you know best. Windows can be very secure and stable. The problem is, without taking $$ courses or buying a lot of Microsoft Press books, the info on how to do it is poorly documented or not existent.
                              Remember Microsoft pre Win 2000? If nothing else, Linux has improved the OS community by making Microsoft work for their money!
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16956
                                Re: New Server
                                That is true. Windows NT 4 required a lot of editing and configuring to make it secure, and a lot of it was trial and error. Linux at the time was very similar, lots of security holes, and little detailed documentation on how to remedy them. Granted, NT4 was worse in it's time for bugs and security flaws. How-to's and support just was not there for it, and if you didn't take the M$ courses for it, you were pretty much on your own. That all changed with W2K. M$'s site is still pretty useless for tech support these days, but there's so much information out there thanks to Google that whatever you need is a quick search away.
                                Team : 49813
                                Join in!!
                                Team Stats
                                • MixMasta
                                  • Feb 2006
                                  • 142
                                  Re: New Server
                                  Are private message email notifications broken?
                                  • iesaunders
                                    • Nov 2006
                                    • 23
                                    #37
                                    Re: New Server
                                    So what is the new server built around (motherboard etc.)?
                                    • omega
                                      Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                                      by omega
                                      Hello all,
                                      as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                                      Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                                      02-09-2024, 03:34 PM
                                      HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                                      This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                                      09-06-2024, 11:39 AM
                                    • harp
                                      Comparing FreeNAS, FTP server, SMB server, multimedia server...
                                      by harp
                                      I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
                                      I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
                                      Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
                                      What is general difference between this products, and what be most useful...
                                      01-04-2024, 02:44 PM
                                    • Fireballcz
                                      Windows 2016 server L2TP/IPsec VPN - two subnets
                                      by Fireballcz
                                      Hello, please how to properly configure VPN in this environment?
                                      I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
                                      Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
                                      2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
                                      I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
                                      I have no problems with VPN connection...
                                      07-29-2022, 03:20 AM
                                    • ratdude747
                                      Server Upgrade?
                                      by ratdude747
                                      I'm pushing 5 years on my current server and I'm thinking it may be time for some sort of an upgrade.
                                      The main issue I'm having is random ATA errors locking the system up at the most inopportune times. Probably the PATA to SATA adapter (I have a few more NOS ones on the shelf I could toss at it) but honestly I'm thinking an old "early" socket 940 board is a retro rig in 2023 and ough to be retired.
                                      The question for me is how much of an upgrade should I shoot for? The main issue I have to deal with is if I keep my chassis, the backplane is 16x SATA. Not SAS....
                                      01-31-2023, 05:49 PM
