Windows 8 login screen locked
  • 3d0
    • Jan 2014
    • 159
    • BiH
    Hi guys, got this laptop from my friend, his brother died last week. There is lots of pictures, videos and stuff he wants to keep and also wants to continue using it.
    It's running windows 8, or 8.1 don't really know, and the login screen is locked. Is there any chance of removing the password?
    I found this useful ISO:
    Code:
    http://pogostick.net/~pnh/ntpasswd/
    But of course it requires you to boot from either CD/DVD or USB. This laptop doesn't have a built in CD/DVD drive, so I went into BIOS and it has the UEFI logo on the top right, searched all over but still cant find the boot options?
    Guess it doesn't have one?
    Any help would be appreciated!
    Just in case someone thinks its stolen, its not. I'm wiling to post any info/pictures on request.
    HP Pavilion TouchSmart 15-b155so Sleekbook
    Serial: 5CD3023T4X
    Product: D2G63EA#UUW
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Windows 8 login screen locked
    Instead of going into the setup, try the boot menu. It can usually be accessed with the Delete, F10, F12, or Esc key.
    • 3d0
      • Jan 2014
      • 159
      • BiH
      Thanks man, usually I would press F2, or DEL etc. to enter BIOS setup.
      I pressed the ESC key and it offered a menu with various options.
      If F2 is pressed it takes you to the UEFI boot menu options, where you can test components, see system info. and similar stuff. Not what I needed for sure.
      Disabled UEFI in the BIOS, still cant boot from the USB drive.
      Have to check if it's bootable on other pc's.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Pretty much all PCs since the USB 2.0 era (at least since 2004!) should be able to boot from a USB stick.
        And USB 2.0 is old school now! (2002-2003)
        You need to hunt for the boot order settings and make sure to disable "secure boot".
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • 3d0
          • Jan 2014
          • 159
          • BiH
          It was the usb stick that caused the trouble, swapped it for a sandisk and it booted fine.
          Wasted a lot of time testing all kinds of applications, non of them helped.
          Mostly because the account was made with windows live, not a local user acc.
          Finally I found a video that explained a method, and it worked.
          Hack a Forgotten Password on Windows 7, 8 or 8.1 BLUE (DON'T ABUSE)
          Except I used a linux live distro to change the cmd.exe to utilman.exe.
          • hannyadou
            • Mar 2014
            My favourite tool that I have ever used when I lock out of my Windows 7 computer: http://www.appgeeker.com/guide/reset...-password.html
            Can't "crack" a account, so no chance of entering a system transparently, but can change/remove login password.
            It works like a charm for windows 7, it says works for Xp and the new Windows 8 as well.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              keep in mind if you have any encrypted files, they will be irretrievable afterwards, unless you can remember the password.
              as far as the pictures...is this one you can easily take the HD out and hook up to another computer?
              • 3d0
                • Jan 2014
                • 159
                • BiH
                Yes that's true, I was lucky enough the files were not encrypted.
                If I remember correctly the HDD was not easily accessible, that was my last option.
                Couple days after, he brought the laptop back again saying he hates windows 8, give me back the start button. The only trouble with win7 is that the rigth side usb 3.0 don't work out of the box, so you only have one usb 2.0 on the left side. Need to find a fix for that, if there is any.
                • trebo
                  • 514
                  • Wales, UK
                  LOL, a man after my own heart
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    "Windows 8" theres your problem...
                    Follow the white rabbit.
