Replacing Bestec ATX-250-12E psu with.....
  • AKBessy
    • Feb 2007
    • 131
    I was researching on replacing a Bestec ATX-250-12E psu and so far have only come across replacement model Bestec ATX-300-12E. Size of the unit appears to be unique. Any suggestions of other models besides the 300, or is the 300 okay?
    The psu is out of an old eMachine (2002?) that "just quit working." I tried to boot it up and nothing happened. Put in my spare psu and the computer booted.
  • AKBessy
    • Feb 2007
    • 131
    Re: Replacing Bestec ATX-250-12E psu with.....
    PSU information, as described by http://www0.dealtime.com/xPF-Bestec-...hines-P-N-1763 :
    This ATX12V power supply is a 250W, PS2 Form Factor, six output unit with remote on/off, UL, CSA, CE, TUV approvals. Airflow drawn out of case into surroundings by 80mm internal fan.
    Wattage 250 Watt
    Number of Fans Single Fan
    Compatibility ATX 12V
    Power Properties
    DC Output +3.3V @ 20A, +5V @ 25A, +5VSB @ 2A, +12V @ 13A, -5V @ 0.3A, -12V @ 0.8A
    Dimensions
    Width 5.9 in.
    Depth 5.5 in.
    Height 3.4 in.
    Miscellaneous
    MPN ATX25012E
    Product ID 26744331
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      any atx psu 250w or better with p4 +12 should do.
      you are lucky you didnt lose the mobo with that bestec.
      it is recappable but you need to do several other than the secondary.
      • WNG
        • Sep 2006
        • 354
        eMachines is notorious for under-powering their systems. One mini tower unit I came across only had a 85W Lite-On Power Supply. It was a Celeron cpu, but still, no marginal of safety.
        I'd go with a 300-350W from a reputable brand.
        As kc8du stated, any ATX unit should fit, as the chassis doesn't appear to be unique.
        “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
        We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
        • AKBessy
          • Feb 2007
          • 131
          Thanks for the input
          I do remember reading (where???) that the mobos usually go too, so I was glad to see that it didn't :-).
          Thanks for the input about the size of the chassis. I was under the impression it was unique -- but, I haven't dealt with these, so was glad to be able to post somewhere where others do deal with these. Cool!
          Again, thank you both for your input.
