win vista freezes!
  • ivtec
    • Dec 2008
    • 1967
    win vista freezes!
    Hi guys; anybody know why my toshiba satellite with vista installed and google chrome when i try to get in my yahoo mail and face book freezes and i have to shutdown and it doesn't freeze on any other site!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: win vista freezes!
    Its God's way of keeping yet another victim off failbook. I'd start the typical culprit checkdown....flash, drivers, and malware.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ivtec
      • Dec 2008
      • 1967
      thanks Topcat, but why it only happens on these 2 sites> ?
      • RJARRRPCGP
        • Jul 2004
        • 6304
        The laptop possibly has laptop-HDD disease. Laptop-HDD disease is a condition where for no apparent reason, the HDD causes Windows to be slow like it's a 286 or a 486 and/or corruption and it goes away, at least temporarily after wiping the HDD.
        Or when it's crawling for no apparent reason, on a Toshiba laptop I fixed, recovering Windows was slow like running XP on a 486 at 25 Mhz!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Flash. Perhaps there's something in their horrendous bloated code causing this....which is why flash was the first on the list. Both those sites abuse & exploit flash as if it were the holy grail or something. I've seen flash cause crazy instabilities on various websites over the years. Does it make any difference if you use another browser>
          Team : 49813
          Join in!!
          Team Stats
          • clearchris
            • Dec 2013
            • 687
            Rjar: Ha I just replaced my hdd with an ssd in my laptop that had those exact symptoms. I think it has to do with ntfs and a hdd that's going bad.
            What tends to be the cause?
            • Elysarian
              • Mar 2013
              • 200
              I'd be inclined to blame flash too, if you're using Firefox try disabling the plugin and see if that helps.
              • ivtec
                • Dec 2008
                • 1967
                Thanks ; I just uninstalled adobe flashes and only freezes in Yahoo mail.
                this happened only after i installed Firefox then i removed firefox and installed
                chrome it does the same,it did not do it with IE,i wanted to get rid of addons and IE was not doing it dispite of the addblock installed.
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1866
                  Imagine that somebody at winhistory.de did that,except the CPU was a Socket 3 (I think)Pentium Overdrive(simple 486 CPUs cannot run XP because they lack a certain requirement that Pentium 1 and newer CPUs have) and they underclocked it to 25-20MHz and even lower,all of this running XP.
                  Main rig:
                  Gigabyte B75M-D3H
                  Core i5-3470 3.60GHz
                  16GB DDR3-1600
                  Samsung SH-224AB DVD-RW
                  Delux MG760 case
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    That makes sense. And I also assumed that the installer needs to be hacked to install with a processor frequency less than 233 Mhz or it will refuse to continue the installation.
                    I thought that it was with a 486, with probably a hacked installer.
                    According to Microsoft, even ME had a minimum core frequency requirement almost as high, at 150 Mhz and halts if the processor frequency is less than 150 Mhz with an error message saying that the core frequency must be at least 150 Mhz.
                    I would have definitely expected XP to have a minimum processor core frequency requirement, because ME did, at least according to Microsoft.
                    Arc A770 16 GB
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      Thats the slowest system I ever put XP on. A dual 233MMX in a Tyan Tomcat AT motherboard (dual socket 7) with 512mb of EDO RAM, on a Adaptec 2940U2W with a 9.1GB cheetah, with an old 8mb Matrox Millennium graphics card and an old AWE64. It ran surprisingly well. Windows 2000 roared on this old relic back in the day. I wish I had that system back.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • ivtec
                        • Dec 2008
                        • 1967
                        I don't know if you talking abount the PC running old hardware!
                        if so not the case.
                        Toshiba Satellite 355D Amd Turion Tm x2 tl 60 2.00
                        2.00GB 32-bit for Vista it's not the fastest but i think it's enough.
                        • dj_ricoh
                          • 2073
                          • uk
                          failbook
                          Now i understand why failblog was so popular.
                          Failbook.com hahahahahahah
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5037
                            • New Zealand
                            I call it Farcebook...
                            -David VanHorn
                            • grosseader
                              MSI B450 Gaming Plus Max - freezes randomly
                              by grosseader
                              Hello everyone, i got this mobo for long time, now i decided to rearrange some hardware and build a office pc, but 1 week so far, this motherboard drives me crazy.
                              What is the issue:
                              PC freezes randomly. While loading win, while installing win, while in windows , and just once did it while in bios.
                              Hardware:
                              MSI B450 Gaming Plus Max , MSI A320m A-pro
                              BIOS : 7B86vHG - latest
                              CPU: Ryzen 3 1200, 3200G , Ryzen 5 3500x, Ryzen 5 5500
                              GPU: Vega 7 in 3200g and MSI 1060 6GB
                              RAM: 2x8 ADATA spectrix 3000 , 2x8 SiliconePower 3200
                              01-30-2023, 03:24 PM
                            • strixuser
                              Verify e-mail address?
                              by strixuser
                              Hello! I am having a problem with the forum in general, not a specific device repair. I am sorry if this is not the correct place to post about this!
                              My problem is quite simple: I got an e-mail that someone replied to one thread which I follow, but when I click the link to go to it, I get a message which says "To download from Badcaps you must register and verify your email address. Upon registration it may take a few minutes for the verification email to arrive. If you do not see it please check your spam folder. For assistance contact support@badcaps.net". I have clicked...
                              06-26-2025, 08:23 PM
                            • hinisa
                              Xiaomi router freezes at boot after re-capping
                              by hinisa
                              I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                              When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                              After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                              Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                              07-08-2023, 05:58 AM
                            • huzo
                              Another Asus ROG Strix G513 issue...
                              by huzo
                              I see there are many issues with these laptops all over the place...but mine is special...
                              THe board is G513-6050A3249301-MB-A04 with Ryzen 9 5xxx and Nvidia 3070 on board...The issue is that the laptop freezes at boot of windows,linux,HBCD etc...Altough the HBCD manages to boot and then freezes after a minute or so... But when i boot linux and disable ACPI=OFF switch it boots and doesn0t freeze, the battrery ,and wifi are working, but the battery meter is not shown, because it's disabled...ANd since i boot from the USB , i can't really install the nvidia drivers to see if the GPU...
                              09-24-2025, 01:42 AM
                            • FShahid
                              Dell Inspiron 7520 (Intel/AMD) LA-8241P Freezing Issue
                              by FShahid
                              Hi I have Dell 7520 which has i7-3632QM as well as AMD 7730M Discrete Switchable GPU.
                              This is BACO Switchable meaning the AMD GPU can only "render" and cannot work as alone as it depends on iGPU for output.
                              Attached is the datasheet for LA-8241P which shares common with Inspiron 5520 and Vostro 3560. Link to Schematics: https://cdn.badcaps-static.com/pdfs/...a856347d78.pdf
                              The laptop has worked flawlessly for last 9 years, with CPU temps never exceeding 90*C and GPU barely reaching 80*C on gaming/full load.
                              Since...
                              04-26-2022, 04:41 PM
