A bad diode! What the heck?
  • Logistics
    • Apr 2007
    • 721
    So I'm holding an MSI K7T266 Pro2 board... Paps says it won't come up. His system recently took a dive due to bad caps, then he hooks up some other system he has and it's having problems so I look, bad caps as well. Then he tried to use some other hardware he has, this board, but he gets nowhere. I look all over, it has some Teapo's, some G-Luxon's and some Rubycon MBZ's next to the CPU. Wow! Next to the DIMM slots, however there is a bad diode. Vut de heck? It's split in two and charred! I can easily replace it, but can I find something like this locally, perhaps? It's marked SS12, which comes up as a Vishay diode on the net.
    BTW, what could cause something like this?
  • davmax
    • Dec 2005
    • 899
    Re: A bad diode! What the heck?
    You have a wide choice from local parts suppliers. In the same construction anything from SS12 to SS100. A diode with axial lead format 1N5817 to 1N5819. The SS14 is available at my local electronics parts so you should not have too much trouble.
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
    • Logistics
      • Apr 2007
      • 721
      Does it have to be this same type of diode? I believe I have some plain 5819's around from an old Dreamcast VGA Box project. That motherboard board also has some SMT but non-chip type diodes on it, but why did they decide to use a chip type in this particular spot? Does it need to have the chip type or can I just use these little axial babies in it's place?
      • Rainbow
        • Aug 2005
        • 1371
        IIRC, SS12 is Schottky diode. They're usually located in memory power circuit and burn when memory module is installed backwards.
        • PeteS in CA
          • Aug 2005
          • 3579
          • USA, Unsure of Planet
          Here's the datasheet. It's a 1A, 20V schottky rectifier. I'd suggest a 1N5817 over a 1N5819. Both are 1A, the '17 is rated for 20V and the '19 for 40V, but the V(F) of the '19 is higher than that of the '17, which may be a relevant factor in the circuit.
          PeteS in CA
          • asr
            Finding replacement diode iPad Pro 3rd gen A1701
            by asr
            Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
            Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
            07-09-2024, 06:24 PM
          • unimatrix93
            TV backlight zener diode
            by unimatrix93
            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
            The led strips has 9 6V leds.
            02-10-2025, 12:13 PM
          • NicRac
            monowheel repair,Is the diode the problem?
            by NicRac
            Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
            First of all, I am new here. Therefore I will shortly introduce myself.
            I am Nico and currently I study Physics.
            In my freetime I like to build and repair stuff. Especially big battery's.
            A few years ago I got myself an electric unicycle, monowheel or however you call that.
            The battery bms was broken so I replaced and resolder that. Nothing big.
            I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
            07-26-2024, 06:13 AM
          • dennis_elx33
            NO BODY MARKING Diode
            by dennis_elx33
            Hello Everyone,
            I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
            While compared to the reading of another diode from the next channel it won't read at reverse bias.
            Now the problem is; it does not have any body marking.
            So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
            What do you think is this diode?
            Can you please suggest what part number can i use to replace this faulty diode instead?
            Hoping that you...
            06-14-2024, 12:36 AM
          • eccerr0r
            Electric lawnmower...purpose of diode...
            by eccerr0r
            I was looking at an old battery powered electric lawnmower I picked up as the previous owner didn't want to buy a new board to replace a ruined old board. Tried to study how it was designed - it appears it has a huge 80A contactor...or rather, a 80A relay. It appears to be SPDT to control the motor. A 30A relay protects the circuitry.
            The weird thing I don't quite get is how this thing is connected. The common contact is connected to the motor. The NO contact is connected to the battery, which is expected, so when the relay is activated, the common is connected to the NO contact and...
            08-27-2022, 12:54 PM
