screwdriver mod.
by jm1234Hi, I have a 11 year old microwave Siemens and the main function selector switch is a rotary type. It goes bad every few months, there are carbon (?) pads and the metal contacts that drive on them create concentric circle tracks from the residue.
I clean the tracks and the metal contacts with IPA and it works few months again. Here you can see the contacts:
Once I tried this contact cleaner: Kontakt 60 https://www.tme.eu/Document/3f58feb2...TAKT60.DTE.PDF, but it only lasted few weeks, so probably not a good choice.
Is there any... -
by budwichI have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
I am looking for the two resistor values located on the small board inside the battery charging stand.
Please help if you know
thanks -
by capfizHi, new to this forum and new to most things electronic component related.
As in my introductory post, I'm good for soldering, fixing up the grandkids console games but that's about it.
I am based in the UK.
17 odd years ago I purchased an ELU diamond core drill, model ELU SB43EK, I had never heard on the brand here in the UK at the time but it has been a faithful tool and has undertaken a number of jobs without issue.
Last week it failed to start when depressing the trigger, initial checks, it wasn't the fuse or plug top, delving further and...3 Photos -
by arsharpeHi,
I am fixing the charger (UC18YKL) for a Hitachi battery drill (DV18DCL2) but, as it charges Lithium batteries, I need to know the correct replacement device for the blown (smd) FET2.
As I have spent many hours trying to find a schematic for this DV18DCL2 charger without any luck, does anyone know where I can get one or a parts list?
Thanks in advance for any help,
Rob - Loading...
