make -j# Tests
  • cheapie
    null
    • Jul 2010
    • 849
    make -j# Tests
    I recently got an 8-core CPU (AMD FX-8350 4GHz) and I did some testing to see how many parallel compilation jobs got the best speed. These tests were done compiling "The Powder Toy" (it uses SCons, but the -j option does the same thing as on make).
    -j1 (one core only) takes 97.877s
    -j4 (number of "modules") takes 27.201s
    -j8 (number of cores) takes 19.586s
    -j9 (cores+1) takes 19.463s
    -j10 (cores+2) takes 19.583s
    -j16 (cores*2) takes 19.861s
    As you can see, cores+1 got the best speed on this computer, but not by much.
  • Elysarian
    • Mar 2013
    • 200
    Re: make -j# Tests
    cores+1 is the recommended setting in Gentoo, I've never tested other values myself though.
    nice bit of info there that proves the guys who write the manual aren't just pulling numbers out of thin air
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Re: make -j# Tests
      Very difficult to answer this question if you have a multithread core. I agree with the single thread CPU case: cores + 1 is good. But that number will change for a multithread box.
      I think I set my multithread box to number of threads the processing units can handle, and no more...
      • cheapie
        null
        • Jul 2010
        • 849
        Re: make -j# Tests
        This particular CPU is sort of halfway there. It has 4 "modules", each comprised of 2 integer cores and a shared floating point unit. So, essentially, with integer operations, it's an 8-core 8-thread CPU, but with floating point operations, it's a 4-core 8-thread CPU.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Re: make -j# Tests
          An Intel Quad Core w/HT is as much an "8 core" CPU as an FX-8350 is.
          As in, it isn't.
          That said, while something like an i7-4770K is faster than an FX-8350 both are excellent processors with plenty of CPU power to spare to run pretty much everything 99.95% of people will want now and for years to come.
          Intel's main advantage is more efficiency and less power consumption. The CPU costs more initially but it will pay for itself over its useful life span because it uses less power.
          • Elysarian
            • Mar 2013
            • 200
            Re: make -j# Tests
            As in, it isn't.
            agree with pretty much everything said in this post.
            was having a discussion with my wife on the subject of pc upgrades recently and came to the conclusion that neither of us needs an upgrade in the foreseeable future ( I have an FX8120, she has a 6 core version, we both have 16GB of RAM, I have a GTX760, she has a GT640).
            About the only upgrades we see as possible in the next 12 months would be SSDs and possibly a GPU upgrade for her machine.
            In the past I've always tried to effectively double my CPU "performance" each time I've upgraded:
            first pc was 486sx25
            then a dx2 66
            p166 mmx
            AMD K62 350
            Athlon 750
            Athlon XP 4000 (bigger jump as longer time span)
            Phenom quad core
            then my current FX8120.
            • mariushm
              • May 2011
              • 3799
              Re: make -j# Tests
              Here it was:
              k6-2 333 Mhz (bought by parents)
              486 66 Mhz (first year of university, gifted to me)
              duron 1100 mhz (bought with my own work money in 2nd year of university, same with the rest)
              barton 2500+ (1833 mhz)
              intel d805
              intel q6600
              fx-8320
