MacBook Air 2010 RAM upgrage
  • Gordon01
    • Aug 2011
    • 33
    • Russia
    Hello, guys.
    As you know, RAM in MBA is not upgradeable, because it is soldered to mainboard.
    My idea is to resolder memory chips. There are 16 chips on main board and general so-dimm module also have 16 chips. So I want to replace chips on mainboard by chips from module I will buy. I can do it.
    The questions are:
    Where is SPD?
    Do I need to reflash SPD or memory amount is autodected?
    Officially A1370 supports 2GB or 4GB of RAM. If I take 8GB in 16 chips, will it "see" it? I really interested in putting 8GB in it
    Thank you and please don't suggest to change whole mainboard/notebook)
  • Agent24
    I see dead caps
    • Oct 2007
    • 4961
    • New Zealand
    Re: MacBook Air 2010 RAM upgrage
    I suspect this would be hard. You would likely need to reprogram SPD for new memory timings, and maybe modify system firmware to read new RAM size - IF the hardware can address that much.
    Take care when replacing so as not to damage the new chips or the board, especially if it's BGA.
    After all that time and money on equipment, probably cheaper to just upgrade the machine. Unless you just want to do it for fun.
    -David VanHorn
      master hoarder
      • May 2008
      • 12175
      I agree with Agent24, the SPD on the RAM will likely need to be reprogrammed. Now, as far as how to do that, I really don't know.
      If you are experienced and/or confident in your BGA skills, it probably won't hurt if you tried it. At worst, the motherboard won't work with the RAM and you'd have to put the old chips back on... which will benefit from some new leaded solder balls for sure.
      But before attempting, make sure the pinout and working voltage of the new chips is the same as the old one. For BGA, usually they are (at least on the few graphics cards I've worked on), but better check anyways than be sorry. Also, speed of new chips must be the same or better than old ones.
      But again, the biggest issue I think you will run into is reprogram the RAM SPD. If you know how to do that and can do it, you are the boss .
      • cheapie
        null
        • Jul 2010
        • 849
        Apparently, SPD uses I2C EEPROM chips, and many chipsets will allow you to write new data to them using a special program (such as a modified BIOS flasher). You could also remove the chip from the board and use an external programmer.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          thats your biggest problem.
          • Gordon01
            • Aug 2011
            • 33
            • Russia
            Hi guys. I haven't receieved reply here for long time so decided that nobody interested
            You're right, actually biggest issue is SPD. I can't find it. There is no ROM chips on motherboard that looks like SPD.
            Furthermore, I think that SPD doesn't exist in MBA at all. Reasons:
            1) memory is soldered = no way to change it, so no need SPD
            2) I've run Thaiphoon Burner, it works on MBP with replaceable memory. On my MBA it doesn't "see" SPD.
            So memory information is stored somewhere in firmware (EFI?) image. Anybody familiar with it? Is there a way to change and reflash it?
            Realizing here I'm stuck and demotivated. Because I can resolder memory chips, I can reprogram SPD even on external programmer. But I don't know at all how EFI is designed and how to modify it.
            Maybe somebody know and can help?
            • Gordon01
              • Aug 2011
              • 33
              • Russia
              OFC, I'm want to do this for fun
              • Agent24
                I see dead caps
                • Oct 2007
                • 4961
                • New Zealand
                I don't know much about how Mac firmware works, so yeah, the SPD data could well be in there. But doesn't the system need the SPD to initialize the RAM so it can start loading firmware anyway, so having it inside the firmware wouldn't work?
                I think more likely it would be embedded in the chipset or some other controller IC, if it doesn't have its own chip.
                Also note that Apple is a master of proprietary and hidden things. An SPD Flash ROM may be there but may be relabeled with some Apple-specific code number.
                -David VanHorn
                • Gordon01
                  • Aug 2011
                  • 33
                  • Russia
                  I can only guess. I know that firmware can be reflashed, I can get dumps but anyway I'm not good with assembler and firmware internals
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4961
                    • New Zealand
                    Maybe the Coreboot guys have been trying to do something with Apple computers and have some kind of information about the hardware?
                    -David VanHorn
                      • 31055
                      run a linux-live disk and see what it says about the ram.
                      if it see's it in detail then there is an eeprom - because that's how linu gets the ram data.
                      • MBA101
                        • Aug 2014
                        Hi Gordon. Were you able to make any progress with this? I'm trying to do the same thing here. I'm able to replace the DRAMs with more dense DRAMs, but I haven't been able to find where the SPD data is stored either. If you've made any progress, please let me know.
                        • ZZZAC
                          • Oct 2013
                          • 12
                          • England
                          As far as i can tell ram may not be limeted by any apple software
                          the reason i say this is apple logic boards use two chips. firstly the efi/bios chip witch is probably what we are looking at messing with. this also stores the firmware password!
                          if you go to apple downloads you will see updates for the firmwares on the smc and efi chip.
                          But notice its not specific to ram size/processor speed? sort of seems like a 'one firmware fits all of this model' sort of scenario but im never quite sure. you guys probably know more about this than i do.
                          Anyhow. this begs the question couldnt you just download the approriate apk, extract it and see what you can find out/how many packages are there?
                          i know logic boards seem to have A or B versions after there model number, this may relate to the firmware/hardware but again, im clutching at straws so theres a high chance im not correct.
                          Anyway. id be interested to see if this works out!
                          • TVTX281
                            • Oct 2015
                            • 7
                            Curious to see if that works out, but imo, I wouldnt do it.
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              Hello, guys.
                              Yet, another reason I hate Apple
                              • ipatch
                                • Jun 2020
                                • 12
                                • usa
                                damn i wish there was more info related to this topic.
                                • ugamazing
                                  Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                  by ugamazing
                                  I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                  08-31-2022, 07:34 AM
                                • piernov
                                  NVidia bumpgate
                                  by piernov
                                  Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                  Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                  May complete this post at a later date with more details.
                                  Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                  03-27-2021, 10:34 AM
                                • envym
                                  by envym
                                  Hi everyone!
                                  06-27-2025, 08:54 AM
                                  Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview
                                  Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview...
                                  10-22-2024, 02:37 AM
                                • tobeend
                                  Bypass mdm macbook m2 ventura
                                  by tobeend
                                  1. RESET MACOS WITH IPSW
                                  a. Power off MacBook, press and hold the power button to enter Recovery
                                  b. Open Disk Utility, remove Macintosh HD
                                  c. Reboot, connect to the network to Activate Mac.
                                  d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                  d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                  e. Release the other keys, but keep holding the Power key for another 10 seconds
                                  f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                  05-26-2023, 07:18 AM
