5.25" Internal UPS
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    5.25" Internal UPS
    hey look at that.
    http://www.beam-tech.com/093001/prd_...ternal_ups.htm
    also available here as "Micro PC" UPS. Theres gotta be some stuff missing to fit it all in that small a box. Like some decent batteries for instance......
  • Rainbow
    • Aug 2005
    • 1375
    Re: 5.25" Internal UPS
    Specs says that the better models have NiMH batteries.
    There is a better thing - PSU with integrated UPS. Hopefully some of them can run the computer directly from the battery without DC->AC->DC conversion.
    • Maxxarcade
      • Jul 2006
      • 973
      If those are any good, I am so buying one for my computer at work... But how the hell can it power anything but a small OEM PC with those little batteries??
      • pentium
        • Mar 2006
        • 2778
        I would only expect something of decent quality it it needed two drive bays (full height, right?) and a more user-friendly front panel like the one on my NEXXTECH UPS.
        Find Nedry!
        Check the Vending machines!!
        <----Computer says I need more beer.
        • gdement
          • Jan 2007
          • 690
          in case anybody is wondering how it hooks up (I was). Diagram is from the site willawake linked:
          • carrzkiss
            Cyberpower cps1500avr not charging batteries
            by carrzkiss
            Hello, all.
            Cyberpower Battery Backup Unit.
            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
            Checking the voltage, it was down to 22v.
            I quickly removed everything...
            06-15-2024, 02:10 PM
          • howardc64
            Where do repair shops buy MB replacement batteries?
            by howardc64
            Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
            Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
            BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
            07-25-2024, 10:42 AM
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
          • joshAU
            How to trick notebook into thinking internal panel is connected?
            by joshAU
            Hi all.
            I have an asus F505DV that has a smashed screen, broken hinges, bezel and top cover.
            The customer cannot afford to repair it, so they wanted me to remove the top of the unit and will just use the base as a desktop and plug into a monitor via HDMI.
            However, for some reason, with this model, it REFUSES to display on the external monitor unless there is also an internal LCD.
            If there is a internal screen, then the external displays fine.
            This is running the latest BIOS.
            I have set the display properties in windows 10 using...
            10-06-2022, 11:04 PM
          • dbuergi
            DIY: Modified smart charger for all types of batteries
            by dbuergi
            sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
            Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
            My first work was to bring my Samsung watch battery back to life with was not recognized...
            07-18-2025, 03:17 AM
