Stevo's building a computer again!
  • stevo1210
    • Oct 2006
    • 4156
    Okay, so after a VERY LONG break from the IT industry... I've decided to build a computer after my brother upgraded to a Core i5 and gave me his CPU and motherboard. CPU is an AMD Phenom 945 and Motherboard is some Gigabyte ATX sized thing. I think there's also 4 sticks of RAM on there. Sorry, all my knowledge of computers went out the window after I moved onto cars and bikes.
    I currently use an Acer Aspire Core 2 Duo of some sort (dunno specs), bought in 2009 second hand. Works great as it is but got some freebie parts so why not upgrade?
    I need an ATX case and a power supply so far. I'll reuse the hard drive, DVD drive and graphics card from my Acer desktop. I've had a bitch of a time finding a suitable case due to space constraints on my desk and I found the Cooler Master 361 to be the best case for the small cubby area on my desk as it's height restricted.
    The power supply I have a few choices and not too sure what to get so here I am to ask the questions!
    Okay, so I found two power supplies which I think *should* be okay.
    * Corsair VS350 (New ~ $45)
    * FSP AX500-A Blue storm (Used ~ $24)(http://icrontic.com/article/fsp_ax500a_blue_storm)
    Not sure if I should get the new Corsair VS350 as it's relatively cheap and has a 2 year warranty or a used FSP for $24 with a 60 day warranty to save $$$. Never had issues with FSP in the past but would like some advice nonetheless. I see Teapo caps! :O
    Thanks.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Stevo's building a computer again!
    Don't feed the Corsair overhyped corporate troll.
    • c_hegge
      • Sep 2009
      • 5219
      Both those PSUs use rubbish caps. If you aren't going to use a Graphics card, then the Seasonic SSP-350GT would be an option. Otherwise, I'd say go for a Seasonic G-360.
      • cheapie
        null
        • Jul 2010
        • 849
        The Seasonic S12II Bronze-380 ($60) would also be an option if you don't need an EPS12V connector, but the G-360 ($55) is probably a better choice.
        I actually have the S12II Bronze-380 and 520 (also $60, but the 430 watt version is on sale for $50), and they have all Chemi-Con capacitors, except for the primary filter cap on the 520, which is a Rubycon.
        Prices listed are those from Newegg, as of today.
        • stevo1210
          • Oct 2006
          • 4156
          Oooh, would like a Seasonic... $60 would be great if those prices were existent here! The basic seasonic c_hegge suggested starts at $90! Bit out of my budget...
          Not sure what to do now. That cheap $24 FSP unit is calling me.
          • mockingbird
            • Dec 2008
            • 5484
            Which model FSP?
            Most new'ish FSP models with all Teapo SC series caps, just change out the two 8mm 5VSB caps and you have a first class PSU.
            • c_hegge
              • Sep 2009
              • 5219
              In Australia, the S12IIs are the same price as the G-series, so there is no point in buying them, and the S12II 380W isn't available at all.
              EDIT: http://www.pccasegear.com/index.php?...ducts_id=25375 The 350GT is only &79 at PCCG. It's still a bit expensive, though (and may even be closer to 90 once you factor in freight).
              • stevo1210
                • Oct 2006
                • 4156
                Just built this computer a few days ago into a Cooler Master 361 case where the PSU goes in the front. Currently using left over parts and stuff so I installed a Thermaltake XP550 PSU in there for now. It's only temporary but gets real hot cause it can't ventilate so well. Only a temporary for now till I have time to look for a new PSU.
                Seeing as I hadn't built anything in the space of 4 years and left the IT industry as a whole, it took me a good 3 hours to figure everything out. I was trying to figure out how the optical drive communicated with the motherboard cause I didn't see no IDE ports on the drive... turned out it was a SATA drive (my brothers old one).
                When I last built a PC, SATA optical drives were unheard of! Though SATA HDD's I used at the time.
                ... it's been a while.
                • stevo1210
                  • Oct 2006
                  • 4156
                  Got an Antec Truepower II BLUE for about $20 on ebay. After I won the auction, there was a slight tingle in my mind cause I remembered many years ago (when I was a kid), Antec had this rep for bad caps.
                  Type into google the name and model and bam, I've bought a dud. Ain't got time to fix caps so once it arrives, it leaves my front door via eBay again.
                  Well, I'll take a look first before but the caps situation doesn't sound good. Anything with bad caps I just throw in the bin, I haven't got time to eat or sleep... let alone fix stuff unfortunately.
                  Recently threw out a Cooler Master 500W PSU and a HEC 300W unit cause of a bad cap on the +5V standby lines with both units. Shame I didn't think about selling them as faulty and may have picked up a few beans!
                  • h0m3w0rk
                    Random Shutdowns/Startup Failure with Corsair SFX 450
                    by h0m3w0rk
                    I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                    For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                    02-09-2025, 03:19 AM
                  • dennis akumu
                    hp elite desk 800 g3 twr bios
                    by dennis akumu
                    i have this elite desk 800 g3 tower with no display,need a clean me file.
                    s/n : SGH802SMK4
                    PRODUCT ID: 1VR31UC#ARE
                    BOARD NO: Andromeda REV A
                    Please clean me please....
                    07-11-2025, 05:54 AM
                    Corsair CX750M [Model 75-002019] - burned output toroid inductor
                    by momaka
                    Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                    So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                    09-19-2021, 08:44 PM
                  • hobostove
                    Corsair RM1000e - Help identify 5VSB Zener diode
                    by hobostove
                    Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                    Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                    There's a 22ohm resistor that's melted and open, but it still has the bands.
                    The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                    It looks like the diode connects the source and drain of a TNY284...
                    03-27-2025, 02:25 PM
                  • W1ngl3t
                    Corsair RM850x (synchronous ATX) need help troubleshooting
                    by W1ngl3t
                    I have a Corsair RM850x that refuses to turn on. I have 5v stby but as soon as I try to power it up it goes 'click' and does not deliver any voltages.
                    I have not been able to find any blown or shorted components and there are no bulging capacitors. I have replaced the APFC controller and for a brief period (2 or 3 on/off cycles) the PSU worked but then the fault returned. Perhaps heating the PFC area is what resulted in the temporary fix?
                    The only option I see now is to start pulling components one by one, but before I proceed, perhaps someone more knowledgeable...
                    03-15-2025, 04:43 PM
