core2duo win2k
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    core2duo win2k
    is core2duo working under win2k or is required to install xp for full performance?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: core2duo win2k
    as long as the OS supports SMP, you should be just fine.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Re: core2duo win2k
      I bet they scream in 2k!!! Haven't tried that one yet... they're plenty fast under XP...
      Ludicrous gibs!
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: core2duo win2k
        great. i dont really want mixed os in the office. prefer to keep all win2k
        • WNG
          • Sep 2006
          • 354
          Re: core2duo win2k
          As Topcat stated, if it supports multi-processors...
          you can always create a dual-boot test mule and run benchmarks in each OS, compare the results.
          It would be interesting to see if Win2k is faster w/o XP's extra fluff.
          “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
          We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
          • bgavin
            • Jan 2007
            • 1355
            Re: core2duo win2k
            Win2000 is SMP capable right out of the box. I believe the limit to be two processors.
            I just migrated from W2k to XP Pro, and changed hardware platforms. Moved up from Epox KT133 to MSI nForce-2.
            I mulled over a socket 775 box, etc, but since I don't game I have no real need. The MSI board is populated entirely with quality caps, and works well with a Sempron 2600.
            My Win2000 installation was broken after the missus installed a bunch of Yahoo games for the grandkids. I was never able to repair IE6, which would hang if scrolled while still downloading from a web page. Strange bug, could not fix it. I moved up to XP Pro/SP2.
            I have VMWare installed on this box with a gig a RAM, and it works great.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Re: core2duo win2k
              Win2K does not differniate between physical and logical CPU's though
              So a Pentium 4 with Hypherthreading and you have used up your 2 CPU max license... Need to use Server to get up to 8 CPU's...
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                Re: core2duo win2k
                well i cant even get win2k to install, even with sata set to legacy or native but ide (using sp4 slipstream on the intel dg965ry)
                it just hangs at the first "setup is starting win2k" screen after copy of files.
                damn ICH8
                i got it installed using DIY method of copying the AHCI driver over the files on the intel F6 install disk which is for up to ICH7. Seems ok but i dont want AHCI anyway in win2k.
                bios says ahci is only for vista?. anyway problem is that wd diagnostics boot cd does not work with ahci. i bet ghost is not working also? i need ghost working for work pcs in case hdd starts failing in the future.
                the linux guys seem to have some difficulties with ICH8 also.
                will try xp next.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Re: core2duo win2k
                  Seems to be many problems with that:
                  http://en.wikipedia.org/wiki/Advance...ller_Interface
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    Re: core2duo win2k
                    xp installed ok with ahci off and no driver.
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      Re: core2duo win2k
                      proc temp is 33oC and ICH8 is 76oC jaysus i think its gonna need a sink.
                      edit : its already got one
                      • japlytic
                        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                        by japlytic
                        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                        Tried (only with keyboard/mouse connected):
                        • BIOS + database update
                        • Using latest Windows 11 image built with official image creation tool
                        • Previous setup version for Windows 11 installer
                        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                        06-19-2025, 04:59 PM
                      • 24gsm
                        MacBook Pro A1708 install macos fail
                        by 24gsm
                        hi to all
                        i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                        after enter to recovery and format hdd 1to .
                        after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                        can help please
                        Serial Number: FVFXP0U0HV2J
                        Config Code: HV2J
                        Find My Mac: OFF
                        04-16-2025, 03:57 AM
                      • duwane
                        A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                        by duwane
                        Hi All.
                        Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                        The issue:
                        Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                        10-26-2022, 07:02 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • TrumanHW
                        MacOS: R|W Programmers like CH341x BINs..?
                        by TrumanHW
                        For years I tried figuring out how to R|W BINs from my CH341x programmer.
                        From FTDI's pkg, Apps specifically claiming they work, I failed for ~8 years.
                        I'd expect many here figured it out (easily), but in case not ...
                        It's one of the few forms of "how-to" remuneration I can GIVE BACK.
                        This group is both GENEROUS & literally BRILLIANT / GENIUS!!!
                        This may be the easiest means to copy-paste:
                        Code:
                        SERIAL -to- USB - CH341 ROM (MacOS):
                        Install xcode:				xcode-select --install
                        Relocate
                        04-08-2022, 02:33 PM
