are there bad caps on fax modems
  • kleung
    • Jun 2012
    • 72
    hi there all,
    I get intermittent problems with my windows fax server.
    it uses an internal pci faxmodem (agere chipset).
    the capacitors on it are small and look ok; has anyone ever seen a faxmodem with bad capacitors.
    the fax board is about 6 years old at this point.
    thanks
  • brethin
    • Dec 2008
    • 1907
    Re: are there bad caps on fax modems
    Yes many times, lightning tends to kill them among many other parts on the card. They are so cheap though its really not worth repairing them.
    • Startacus
      • Jun 2013
      I've had many issues with the agere chipset modems with machines susceptible to lightning strikes / surges. I usually replace these with USRobotics or 3Com which seem to handle the surges better. I would strongly suggest some sort of grounded surge protector / battery backup solution as this will most likely happen again. If you continue with the agere modems, thankfully they can be found very very inexpensively. Good luck!
      • Logistics
        • Apr 2007
        • 721
        Which model, specifically do you have?
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
