can i replace damaged 14n36gvl with 20n60 ?
  • bembeno
    • Feb 2016
    • 309
    • egypt
  • XxMicroSoldering
    ASUS Rog Strix G17-712LV Laptop Liquid damaged
    by XxMicroSoldering
    Hello Guys
    I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
    10-17-2024, 10:45 AM
  • Tomylee
    Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
    by Tomylee
    I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
    It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
    I'm looking for help with the following:
    The exact identification or part number of the T5 component
    05-28-2025, 12:42 PM
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • tmhobadcap
    Samsung un65h6203af led replacement question
    by tmhobadcap
    This tv is with sound but no picture. When light shines on the screen, we can see the image. This is a typical backlight problem. I opened it and found quite a lot of the leds are damaged. But the damaged ones are all shorted. No one is open. Is there a special reason? (From my past experience, both can be happened)
    When I supply 3V to each of the good leds, the currents range from 105mA to 154mA. From these figures, I think the leds are 3V and about 0.5W. I plan to replace all the damaged leds only (because the price of the led strips is very expensive), but I could not find 3V 0.5W...
    10-03-2023, 11:37 PM
  • i_am_patch
    Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
    by i_am_patch
    Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
    04-30-2024, 08:20 PM
