MAC: UPS signalling via serial ports
  • japlytic
    • Oct 2005
    • 2086
    I have stumbled across a "smart" signalling UPS cable for a Macintosh (http://www.networkupstools.org/cables/mac-940-0024C.png) and I am wondering if there were any "dumb" signalling (Power Fail, Battery Low, and Shutdown) cables and software for Macs.
    The serial port has TxD (+/-), RxD (+/-), HSKi (Handshake IN), HSKo (Handshake Out - not fitted on 128K, 512K(e)), and +12V (128K, 512K(e) only).
    To use the serial port in RS-232 mode, RxD+ needs to be grounded.
    Some of the UPS cable wiring diagrams for PCs are on http://www.opennet.ru/docs/HOWTO/UPS-HOWTO-8.html
    Does anyone know of any "dumb" UPS signalling cables and software for the Macintosh?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: MAC: UPS signalling via serial ports
    i dont know much at all about macs but APC has dumb and smart cables.
    are you talking about an APC ups?
    apcupsd works with usb and osx
    http://www.apcupsd.org/
    there is some more pinouts in the manual
    • Dannyx
      UART (serial ?) splitter ?
      by Dannyx
      Good day folks. I got a project on hand and would like some thoughts on whether it's possible to achieve, albeit impractical. You know me - I like to over-complicate stuff
      The setup: I got a Paradox EVO192 alarm panel, a serial-to-ethernet adapter and an official PCS250 GSM communicator.
      The task (TL/DR): connecting both the ethernet adapter AND the communicator to the single serial port of the Paradox panel. Connecting their TX/RX lines in parallel the data would get all messed up. At the very most, I THINK I could parallel the RX pins of the ethernet adapter...
      08-18-2023, 03:21 PM
    • mshone
      Lenovo thinkpad P1 G2 UUID and Serial number/mashine type unknown
      by mshone
      Sorry if topic if misplaced. Have lenovo thinkpad P1 gen2 with Xeon E-2276M CPU and NVIDIA® Quadro® T1000. It is a new board replaced. Old board was P1 G1 model with i7 and it is defective. I ordered a new one with xeon, but is gen 2. Laptop case is suitable for this motherboard, with some little difference (GPU fan and subcard).Ok, ordered and replaced and GPU fan and subcard and now laptop is working fine, but serial number and UUID is unknown. Ok, i readed several topics here and found Thinkpad maintenance disk, but.....which values to type? How to find data base with those values? serial...
      08-29-2025, 06:41 AM
    • hell
      Hıkıvısıon serial problem
      by hell
      Hello, I would like to talk about the problem. My Hikvison recording devices have a password, so the BIOS is written. Our problem is the serial numbers on the devices, as written, it works in offline mode, but I cannot change it to online mode in any way. I have the BIOS. I tried to edit it, but it could not find the serial number with the BIOS hex editor. I have the original serial numbers. Can you help me? Best regards.
      model DS-7208hqhı-K1
      main kod : ds-20899_P rev:2.0
      07-23-2025, 01:20 AM
    • baletak
      Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
      by baletak
      had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
      I have updated laptop model number.
      1) I did not find the way to update laptop serial number - I have this one.
      2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
      Hope to find someone to help me with this as I am hitting dead end at the moment.
      Many thanks
      Miro
      05-23-2025, 01:21 AM
    • Friend33
      Updating Serial Number on EliteBook x360 1030 G3
      by Friend33
      I have an EliteBook x360 1030 G3 and after a motherboard replacement, I want to change the serial number and the FeatureByte. None of the known methods work. MPM is locked and cannot be unlocked via EFI.
      Therefore, I read out the two chips and adjusted the serial number, FeatureByte, and Born Date using a hex editor. Now the system won't start anymore. I think I did something wrong with the FeatureByte, as there was a message indicating that the file size was changing.
      My serial number is: 5CD849BL7Q
      FeatureByte:
      3X476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAd6dUdpdq
      06-20-2024, 03:55 PM
