Disabling Conexant SmartAudio headphone limiter
    master hoarder
    • May 2008
    • 12170
    • Bulgaria
    Re: Disabling Conexant SmartAudio headphone limiter
    It's usually best to do a little bit of search online to see some new laptops and see what price range you like and what features you'd like to have, then go to an actual store that has the laptops you "liked" displayed and try them out. See how much heat they kick out, how they feel, and give them a good test if possible.
    When I was buying a laptop for someone a few years back, first thing I did was look at some laptops online. Then I went to the store (Micro Center) with a flash drive full of diagnostic utilities and started playing the same 1080p YouTube HD video on each laptop, then checked how hot each laptop ran and how loud it was. Ended up picking up a Compaq CQ-61, despite knowing that low-end HP/Compaq aren't exactly stellar. It's a 15.4" sub-$500 laptop ($430, to be exact, I believe), so definitely in the consumer end of the scale, though not the cheapest stuff which were $200-300 and came with single-core Celerons and similar at the time. I picked it mostly based on the price and the fact that it had probably the most powerful CPU for its price range, yet the CPU had only moderate TDP rating. It was either an AMD Athlon dual-core M340 or P340. Laptop fans were always on but very quiet and there was no heat when laptop was idle. After HD video test, the CPU temperature were fairly low (mid 40's) and CPU fan was spinning faster, but still not too loudly and there was hadly much heat coming from the exhaust grill.
    That laptop is still working today even with lots of daily use and many power cycles.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Yeah, this laptop is super cheap, add another 2GB RAM and it's an inexpensive usable machine.
      http://www.bestbuy.com/site/dell-ins...specifications
      I'm actually considering purchasing this for my mom. If they still have it in June she'll get it for her birthday.
      It's not beautiful nor does it have a good screen, but it's probably a decent enough machine.
      • lti
        • May 2011
        • 2548
        Now that there have been no replies for three weeks, I'll add a little update.
        I compared the sound on this laptop to my desktop computer, and they both sound the same. Switching to the generic Microsoft driver did make a big difference, but I thought it was worse since I was used to the sound with the real Conexant driver. The real driver is 59.4MB, and most of that is just the software that provides the crappy enhancements and two useless equalizers (one might be usable, but disabling the normal Windows enhancements disables it as well). The only reason to install it again would be if it allowed me to reconfigure the jacks as a line out and line in. The chip (CX2058x series) supports that, but the microphone jack is mono only (the tip and ring contacts appear to both be connected to the left channel input) and the driver has no configuration settings.
        • osrex
          LED DRIVER KEEPS DYING
          by osrex
          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
          i have no datasheet at all for the LED lights, all i have is its length.
          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
          05-05-2025, 03:36 PM
        • howardc64
          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
          by howardc64
          Problem
          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
          Model & Board Pics
          Conflicting Spec
          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
          https://www.shopjimmy.com/vizio-gj-2k1...
          10-10-2024, 01:16 PM
        • charif
          Audio Driver for Thomson P14C4BK128
          by charif
          Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
          I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
          The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
          Here are the details:
          • Model: Thomson P14C4BK128
          • Operating System: Windows 10 64-bit
          If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
          Thanks in advance for your help!
          04-30-2025, 05:41 PM
        • bohaboha
          how to install gl usb2.0 uvc camera device driver on windows 10
          by bohaboha
          Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
          but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
          any help?
          01-26-2025, 08:33 PM
        • Tom_x
          Rotel RSDX-02E headphone mode
          by Tom_x
          Hi!
          I need help to disable headphone mode on this unit!
          Someone played buttons on front panel and now no sound on speakers. When i push the Surround button, only HEADPHONE MODE appear
          Amplifier does not have headphone connector in front, only 3-pin on main board and factory grounded the hpsw line
          i tried all combination on front panel, but no success....
          In sevice manual no info about full reset, only reset speakers settings to default.
          Anyone have info?
          regards
          Tom
          12-22-2024, 11:33 PM
