Shame on you Dell!!
  • c_hegge
    • Sep 2009
    • 5219
    Shame on you Dell!!
    So, I had to fix up a Dell Studio XPS 8100 desktop PC the other day. Among other things I had to clean out the dust and after pulling off the side panel, a somewhat disturbing design flaw caught my eye. The PC uses a Radeon 5770 Gaphics card, and has a steel bracket which screws to the case near the HDD bay to hold it in position. The wires for the HDD's SATA power connector run right under it, but unfortunately, the bracket doesn't have folded edges, and had chafed the wires . I covered the edges of the bracket in tape before putting it back together.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Shame on you Dell!!
    Yeah, the edges should have been folded or the like. Whoops.
    I personally would have filed the edge smooth with a needle file but tape works too *comes from the guy who used to own a shuttle XPC with a drive caddy covered in tape, due to it shorting a large TV tuner card*
    sigpic
    (Insert witty quote here)
    • trodas
      • Jan 2006
      • 770
      • Czech republic
      ...and these sharp edges are even cuting people hands! Many times it happend for me, that the computer I building took some more of my blood as sample...
      Damn vampires!
      (this is really shamefull for a respected Dell PC making company)
      "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
      "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        While at Delta I removed and installed a P/S in an Apple drop-side case quite a few times, and got sliced more than once.
        BTW, I would not recommend using a file to deburr edges in a computer case. Metal particles being circulated around the computer case by the fan might not be a good thing.
        PeteS in CA
        • Nitro468
          • Oct 2013
          • 65
          Foam weatherstripping tape makes nice padding, doesn't look too shabby either. I remember the 1st time I bought a quality case (Antec) back in the day. I did not even have to wear gloves.
          • Kiriakos GR
            Banned
            • May 2012
            • 940
            • Greece
            This Radeon 5770 it is a monster, I love my Vapor-X
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              That's why you clean up your mess when you're done.. Handi-vacs and magnets are good for this. I've metalworked cases before, never had an issue.
              sigpic
              • c_hegge
                • Sep 2009
                • 5219
                An easy way around that would also be to remove the bracket from the case before filing it. In this case, however (pun intended) I didn't have a file available, so duct tape had to do.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  dell done with bad caps and moved on to ginsu cases?
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Is the reason you had to fix this thing in the first place because of KZJ capacitors?
                    HA
                    • c_hegge
                      • Sep 2009
                      • 5219
                      No. Malware. I think the caps were mostly Panny
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        Good thing you checked. Last thing you want is an angry customer that complains their PC no longer works after you fixed it.
                        I always check everything regardless of what people tell me the problem is.
                        And yeah, Dell cases aren't the best. Personally, I hate the desktop full tower clam shells they had in the Pentium-4 era (like the GX260, GX270, and GX280). Mistreat it a little and their mechanism starts to lock on you and they become really hard to open.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Yes, I remember the clam-shell tower cases. I've only had to work on a few of them, but I know what you mean. On one of them, the whole mechanism broke, and I never got it back together properly on one side.
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                          • Akhlz001
                            by Akhlz001
                            09-20-2025, 07:15 PM
                          • master3112
                            by master3112
                            07-29-2025, 01:55 PM
                          • F R 2568
                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                            by F R 2568
                            Hello all,
                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                            If the laptop is only connected to the AC adapter (battery removed):
                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                            The power/battery...
                            01-08-2025, 05:45 AM
                          • diamon
                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                            by diamon
                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                            Pictures of these boards:
                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                            Dell...
                            02-28-2024, 12:51 PM
