Socket 754 3700+ clawhammer?
  • asand1
    Oregon, USA
    • Oct 2011
    • 123
    I have a n Asus K8N socket 754754 machine i built years ago.
    I love this machine and dont intend to replace it until i have to from lack of support.
    I asked my wife for a AMD Athalon 64 3700+ socket 754 cpu on ebay. If this doesnt happen i would still like to pick one up down theroad. Has anyone arou d here have one of these?
  • CG2
    Janome DC3050 Sewing Machine Pedal Resistance
    by CG2
    OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
    Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
    04-14-2023, 07:53 AM
  • Isabella91
    Possible to convert eMMC Socket to a micro SD Card socket?
    by Isabella91
    I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
    Read/Write a Micro SD Card from an eMMC Socket.
    I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
    Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
    Not to remove...
    01-14-2024, 05:10 PM
  • Geomih
    CPU socket replacement soldering profile
    by Geomih
    Hi All - I am hoping someone can help with some pointers (complete noob here!)
    I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
    My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
    The simple stuff like a small memory module isn't a big deal because there are
    12-11-2023, 11:07 AM
  • warsztat
    Acer AN515-57-577G JDIMM1 socket not working.
    by warsztat
    Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
    11-18-2024, 09:13 AM
  • AJ847.63e
    LGA 1700 Socket Replacement Tips & Tricks
    by AJ847.63e
    Hi All,
    Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
    I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
    07-24-2025, 06:57 PM
