Bending boards
  • stevo1210
    • Oct 2006
    • 4156
    Bending boards
    Hello Everyone.
    I have a few socket 478 motherboards here at the moment and I just noticed that if I lock the heatsink+Fan down, the boards will bend very slightly.
    Could I have installed my CPU wrongly or loose? I can see that the heatsink sits flat on all four corners.
    The PC currently POSTs and passed all burn-in tests and a Windows installation. It has been on for hours without issues at all.
    I looked through my IBM desktop and found it had something behind the CPU area, it looks like a large metal plate thing and it prevents the board from bending at all.... what is that thing called and is it recommended that I get one?? (The manual says I shouldn't get one because I may damage my board)
    I'm just paranoid to why my boards are bending slightly.... some people tell me that it is a very normal socket 478 thing to have a board bend very slightly once the CPU heatsink is locked in place.... is that true??
    Thanks.
  • Galvanized
    • Mar 2006
    • 468
    Re: Bending boards
    That is why it's nice to have a slide-out motherboard tray for bench testing, because once the board is mounted, it won't flex as much. A slight flexing is normal and can get radical when the retail heat sink with it's .019" thick thermal pad is inplace. I have removed the retail thermal pad and used a quality paste, like CoolerMaster Premium or Ceramique. That is quite a difference in crush, .019" to what? Maybe .002".
    I did read a post where the fella only latched a P4 sink, with retail thermal pad, half way, ran Prime 95 for an hour, then latched it all the way.
    • pentium
      • Mar 2006
      • 2778
      Re: Bending boards
      I have seen some nasty stock coolers do some insane stuff.
      I pulled a socket 370 board once (foret the model) that was having intermittant problems and the cards had trouble seating (hint).
      You put this thing on a flat surface and you could see a half centimeter (or more) bend in the board.
      Not only was he using a dirty thermal pad with way too much heatsink compound but he also rigged a socket 478 heatsink to fit over the cpu!
      This is the same person who thought it was safe to replace cards while the system was on. That board humanely put out of it's misery (and circulation).
      Find Nedry!
      Check the Vending machines!!
      • Maxxarcade
        • Jul 2006
        • 973
        Re: Bending boards
        I put an Athlon Socket 754 system together with an ECS motherboard that did that as well. It had a cheap plastic plate mounted to the back of the board under the cpu socket. It also didn't fit into the old HP Pavilion case I was trying to install it in, because the back plate was thicker than the board standoffs.
        I like the newer way that heatsinks are mounted these days, but not when they use flimsy retention brackets with rediculously tight clips.
        • Galvanized
          • Mar 2006
          • 468
          Re: Bending boards
          ThermalRight does offer a metal back-up plate for < $5 here State-Side.
          • ugamazing
            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
            by ugamazing
            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
            12-17-2024, 07:05 PM
          • ugamazing
            Procedural question about BGA rework and removal of CPUs
            by ugamazing
            I have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
            I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
            I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%...
            07-12-2022, 03:11 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • harp
            Metod for removing glued heatsink from fragile component
            by harp
            I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
            06-23-2025, 02:01 PM
          • ugamazing
            Apple M1 Boards & Exclamatory Error?
            by ugamazing
            We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
            Has anyone else run into this...
            02-20-2025, 09:24 AM
