I'm obsolete!!!, I can no longer build PC's.
  • Fizzycapola
    • Oct 2006
    • 423
    This same thing happened last year building another PC, I despise all these multitude of connectors these days, it used to be connect the ATX and the molex and switch on all is happy, it seems much more complicated to me I fear this shall be the last PC I ever build.
    My system is all brand new MSI Neo-F MB (brand new MBZ capacitors & solid caps), Core2Duo6700, 2GB Dominator RAM, All SATA2 Devices (Seagate NL35), GF8800GTS, FSP 300W VGA PSU (only 1 connector used/1 tucked away), Tagan 480w PSU
    Power is connected as follows:
    ATX 20+4 connector slotted into 24pin atx power
    There are 5 connectors that appear to fit in the small CPU power connector, I have the one marked P4 connected, theres another one
    market P4+, another one and 2 pcix connectors spare not used.
    FSP PCIX connector 1 of 2 connected into GF8800
    When power switched on at socket no keyboard or mouse power lights appear. When power switched on at front PC fans connected direct PSU flash for a split second, repeated pressing power and reset button no longer has any effect at all. No Floppy or IDE's are connected, only connections are power switch and reset button, front usb connector, the rest tucked away.
    Maybe I've just smoked too much and am too stupid to build PC's anymore. ... zzz stressful spent half my savings on this new PC ...
    This exact same thing happened last year also building an Athlon X2 machine, throughout these builds the same Tagan 480W PSU has been used, it appears ok on inspection and continues to power old ATX 20pin boards without glitches.
    Rubycon Rubycon Rubycon
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: I'm obsolete!!!, I can no longer build PC's.
    please disconnect the usb header and check you didnt put it wrong.
    disconnect also the FSP and try to get it working with only the tagan for the moment.
    sounds like the tagan has marginal probs though?
    • Fizzycapola
      • Oct 2006
      • 423
      Ok now it's really bare testing, I spent hours yesterday getting it all so neat inside, I really should test if it works first lol. Thanks again for another fast reply btw
      Ok USB headers disconnected and using only Tagan. Nothing.
      All non-crucial connectors disconnected. Only Power Switch connector still connected (even reset disconnected). Nothing.
      All case fans disconnected (these were all set on low btw). Nothing.
      Next up... ?
      1. replace (150w peak)GF8800 with (~10w?) MatroxG200 graphic card
      2. put (3 pin!) CPU fan into a spare molex and put in the Intel original 4! pin fan just incase strangely the board won't boot unless it has a rubbish Intel 4 pin fan.
      3. try a different psu (options 350w antec, 400w mercury, buy a new one for testing)
      Pictures incase theres something obvious that my eyes don't see:
      Pic 1 (overview)
      Pic 2 (mb connections)
      Pic 3 (mb connections atx pwr)
      Pic 4 (DDR/CPU)
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        i would take the board out of the case because maybe you are shorting the board behind.
        its a pity your tagan is suspect it does not make troubleshooting easy.
        • Fizzycapola
          • Oct 2006
          • 423
          Ok I'll try that. I can't think how it could be shorting, theres a good gap all the spacers are in the right places securing the board. I'd like to test further using very minimal components and connections, removing all ram is ok?, what I'm looking to achieve is that red glow on the mouse when PSU is switched on.
          If PSU is faulty, I wonder why it powers 20pin atx computers and not 24pin?, in the past I seem to remember certain combinations of fans on molex headers labeled S1 & S2 could produce this same effect of no MB power but molex devices a quick brief spin.
          BTW system I build last year, when returned was found to be DOA and refunded me, I wonder if somehow I destroyed it or it really was DOA. Maybe this ones the same also.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            well there seems to be a problem with the loading of the 12v rails. if no joy in the end then head over to http://www.jonnyguru.com/forums/ and get them to recommend a new psu.
            • WNG
              • Sep 2006
              • 354
              just for sh!ts and giggles, did you try resetting the BIOS?
              Curious, how is the FSP VGA psu switched on? Signal from card?
              “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
              We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
              • Fizzycapola
                • Oct 2006
                • 423
                yep bios reset several times no joy
                The 300w (400w peak) dedicated vga psu switches on from detecting voltage from main psu molex connector plugged into it. I read as it's just a dedicated 12v PSU (2 x 150 (200w per pcix connector peak) rails / only 1 rail will ever be used for my setup) it can modified (according to xbitlabs) to provide more power to other 12v devices also, as by default it only supplies supplementary 12v to vga after drawing max power from boards pcix16 slot, - 75watts from pcix.
                • Fizzycapola
                  • Oct 2006
                  • 423
                  2 more tests done
                  1. replace (150w peak)GF8800 with (~10w?) MatroxG200 graphic card . NOTHING.
                  2. put (3 pin!) CPU fan into a spare molex and put in the Intel original 4! pin fan just incase strangely the board won't boot unless it has a rubbish Intel 4 pin fan. NOTHING.
                  only changing psu left ... yawn ... so tired, I could have gone on a very long holiday with as many hot babes I could shake a stick at, instead of buying all this crap that doesn't work, now I need a holiday for it not working!!! *groan* =/
                  so... my last test before I check myself into therapy, that Corsair 620W I've had my eye on will order monday.
                  • Tom41
                    • Oct 2005
                    • 336
                    • England
                    The most complex PC I've ever built (perhaps the only PC I've built from scratch) was the one at my workplace. We ordered it to replace one on which the PSU and motherboard caps had vented, and the HDD was rendered useless by the 'dirty' power and sporadic signals from the board.
                    Installed the board in the case, put the CPU in, connected the PSU. At that point I decided to power up the board there and then - even with no additional memory/peripherals installed, provided the board and its built-in graphics card are working, it should at least go through POST and then do a boot failure message.
                    Turned it on, board seemed dead. Checked all connections, power-cycled at the mains, still dead. Then I finally realized I hadn't connected the extra 4-pin power plug coming from the ATX PSU to the separate 4-pin socket on the board!
                    Connecting that up, then powering on, I was able to get a picture on the screen and access the BIOS setup. But that little escapade does make you realize... if you can get stumped by not plugging in one aux power connector, the multitude of PSU and board connections today really mark the end of successful 'home build' PCs
                    You know there's something wrong when you open your PC and it has vented Rubycons...
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      in this case i put my money on psu or board. if its psu then its another wonder of the modern world...splitting up the 12v rails and giving poor amperage on each otherwise the board is doa.
                      but yeah sometimes the connections give a surprise. especially after recapping and results in a "shit i fucked the board"....no this power connector is wrong heh....
                      • starfury1
                        • May 2006
                        • 1256
                        Hi All
                        Ok complete wet finger in the air, long short and I am probably totally wrong since this is a complete new system and I would guess all parts are of spec for todays system
                        As I cant remember any detail of it and haven't look
                        at any details of what fizzycapola specs are.
                        but didn't we have a case where some MB need a -5V and the PSU dont have it
                        (due to changes in spec)
                        As I said probably totally wrong but these are sometimes the things you miss
                        2 c you having these probs with what should be a great box mate
                        • gonzo0815
                          • Feb 2006
                          • 1600
                          I would suggest to check the darn, damn skt 775 with a magnifing glass. If your not that carfully, this skt. will easily develop bend and broken pins.
                          You can see this with if you direct a flashlight from a certain angles on the socekt, the dammaged pinns will refleckt the light differently.
                          And yes, unless you already replaced the shitty Fujjihy caps in the tagan, it may suffer from them.
                          And i would certainly put the board on my desk, this is always recomended b4 puting it in the case. Just sit it down either on a sheet of paper of some antistatic foil / foam and power it up.
                          The systems should come up even without vga, but memory should be supplied.
                          • Fizzycapola
                            • Oct 2006
                            • 423
                            Ok thanks I'll try those suggestions.
                            Theres a line in the manual (nowhere else it seems, and unique to MSI boards) which states to use a PSU with -5v yes, but if that were totally necessary (which I believe it isn't because I read people using the board with not only not have -5v but other requirements missing also) I don't think the board would be very popular, it's an obsolete standard not included in latest PSUs.
                            I will try one of these PSU though if anyone knows one that exists and is Conroe/Geforce8800 suitable.
                            So my updated tests will be:
                            Board out it's case, removing cmos battery for an hour (hit power button to drain power maybe), Power and Reset buttons connected. Low power PCI graphics card
                            with monitor connected.
                            1. Test different PSU Corsair 620w, Delta/Globalwin PSU -5volt feature
                            2. Try ram in all combinations of slots, try different brand/performance RAM modules
                            3. Disconnect all cables and reconnect in all possible combinations (except stupid combinations)
                            4. Look around board for any defects.
                            x. Check all power supplies are delivering the correct voltage with multimeter.
                            x. Take a multimeter to the board to see whats going on? (not intended, not sure where to start)
                            x. Boot without P4 power connected (not intending to, but I read this can work?)
                            • gonzo0815
                              • Feb 2006
                              • 1600
                              -5v is usually not necesary, only some boards need this for the onboard AC97 sound codec.
                              The board should without doubth boot up without -5v.
                              If this board don`t to do the smallest beep, i am shure, either it was an DOA or one of the skt. 775 pins have been dammaged during instalation.
                              I am afraid, but now it is time to chek the soket. There is no sense in trying any further troubleshooting before you are shure that CPu and skt is fine.
                              • starfury1
                                • May 2006
                                • 1256
                                Thanks Gonzo like I said long shot in the dark I just remembered something about -5V and I sure it was MSI MB but don't know what one
                                • gonzo0815
                                  • Feb 2006
                                  • 1600
                                  Some Asus board (skt. 939) still needed the -5v, despite theyr desinged fpr 24 pins ATX 2.0 PSU`s.
                                  May be there are some other vendors, wich used the -5v rail.
                                  But from my knowledge, this was always not criticall for boot up.
                                  • Galvanized
                                    • Mar 2006
                                    • 468
                                    I have read that a number of the newer MSI MBs need the -5V for onboard sound.
                                    If one uses a sound card this would be a non-issue.
                                    • Fizzycapola
                                      • Oct 2006
                                      • 423
                                      More pictures:
                                      Bad allignment:
                                      Picture 1
                                      Some tracks damaged on the back of board and I don't know if this is normal but some kind of sticky slime *all* over the back of board that you can smudge around with your finger:
                                      Picture 2
                                      CPU Socket
                                      Picture 3
                                      CPU
                                      Picture 4
                                      • gonzo0815
                                        • Feb 2006
                                        • 1600
                                        If those rteaces are truely cut, i would say it is dammaged. But from your pic i can`t see that beyond doubth.
                                        Skt. sems to be ok.
                                        • niimi93
                                          Laptop No Longer Recognizes TV Sound Bar
                                          by niimi93
                                          I'll begin with the fact I don't know what change I made to my laptop that triggered this cause. I use my laptop as a pseudo PC by just connecting it to my big smart TV and using a wireless keyboard and mouse. I have a sound bar connected to the TV via optical audio toslink cable. I have game consoles connected to the TV. The game consoles and Netflix/other media apps installed on the smart tv all work properly playing sound through my sound bar with no issues. My laptop, until recently, was playing sound through the TV sound bar just fine as well. I don't know what change I made, and I don't...
                                          04-25-2023, 07:43 PM
                                        • survivalbloke
                                          Acer Predator Helios 300 - will not power up if battery is CONNECTED
                                          by survivalbloke
                                          This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                                          06-25-2025, 12:20 PM
                                        • beogeek
                                          820-2915-A Wont power on with battery connected
                                          by beogeek
                                          Ok so this doing my head in and hopefully someone more knowledgeable will be able to assist.
                                          I've got a MacBook Pro 820-2915-A it will power on without the battery connected, but when the battery is connected it will do a 2,3-second fan spin when pressing the power button and then nothing.
                                          After measuring and probing around I found that R7051 was bad, reading high instead of 2.2Ω so I replaced it. Still the same issue, I have the green light on the charger but it won't power on or charge the battery.
                                          So to cut the long story short I've replaced U7000,...
                                          02-26-2022, 01:29 AM
                                        • muhuruu
                                          PS5 too many USB devices connected
                                          by muhuruu
                                          Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
                                          05-19-2025, 07:14 AM
                                        • versionlab
                                          Weird problem, laptop stays on when connected to another pc
                                          by versionlab
                                          Hi, I want to ask for advice about an interesting issue I've been having with a sony vaio laptop.
                                          Client came and said that "a desklamp touched the back of the lid while laptop was operating normally and it caused the office's circuit breaker to trip. Laptop had never turned on since".
                                          After taking the laptop apart (checked dc adapter everythin ok), I found a faulty MOSFET on the motherboard which I replaced. Laptop managed to turn on. However, while booting it shut down. Nothing else seemed faulty and thermals were ok. Shutting down was coming at random...
                                          10-26-2022, 03:43 AM
