Creative VGA pinout
  • pentium
    • Mar 2006
    • 2778
    Creative VGA pinout
    I find a 12x dvd drive at value village and it came with a bonus DXR3 pci decoder card. So I get this thing home and load he drivers (Creative is really good at archiving it's files) and discover that I need to pass one of my VGA monitors through the card. So the vga out is no problem but compared to the DXR2 the DXR3 uses a different connector than the usual VGA for the input. I can probably make a custom cable but I need the pinouts for the socket.
    Anyone got one of these cables for pin reference?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2662
    • oooo ess aaaaaaaaa
    Re: Creative VGA pinout
    my dxr2 board had a 'jumper' that went from the output of my video card to the input of the dxr2 and if i remember correctly, the input on the dxr2 was the regular 15pin VGA connector. i took a look at a pic of the dxr3 board and it looks like they are using an s-video type connector for the dxr3's input. its just a guess though. find a VGAtoS-VIDEO adapter and you might be in business.
    did you check creative's site for info on that??
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
    • pentium
      • Mar 2006
      • 2778
      The dxr3 was different from the dxr2 (as the model implies)
      This unit has both a 7-pin "tv out" (looks like mac serial with an extra pin on the bottom left row) and a 9-pin (circular plug) VGA in connector.
      A visual look also shows the vga socket is larger than the tv out socket.
      Nope.
      I tried this before with other companies and they either never respond or say that they can't give the pinout for some reason.
      Find Nedry!
      • stretch0069
        • Oct 2003
        • 2662
        you may have to order a replacement "adapter" cable from Creative. From what I saw, though, the board is quite old (as far as computer hardware is concerned) so you may have to see if someone who has one can give you the pin-outs. With the large number of dxr3 boards sold, i'm sure someone out there can get you the pin-outs.
        sorry i couldn't be of more help
        • pentium
          • Mar 2006
          • 2778
          ...Which is why I posted.
          Find Nedry!
          • stretch0069
            • Oct 2003
            • 2662
            you may want to hit a forum for creative labs products. odds are better there.
            • pentium
              • Mar 2006
              • 2778
              They have forums?
              I guess I'll try there.
              Find Nedry!
              • stretch0069
                • Oct 2003
                • 2662
                i used to be on one a few years back. it was a graphics forum, but they had one topic just for creative labs. sorry i can't remember it
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  its probably the same as hollywood+
                  http://www.lava.net/~bhiga/HPlus/faq.html
                  • stretch0069
                    • Oct 2003
                    • 2662
                    there ya go.......
                    Will is da man
                    ...or woman......
                    ....haven't quite figured it out yet......
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      here is willa's dna encoded in ascii
                      ..........''...\.......... _.·´
                      • pentium
                        • Mar 2006
                        • 2778
                        It's the same thing as the hollywood+ but with improved audio and video.
                        Is that yours?
                        Find Nedry!
                        • willawake
                          Super Modulator
                          • Nov 2003
                          • 8457
                          • Greece
                          yeh
                          • pentium
                            • Mar 2006
                            • 2778
                            You got the pass-through cable?
                            If I can get the pinouts for both sides of the cable I can build my own.
                            Find Nedry!
                            • pentium
                              • Mar 2006
                              • 2778
                              Silly me.
                              The link had the pinout.
                              Thanks willa!
                              Find Nedry!
                              • pentium
                                • Mar 2006
                                • 2778
                                1:Blue IN
                                2:GND
                                3:Green IN
                                4:GND
                                5:Vsync IN
                                6:Hsync IN
                                7:Red IN
                                8:SDA (from pin12 of DB15)
                                9:SCL (from pin15 of DB15)
                                Um, that's only two grounds. That means that either all three color grounds are tied together or the pinout is wrong.
                                Get an ohm meter and see if pins 6,7 and 8 on the vga connector all connect to either pin 2 or 4 on the mini-DIN connector.
                                Find Nedry!
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  nevermind. I go it.
                                  Find Nedry!
                                  • stretch0069
                                    • Oct 2003
                                    • 2662
                                    you're awesome dude!!!!! i guess i'll have to take a Greek detour on my way to PI. I owe you quite a few beers by now
                                    • pickledegg
                                      Dell Inspiron 7501 / Vostro 7500 (2020) - eDP connector pinout/panel compatibility question
                                      by pickledegg
                                      Hello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
                                      I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...
                                      10-02-2024, 04:54 PM
                                    • ktmmotocross
                                      Ps5 pro - one beep and not start after hdmi port change and decoder ic reflow
                                      by ktmmotocross
                                      Hello.
                                      Have this ps5 pro EDM033 that came with damaged hdmi connector. i replace it and console works for few days but show hdmi problems when cold start. so cold joint. reflowed connector and decoder ic as i think he have cold joint. but now i have only one beep and no start. can heatdamage of this decoder ic prevent start?
                                      i have ps5 repair guide but not ps5 pro so link me to it if u know it
                                      04-27-2025, 01:10 AM
                                    • maleksa
                                      Korg Kross2 Service Manual and LCD pinout
                                      by maleksa
                                      The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
                                      However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
                                      Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
                                      From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
                                      10-11-2024, 05:54 AM
                                    • ChaosLegionnaire
                                      by ChaosLegionnaire
                                      09-13-2022, 09:02 AM
                                    • szelda
                                      Walkom NP-903 Charging Connector Pinout
                                      by szelda
                                      I'm looking for assistance with powering on a laptop that also goes by the names Modern Computer Corp NP-903 or NoteStar NP-903. I don't have the original charger for it, and I'm unfamiliar with the connector type. I'd be very grateful for information regarding the pinout, specifically where to connect the positive and negative leads for a DC 12V 2.5A power supply.
                                      11-01-2025, 07:22 AM
